Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 05-03-2014, 01:34 PM #1
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
4th Gen Front brake caliper rebuild for stuck piston
This work was inspired because I wanted to find the root cause and potential fix for the infamous stuck caliper pistons. This rebuild option is also a way to save some dollars using parts instead of a remanned caliper.
Bottom line: the inner bore diameter between the piston seal and cylinder boot is rusting. This is potentially due to lack of lubrication that would keep the piston lubed and displace any moisture.
Read on if you want the details.
Background:
Here is my original thread - Front brake caliper & pad replacement
I've spent over C$1000 over 5 years on 6 reman calipers. Ordered the OEM caliper seal kit (for entire 8 pistons) and 4 new pistons. Came in at U$85 plus a tube of brake grease and a can of brake cleaner. Ended up using all the boots and rings plus only 3 pistons and seals. I knew from my last check when doing my winter tire rotation that I was coming due for more caliper work with a tight piston.
I'm not sure of the condition or amount of the piston lube under the boot "as new" because I didn't look at this when I bought the truck or any time I put on a remanned caliper. I'm going to guess there isn't much lube there even though it calls for it in the FSM (but doesn't specify how much.) The past lessons learned of exercising the pistons by depressing them at each tire rotation plus more frequent brake fluid flushes weren't doing anything to prevent the stuck piston. I thought give it a shot this way and try to break the replacement cycle. The labour is free because I'm doing the wrenching. Working on the T4R is priceless.
FSM references:
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 05-03-2014, 01:35 PM #2
Kmvreter's Avatar
Kmvreter's Avatar
Started by removing the wheels. Reattach 2 lug nuts to hold the rotor in place.
Remove the brake hardware and pads.
Remove all 4 of the cylinder boots (only my driver's side caliper had spring rings.)
Pic 1: Depress the brake pedal to expand the pistons. DO NOT do this with the caliper removed from the rotor otherwise the pistons will pop completely out of the bores and you will be dealing with a massive brake fluid leak.
Pic 2: Close up. Notice the rust on the lower inner piston. This piston wasn't completely stuck but was hard to compress.
4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild1-jpg  4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild2-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 05-03-2014, 01:35 PM #3
Kmvreter's Avatar
Kmvreter's Avatar
Remove the caliper in order to work on it on the bench. Plug the end of the open brake line with some Glad/Saran wrap and an elastic to minimize brake fluid loss. There will be a lot of brake fluid that comes out of the caliper because all the pistons are extended.
Note: I was warned DO NOT seperate or open the caliper halves. It may be easier to work on the bores this way but you risk a leaking caliper when you put it back together because replacement O-rings aren't readily available.
I didn't remove all of the pistons. I cleaned, inspected and lubed each that was freely moving. Then I manually depressed each back into the bore. You can see how this looks with the right side piston in the first pic below.
Pic 3: After doing the 3 easy pistons I worked on the lower inner one. What a PITA. This one wasn't even entirely frozen like the driver's side. Tried to use a vice grip to remove it. It was hard to budge and rotate. Ended up using a hammer and drift to knock it out by working my way around (sorry no pic of this.) Time and patience.
Pic 4: Shows the bore with the piston removed. The piston isn't badly corroded and the surface rust is easily removed but I didn't want to chance it and just used a new piston (plus I chewed up the top pretty good with the grips.)
Pic 5: A close-up of the culprit. Notice the rust buildup on the inner bore that causes the diameter to close/decrease and "grab" the piston.
4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild3-jpg  4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild4-jpg  4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild5-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 05-03-2014, 01:36 PM #4
Kmvreter's Avatar
Kmvreter's Avatar
Pic 6: Removed the bore rust as best as possible with emery cloth. Did this with the old seal in place to keep as much junk as possible out of the groove.
Then remove the old seal.
Pic 7: All cleaned up and ready for a new seal. Used liberal amount of lube on the seal.
Pic 8: Comparison with an unrusted bore that had a freely moving piston (pic taken later from driver's side caliper.)
4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild6-jpg  4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild7-jpg  4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild8-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 05-03-2014, 01:36 PM #5
Kmvreter's Avatar
Kmvreter's Avatar
Pic 9: The OEM seal kit. It came with 2 sets of different styles of cylinder boots (see next pic.)
Pic 10: Note explaining cylinder boots. I wasn't able to get a good pic of the 2 styles but there are subtle differences. I decided to use what I assumed was the "new" style becasue it was different than the original boots. Who knows, this may help. It certainly can't hurt.
Pic 11: The OEM piston and the brake grease I used. There was a very small packet of Toyota pink grease in the kit. You can buy a larger tube of this but it's an arm & leg at the stealer. The PermaTex works. Be careful to use the right "lithium soap base glycol grease" that is compatible with the seals. DO NOT use white lithium grease.
4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild9-jpg  4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild10-jpg  4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild11-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 05-03-2014, 01:37 PM #6
Kmvreter's Avatar
Kmvreter's Avatar
Back to the rebuild.
Pic 12: A piston all lubed up before being inserted back into the bore.
Pic 13: New cylinder boots and spring rings attached. Used plenty of lube inside the boot to hopefully prevent moisture from getting in the joint. Caliper is ready to be reinstalled and then button everything back up.
