Originally posted by greasefingers
It cost $ 19.26/gallon at my dealer. It is concentrated so pick up a gallon of distilled/ di-ionized water from the grocery store to cut it with.
If you want a full change in fluid, then change it twice. Drain it one weekend then drive it a week and do it again the following weekend. That way you replace most of the coolant.
There used to be kits that allowed complete flushing of the coolant. You just cut a hose, inserted a T-fitting, then screwed a garden hose in it. Remove the thermostat and turn the hose on, engine running. The liquid is ejected from the radiator cap (kit included a tube for that) and when it ran clear you were done. Then drain the engine and radiator of the hose water and replace it with a blend of distilled/coolant 50/50. I don't think many people do this anymore
