Does anyone use Auto Maintenance Pro to keep records of the maintenance performed on the vehicles? If not what other software do oyou use to keep track of your maintenance?:awais:
A woman's mind is cleaner than a man's. She changes it more often.
-- Oliver Herford
03' 4Runner
Titanium Gray
SR5 All Time 4WD V8
Factory Sunroof
Double Deck Cargo Area/Cargo net
DRL 5 Speed Auto Trans
Jaos Center Protector R
Jaos Progreate Off Road Lights
Dueler REVOS
SilverStars
Volant CAI
WeatherTech Bug Deflector
WeatherTech Floor Liners/Wind Deflectors
Yep I use Excel because you can customize the layout! On the first Sheet are the maintenance specifications, so the columns are set up/labeled for part numbers, brand, price, quantity, torque valves, and comments. Sometimes I list what metric socket is needed for the job. Like the 12mm bolts to remove the skid plate for access to the oil filter and the 14mm socket to remove the oil drain plug.
Then on the second Sheet I log the actual work performed, date, mileage.
I have four vehicles so my Workbook has several Sheets.
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
Microsoft Office also has a couple Templates that you can download for free for almost anything that you can think of. The link provided is an example of an automtive record. There are at least three of these. You can modify them as well. http://office.microsoft.com/en-us/te...CT101438521033
Originally posted by greasefingers Microsoft Office also has a couple Templates that you can download for free for almost anything that you can think of. The link provided is an example of an automtive record. There are at least three of these. You can modify them as well. http://office.microsoft.com/en-us/te...CT101438521033
Awesome template greasefingers. Too bad I'm feeling lazy right now to import data from my current sheet to the template. Another item for the 'to do' list.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