On to the driver's side...
4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild12-jpg  4th Gen Front brake caliper rebuild for stuck piston-t4r-caliperrebuild13-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 05-03-2014, 01:37 PM #7
Kmvreter's Avatar
Kmvreter's Avatar
Lesson learned:
You don't have to wait until you have an actual stuck piston. You might want to consider doing this on a remanned caliper before installing it.
This lubing can also be done with the caliper on the truck as follows:
Remove the pads and boots.
Extend the pistons by depressing the brake pedal.
Lube the pistons and depress them back into the bore but not all the way in. You might want to do one set and temporarily put a pad back in, then the other set because as you press a piston in it will want to extend the others out. You need to hold the pistons from wanting to extend back out.
Reinstall the boots and spring rings.
Reinstall the pad hardware.
I'll be doing this shortened method as an inspection and maintenance item in order to monitor the pistons. I'll keep you posted.
As mentioned, there was no visible amount of lube under the original (reman) boots after use. Hopefully by lubing the pistons, and more importantly the bore joint, it might be successful in preventing the bore rust.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 05-05-2014, 09:09 AM #8
Bob J Bob J is offline
Bob J is on a distinguished road
Excellent write up..... Much appreciate you doing this and documenting your results....
2003 V8 Limited
aFe filter, V-Led interior lights, RCI skid plates, Brembo rotors, NAPA lifetime reman calipers, Stoptech brake lines, WMW "fedrlbiker" roof rack
Bob J is offline   Reply With QuoteReply With Quote
Old 05-13-2014, 02:08 PM #9
pickerdd pickerdd is offline
pickerdd is on a distinguished road
kmveter,
Thanks for posting this write up!
David
2008 4Runner V8 4WD Limited,
Galactic Gray/Stone Interior
Delivered 5/5/2008
pickerdd is offline   Reply With QuoteReply With Quote
Old 08-12-2014, 08:28 AM #10
ben550's Avatar
ben550 ben550 is offline
ben550 is on a distinguished road
ben550's Avatar
Another good write-up. I might used this to service calipers every once in a while rather than wait for them to seize up and replace...
Thanks.
'01 SR5 3.4 V6 4WD
'04 SR5 4.0 V6 2WD
'07 Tacoma 4.0 V6 4WD
'06 Sport 4.7 V8 4WD
'10 Limited 4.0 V6 4WD
ben550 is offline   Reply With QuoteReply With Quote
Old 08-12-2014, 04:05 PM #11
txclimber's Avatar
txclimber txclimber is offline
txclimber is on a distinguished road
txclimber's Avatar
Nice job. This is in my future.
2007 4runner SE V8 4WD: OME BP-51, SPC, Scion IM 2016+
2005 4runner SR5 V8 4WD: ICON Stage 1, Total Chaos UCA, Scion T1819 (SOLD )
1986 4Runner 4WD 22-RE: Full Rebuild, LCE Header, Custom Head, Supra AFM
txclimber is offline   Reply With QuoteReply With Quote
Old 01-09-2015, 05:47 PM #12
Kmvreter's Avatar
Kmvreter's Avatar
Found time for a short update to this thread due to my winter tire rotation.
I did my caliper check by extending and depressing the pistons (one set at a time multiplied by 4 sets.) It's only been since last spring but no stuck or dragging pistons yet.
I'll do another check and on-vehicle piston lube in the spring.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 01-17-2015, 10:47 AM #13
NuclearN8's Avatar
NuclearN8 NuclearN8 is offline
NuclearN8 is on a distinguished road
NuclearN8's Avatar
@Kmvreter thanks for posting this and for the update, I'll be doing this preventive maintenance this spring when I overhaul my brake system.
couple quick questions I have...
1) is everything needed for this rebuild included in this kit shown except the piston and permatex or toyota lube?
2) When you reinstalled the front calipers to the hard lines did you need to replace any seals at this connection? if so, are these in the kit above as well?
thanks again, nate
Current: 17' GX460 Luxury with DSP, Nightfall Mica / Black
Sold: 05' 4R Sport v6, 07 4R Limited v6
NuclearN8 is offline   Reply With QuoteReply With Quote
Old 01-18-2015, 11:31 AM #14
Kmvreter's Avatar
Kmvreter's Avatar
thanks again, nate
Answers:
1) Yes, that kit is everything needed (seals, boots, spring rings, bleeder covers) as shown above in picture 9 in post #5.
2) The brake line fitting screws back into the caliper without any replacement seal.
Keep us posted on your progress.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 01-18-2015, 11:47 AM #15
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
nice write up
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Seized Piston in Front Brake Caliper docfeelgood 4th Gen T4Rs 11 10-15-2022 10:16 PM
Brake Caliper Stuck? Kanger328 3rd gen T4Rs 4 10-07-2013 05:33 AM
Brake Caliper: Rebuild or Replace Jeremy03Sport 4th Gen T4Rs 16 09-21-2013 11:18 PM
front brake caliper piston seized...again! t4rmax 4th Gen T4Rs 10 06-27-2012 11:57 AM
one brake piston is stuck out 2WICE Maintenance/Detailing 3 06-05-2005 06:07 PM
