Old 03-28-2019, 06:11 PM #1
Fareastplaza Fareastplaza is offline
Fareastplaza is on a distinguished road
Manual said change transmission fluid only need in certain conditions
My 2010 (5thGen) T4R manual said:
Replace automatic transmission fluid every 60k miles only if you drive primarily under the conditions indicated below:
- Driving while towing, using a car-top carrier, or heavy vehicle loading
Does it mean if I drive it only for family around mainly doesn't need to do transmission fluid flush/change at all? I don't believe this.
I currently have 150k km (Around 100k Miles). Can I still do flush? or I better ends up drain only. Or I can follow manual and do nothing?
There are so many different opinions out there, very confusion.
Thanks
Fareastplaza is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 07:30 PM #2
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Yes, do a complete fluid exchange using Toyota brand WS fluid.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 04-01-2019, 06:08 PM #3
Hi, Seymore. Thanks for your reply. Do you mean a complete flush? One dealer recommended a full flush ($360 and not drop pan, no filter clean/change) and he said it won’t cause any issue. But another dealer recommend me to do a drain/fill first to begin with. An flush can be done later and they charge $260 only.
Looks like it is totally personal decision after all :-)
Thanks!
Old 04-01-2019, 06:25 PM #4
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
I'll be servicing my transmission and transfer case every 50K I change my diff fluid every 25K and engine oil every 5K Maintenance is key and your fluids can never be too fresh. Cheap peace of mind if you ask me.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 03:31 PM #5
Complete exchange using either the flush method the dealer recommended or the exchange using transmission cooler lines. Ask the dealer if they use Toyota WS fluid.. Most dealers around here use a "compatible" non-Toyota fluid, which is not the perfect specification for your transmission.
Drain and fill is inappropriate because it leaves most of your old fluid in the transmission.
Old 04-07-2019, 02:53 PM #6
J.F. Sebastian J.F. Sebastian is offline
J.F. Sebastian is on a distinguished road
After finally coming to the unsettling conclusion that I can't let a Toyota dealership "service" my car, have found a highly reputable, independant shop that specializes in Toyotas (Toyota Master Tech-owned with another on staff) in my general area (45 minute drive away). They have recommended essentially the same thing if one cares about their investment. Peace of mind is worth the cost to me. Being old, half crippled and an apartment dweller, having a competent, honest mechanic to work on my vehicle is actually cheap if I can buy that with money.
J.F. Sebastian is offline   Reply With QuoteReply With Quote
Old 04-11-2019, 04:43 AM #7
Lawrence_Liang Lawrence_Liang is offline
Lawrence_Liang is on a distinguished road
This is the 4th year I own my 4R... and I will be doing my 4th drain and fill next OC...
从我的 iPhone 发送,使用 Tapatalk
Lawrence_Liang is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 11:24 AM #8
bjax4x4's Avatar
bjax4x4 bjax4x4 is offline
bjax4x4 is on a distinguished road
bjax4x4's Avatar
I have never had a transmission flush. You all are about to convince me to do it.
2008 White Sport Edition
220K miles
bjax4x4 is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 02:02 PM #9
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
According to a 5th Gen 4Runner Scheduled Maintenance Guide, the transmission fluid should be first inspected at 30,000 miles, then again at 60,000 miles.
If you use your 4Runner for towing, under the Special Operating Conditions it is recommended to replace the transmission fluid at 60,000 miles.
Next inspection of the transmission fluid is at 90,000 miles, then again at 120,000 miles. Transmission fluid replacement (under SOC) is recommended at 120,000 miles.
Here is a link to a video explaining when you should change your transmission fluid, answering whether or not changing your transmission fluid could damage your transmission, and whether or not to change or flush the transmission fluid.
YouTube
And this link to a video outlining the steps to actually change (not flush) the transmission fluid.
YouTube
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 05:42 PM #10
JohnathanSullivan JohnathanSullivan is offline
JohnathanSullivan is on a distinguished road
My 06 silverado has started to nickel and dime to hell every time i turn the key. Ever since my cousin who is a mechanic at a dealership said the 4runners are tanks i have started to fall in love. He mentioned if taken care of properly they run forever. So i found this forum and have some questions. I live in PA so its winter for what seems like 6 months out of the year haha. How are they in the snow? I see some are AWD and some 4WD. What do yall prefer? I have tons of questions but ill just keep it small. Come on people put me over the edge and talk me into pulling the trigger hahahttps://19216811.cam https://xender.vip https://testmyspeed.onl
JohnathanSullivan is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 09:02 PM #11
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
This comment is only applicable to the current 5 gen models excluding 2WD variants. All 4Runner are 4WD, but not all are AWD. The Limited is the only one that can do both. If snow performance if important to you, then the Limited is ideal.
By the way... I also own a 2004 Silverado Z71, its a great truck, but the 4Runner is certainly built better. I still keep it around because when you need a truck, you need a truck.
Old 02-06-2020, 09:05 PM #12
Bumbo's Avatar
Bumbo's Avatar
I agree… I all fluids eventually degrade over time.
They may say its good for the life of the transmission, but in the manufactures eyes, what exactly does that mean? Till the warranty expires?
Old 02-07-2020, 08:01 AM #13
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
You absolutely should since “lifetime” fluid is a myth, but at 220K, you don’t want a flush, you want a full-fluid exchange. The difference is that a flush uses pressure while an exchange is just that - old fluid out and new in. There are several 4th Gen write ups on how to do it.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 06:43 PM #14
Snypr18's Avatar
Snypr18 Snypr18 is offline
Snypr18 is on a distinguished road
Snypr18's Avatar
I have heard that it is better to just change the fluid rather than do a flush if the fluid has not been changed regularly; reason being that a pressurized flush can dislodge debris inside the transmission, which will start causing problems down the line.
Snypr18 is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 07:46 PM #15
lixamturtle lixamturtle is offline
lixamturtle is on a distinguished road
i dont think it would hurt!
lixamturtle is offline   Reply With QuoteReply With Quote
drive , fluid , flush/change , manual , transmission
Manual Transmission Fluid Change kjcprb 3rd gen T4Rs 41 12-14-2022 04:58 PM
Better Manual Transmission Fluid For Winter? nalbertasr5 3rd gen T4Rs 17 02-19-2019 12:45 AM
Manual Transmission Fluid Maverick7 3rd gen T4Rs 12 11-29-2014 09:00 PM
Transmission Fluid Change help faxmachine Maintenance/Detailing 1 11-12-2008 07:26 PM
Transmission Fluid change???? jesman1484 3rd gen T4Rs 1 11-01-2007 07:49 PM
