Old 07-06-2019, 09:34 PM #1
stella stella is offline
stella is on a distinguished road
How to clean this?
Does anyone know how to clean the dirt around the outsides of the panels on my 2006 4runner?
Bonus question: how can I make the running boards black again?
How to clean this?-2019-07-05-17-38-15e-jpg
stella is offline   Reply With QuoteReply With Quote
Old 07-06-2019, 09:51 PM #2
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Did you see my post in your other thread? Easy to get rid of.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 11:46 AM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I read your reply and replied to it....here's my reply here as well, plus a bit more info.
I'm not sure if you know what her issue is, what I see is dirt getting behind the edges of the clear film on the door/s at the bottom of the clad panels, this clear film was install to help protect the plastic cladding from rock chips, the dirt line you're seeing is not on the paint it's on the back edges of the clear film.
You can possibly clean the dirt from behind the film but it will just be back fairly soon because the edge of the film is lifting up/slowing coming loose allowing dirt to get behind it, some on the forum have removed the film so this doesn't happen any longer but how they got it off would have to be searched for as I don't remember exactly how they got it off, I know it's not as easy as it sounds because it has a self adhesive back on it.
It seems I do remember one guy using a safe solvent that won't damage the paint but will dissolve glue and plastic razor blades, yes you read that correctly, plastic razor blades, check online they are made for using on painted surfaces so it won't scratch the paint.
2004 Limited V8
Old 07-07-2019, 12:01 PM #4
cb1111's Avatar
cb1111's Avatar
Yes, I knew what it was, but I thought that you had already removed the ppf and were just dealing with the residue.
No real way to fix it except to remove the PPF, clean as I outlined and replace with new.
Old 07-07-2019, 09:22 PM #5
Thanks!
I'll go look in the other thread for your response. I'm still getting used to this forum. Thank you very much!
Old 07-07-2019, 09:36 PM #6
cb1111's Avatar
cb1111's Avatar
Unfortunately, once PPF (Paint Protection Film) starts to peel, there isn't much one can do. Even if you remove the damaged areas, it won't be long before it peels again.
Remove it, clean the area and reapply new film. Auto parts stores (PepBoys, Autozone etc.) sell rolls of cheap, somewhat junky, film in 4 and 6 inch rolls that is fine for this sort of application and you can swap it out every couple of years.
My other post was written in a very basic way, so please don't take it as being talked down to if you know that already.
Old 02-14-2020, 06:37 PM #7
Snypr18's Avatar
Snypr18 Snypr18 is offline
Snypr18 is on a distinguished road
Snypr18's Avatar
Aerospace 303 is great for keeping / returning plastic and rubber to their original color. Also protects from UV and helps prevent drying and cracking. I wipe all the black plastic and rubber trim down on my cars once a month or so.
Snypr18 is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 07:47 PM #8
lixamturtle lixamturtle is offline
lixamturtle is on a distinguished road
great question im interetsed
lixamturtle is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 07:50 PM #9
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
that stuff won't damage the rubber trim?
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 09:09 PM #10
Snypr18's Avatar
Snypr18's Avatar
It sure shouldn't, its basically just sunscreen for exterior surfaces. It is really popular for marine use since boats take so much abuse from salt water and direct sun. It makes a world of difference on window trim, grilles, etc.
303 Aerospace Protectant Review and Guide | Ask a Pro Blog
Old 02-15-2020, 10:30 PM #11
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thanks...i def need to get some of that
Regards, sport2004
Old 02-25-2020, 03:03 PM #12
SaguarGo SaguarGo is offline
SaguarGo is on a distinguished road
Just used this on the black trim panels on the back side of front window and front part of back window, and also on the black plastic on top rear bumper. It made a world of difference. Highly, highly recommend. Thanks for the tip.
SaguarGo is offline   Reply With QuoteReply With Quote
black , boards , clean , make , running
How clean is "clean" for the water pump mating surface? eremoy Maintenance/Detailing 6 05-31-2016 08:14 AM
1993 SR5 4runner $1200 great body/clean leather interior clean title builder project zidaro For Sale: Vehicles 2 02-06-2015 03:09 PM
Clean garage = clean runner rushrunner 4th Gen T4Rs 13 06-30-2011 03:50 PM
For Sale = 2004 SR5 4Runner 2WD, clean, Clean, CLEAN... w/ maintenance records... 4runDiZZLe Classifieds - buy & sell (no commercial ads please) 1 01-19-2010 03:53 AM
ISR clean up mike1305 3rd gen T4Rs 3 12-22-2006 02:56 AM
