Old 07-31-2019, 07:40 PM #1
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Rust prevention other then Fluid film?
Looking for a more permanent solution to treat and cover the frame of my TuRD. Bought it new off the lot last Sept 2018 and its showing some rust spots. Enough that I want to treat them. Truck is in the "deep south" so there is a lot of moisture, but not much in the way of road salts. What have you guys done? I'm thinking of hitting rust spots with por then maybe hitting every thing with Eastwood encapsulator premium and covering with a Eastwood chassis black 2 part epoxy. Then using Fluid film or lps3 on the inside of the frame. What does the group think?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 08:19 AM #2
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Surprising that this is happening that far South. Fluid Film is good for the inside of the frame and crossmembers, but it doesn't hold up to water spray and washes off the exterior surfaces.
I've had good results there with Amsoil Heavy Duty Metal Protector spray, but it has to be reapplied each year in the areas that get a lot of splashing.
Ideally, POR-15 for the exterior surfaces after good preparation is the right approach. I've done this on my skidplates and front crossmember (under the radiator) and they still look new.
waypoint is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 04:09 PM #3
gp55445's Avatar
gp55445 gp55445 is offline
gp55445 is on a distinguished road
gp55445's Avatar
Came here to post Amsoil too.
gp55445 is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 04:55 PM #4
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
The $5.00 rustoleum satin black works just as well. The oil that you spray matters more than any paint ever will. I killed a lot of time trying these stupid paints. If it can be removed for a wire wheel then road debris and salt will make quick work of it. Oil it up, regardless of what you use, spray some silicone spray on all your rubber bushings. These anti rust oils can eat them.
Old 08-02-2019, 05:36 PM #5
Charlievee's Avatar
Charlievee's Avatar
Anyone use the LPS3? They say safe for paint and rubber. I just want to get after it, it's all surface rust on unprotected spots except the welds on the front end are rusting up. Not sure why welds would rust up in under a year... I'm guessing the parts sat around before they built the truck? Who knows. So humid down here, I think I'm going to rust.
Old 08-02-2019, 11:09 PM #6
waypoint's Avatar
waypoint's Avatar
Rust at the welds is a common problem, seen it on my '02 Chevy truck, '03 Tundra, etc. POR15 paint after good prep with their Metal Ready surface chemical and cleaning is money in the bank for protecting the weld joints.
Old 08-03-2019, 05:40 PM #7
Charlievee's Avatar
Charlievee's Avatar
I almost avoid amsoil due to the fact it's a PITA to find. Most reviews are made by someone selling it.
Old 08-04-2019, 10:11 PM #8
waypoint's Avatar
waypoint's Avatar
My local hardware store keeps a shelf of Amsoil stuff at reasonable prices, otherwise I'd never have tried it.
Old 08-06-2019, 12:28 AM #9
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 will become famous soon enough
Jarheadoo7's Avatar
YouTube
This video compares several DIY rust preventative methods.
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 10:16 PM #10
4Liberty 4Liberty is offline
4Liberty is on a distinguished road
Cosmoline for Sale - Cosmoline Direct Rust Preventives, Sprays & More
RP-342 Spray Can. I used 3 full cans. You want to wear a facemask filter, safety glasses or goggles and rubber gloves. Also cover the driveway or garage floor with plastic and back over on top of it to keep the wind from blowing it around. Use in well ventilated area! The red straws don't stay in the nozzle head very well. I lost all mine inside my frame. Spray inside the frame holes every direction possible. Then coat the outside of the frame. If you have KDSS make sure to spray the hydraulic manifold block under the drivers door. Seals everything in a wax coating. The stink will lessen after about a week. Don't spray your exhaust pipes because that really stinks! But it will burn off if you do. I drove up on 4 ramps so I could move around under the vehicle. No lift yet.
2019 Toyota 4Runner Off-Road Premium, KDSS, Moon Roof, Classic Silver Metallic, Dobinsons IMS w/Rear Comfort Shocks 302/505 coils, JBA STD UCA's, General Grabber ATX LT275/70R17E,
4Liberty is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 02:02 PM #11
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Cosmoline? Isn't that what Moisin Nagants were packed in?
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 02:38 PM #12
Charlievee's Avatar
Charlievee's Avatar
Thats what everything in the arms industry is coated with.
fluid , hitting , lot , rust , spots
Rust prevention - Is fluid film enough? BriAntic 5th gen T4Rs 4 04-02-2018 11:50 AM
Any rust issues on Gen 5? Beach rust prevention. Fomer_FJ_owner805 5th gen T4Rs 8 09-19-2016 01:08 PM
Hitch rust prevention renau001 5th gen T4Rs 5 03-19-2016 09:30 PM
Electronic Rust Prevention Whiplash Willy 5th gen T4Rs 9 09-21-2013 07:54 PM
Vehicle Theft/Break-in Prevention Film limamike 5th gen T4Rs 20 06-06-2012 10:22 PM
