Old 01-13-2019, 08:26 PM #1
coopma coopma is offline
coopma is on a distinguished road
Transmission flush
Advice please.
I have a 2004 4Runner with 175,000 miles.
What do you think about a transmission flush?
Coolant flush?
Differential flush?
Other maintanance? (I have done regular oil and filter changes and a timing belt change at ~100,000.
CoopMA
Atlanta, GA - 2013 4Runner SR5, 2004 SR5, had a 1991 SR5.
coopma is offline   Reply With QuoteReply With Quote
Old 01-15-2019, 12:22 PM #2
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Please read stickies on this forum. All your questions were answered hundreds of times. Search is also your friend. And, yes you need to change all of those fluids if it hasn't being done on record. Welcome to the forum.
<<<< is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 11:22 PM #3
bsa70 bsa70 is offline
bsa70 is on a distinguished road
Very common question. Read stickies and google is your friend. Basically with that amount of miles, do a low pressure flush on the transmission-google. Ok to flush the coolant and swap out the differential fluid. Just be careful with the transmission.
bsa70 is offline   Reply With QuoteReply With Quote
Old 02-09-2019, 09:47 PM #4
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
what do I think of those things? Yes, do them. Not very hard, just a little tedious in some cases but your truck will run well for a good long while.
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
Old 02-17-2019, 09:18 PM #5
If it has never been done, you do not want a high pressure flush that you get at dealerships. It will kill your transmission. If you start out with the high pressure flush say every 50k miles, it is ok. What you want is a low pressure flush, can be fairly involved so google.
Yes change out all the fluids.
Old 03-05-2019, 01:12 PM #6
mitchell.marsh mitchell.marsh is offline
mitchell.marsh is on a distinguished road
I would consider doing the services recommended at 90K: coolant flush, transmission flush, oil change, new spark plugs and wires, and a new air filter.
mitchell.marsh is offline   Reply With QuoteReply With Quote
Old 03-12-2019, 08:22 AM #7
This advise is good except for a high pressure transmission flush that all dealerships do. If you wait til 90k, there is a good chance you will dislodge varnish and cause all kinds of problems. High pressure needs to be done at about 40 to 50 k miles.
Low pressure flush can be done at any time.....
Old 07-29-2020, 03:54 PM #8
Bigt5646 Bigt5646 is offline
Bigt5646 is on a distinguished road
Is there hope?
Hello all,
Went out and bought some grease guns today to grease my driveline and thanks to the forum it has been going well. Today, things have been a little strange with the truck. I have an 05 v6 4x4 and I’m worried that what I may have been diagnosing as a driveline clunk may actually be a transmission issue. Today I had to brake hard from about 50 mph to avoid hitting a car that had stopped in front of me. After hitting the accelerator to get going again the car reved up high and then chirped the tires about 1-2 seconds after I had pressed the accelerator. It’s never done this before. I checked my records (I had the transmission drained and filled less that 5,000 miles ago) upon looking at the form from Toyota it seems that i was only charged for 2 quarts of 00289-atfws @ 10.49 a piece. Is my transmission fluid just low or should I start looking into a rebuild? Should I flush it and hope for the best? Or just do a correct drain and fill with the correct fluid amount? Could this be a driveline issue and my transmission is fine?
Thank you for your time. I appreciate any and all feedback.
Bigt5646 is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 01:34 AM #9
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Don't forget brake fluid and power steering fluid. I recently flushed power steering fluid on a 2007 Jeep grand Cherokee using the engine off method. It was easy.
I did it slightly different than the video. I unplugged the factory line from the power steering cooler to reservoir. Raised it above the reservoir. Connected clear hose from the power steering cooler to empty container on the ground. On the Jeep Grand Cherokee it took about 2.5qts to flush the system.
Why You Should NEVER EVER FLUSH POWER STEERING FLUID Until You Watch This!! - YouTube
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
belt , change , filter , flush , transmission
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
Transmission Flush and like new!!! achha64 3rd gen T4Rs 1 09-04-2014 10:51 AM
BG Engine Flush / Transmission flush scrhew 3rd gen T4Rs 19 09-11-2013 05:44 PM
Transmission Flush Dylan Classic T4Rs 2 12-11-2011 03:49 PM
Transmission Flush ? frohbego 3rd gen T4Rs 2 09-01-2006 07:40 AM
