Old 02-13-2020, 09:03 PM #1
JsinLegacy's Avatar
JsinLegacy JsinLegacy is offline
JsinLegacy will become famous soon enough
JsinLegacy's Avatar
Spots on clear plastic
My wife has these spots on the clear plastic in front of the speedometer. No clue what they are from as I don't typically mess with her vehicle and I have no idea how to get rid of them.
Tried wiping them away but they just seem to reappear after the liquid dries.
Any ideas or suggestions or am I going to need to replace the entire piece.
Thank you.
JsinLegacy is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 12:55 PM #2
MSRP. MSRP. is offline
MSRP. is on a distinguished road
If they reappear after wiping with water (in the exact same location, pattern unaltered):
**Try at your own risk: I would consider trying some isopropyl alcohol--but try in an inconspicuous spot first.
MSRP. is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 01:12 PM #3
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
your wife a smoker? then coughs..
I have old vehicles .. I polish my head light lenses with plastex polish..
I then had scratches on my center console on my 1996 Impala.. not deep but it also looked dull since it is over 20yrs .. I removed it and polished it up and it looked like new no damage perfect ..
product is for plastic will not do damage ..
I do not know how to remove this on the runner .. only 10 bucks on the plastex ..if it works then lookup how to remove those parts.
https://www.amazon.com/Meguiars-Plas...1700430&sr=8-1
catrains is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 02:39 PM #4
swampdodo swampdodo is offline
swampdodo has a spectacular aura about swampdodo has a spectacular aura about
To the OP...has your wife been to a car wash or one of those so called 'detailers'...because I can tell you from experience that dash/interior dressing like Armorall will make those spots on the cluster lens...especially, if left to dry.
My wife's CRV came from a body shop with those kinds of spots on her car...the body shop 'detailed' and I use that term loosely, as a 'customer satisfaction service' (thanks for nothing). Unfortunately, the only thing that will remove it ends up ruining the lens...makes it worse. Ended up just replacing the lens...fairly cheap and easy on her car.
swampdodo is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 06:52 PM #5
Snypr18's Avatar
Snypr18 Snypr18 is offline
Snypr18 is on a distinguished road
Snypr18's Avatar
Is it some material on the plastic or is it an actual deformation in the plastic? Can you catch your fingernail on it or scrape it away?
It looks like overspray from a cleaning product. You could try 50/50 rubbing alcohol and water and see if it makes any difference. If nothing seems to work, you could also try buffing it with Nu Finish on a microfiber towel and see if that brings it out, before just replacing the lens outright.
Snypr18 is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 06:01 PM #6
JsinLegacy's Avatar
JsinLegacy's Avatar
No smoking on her part. I think @Snypr18 is correct in it being overspray from something. She took it to a car wash that does some detailing apparently and then she noticed it a few days later. At least, that is what she is telling me. haha.
@swampdodo I'm not sure on how to remove it from her car. She drives a Corolla IM. I'm sure I can find some sort of guide on the internet though if need be.
Thanks for all the suggestions also. I'll try the alcohol on a small spot and see if that does anything if not then I'll try the plastic polish. If neither work then I'll just end up replacing it.
Old 02-16-2020, 09:07 PM #7
PLASTEX WORKS ON ANY sun/stains/light scratches...
some alcohol could dull the plastic finish.
Old 02-17-2020, 04:20 PM #8
post back how it was fixed ..
Old 02-24-2020, 01:59 AM #9
JsinLegacy's Avatar
JsinLegacy's Avatar
So I used the PlastX that you suggested. Put it on a sponge and wiped the whole area down and left it on for about a minute then wiped away with a cloth and it came right off.
So thank you for the suggestion and input.
Old 02-24-2020, 03:05 PM #10
good feed back from your work, if members have plastic issues this will help ..
use a foam pad that is best.. I use a black foam pad on my black sedan with 3m paint polish on the paint looks like a mirror..
Old 02-24-2020, 04:38 PM #11
JsinLegacy's Avatar
JsinLegacy's Avatar
There is a small portion up near the very top of the plastic that still has some spots. I'm going to hit that spot this week and hopefully get rest of it. Although, if you're driving you wouldn't notice them at all.
I'll pick up a foam pad, will probably work better than a sponge honestly. I'm just glad it came off.
clear , liquid , plastic , spots , wiping
WTB: 3rd gen clear plastic cluster face BADCLOWN For Sale: T4R Items 5 10-30-2015 12:54 PM
Clear-Plastic Protectant at trim panel? zerowkul98 4th Gen T4Rs 3 07-12-2012 12:23 PM
Can I buy just the clear plastic part of the headlight? ohnoitsthecops 4th Gen T4Rs 9 12-21-2011 09:36 PM
Cleaning Clear Plastic over Instruments hwheeler 4th Gen T4Rs 7 10-27-2007 01:44 AM
Where did clear plastic hood protector come from? TeryT 4th Gen T4Rs 7 03-08-2005 01:39 PM
