Old 03-05-2020, 10:52 AM #1
apache67 apache67 is offline
apache67 is on a distinguished road
Leather Cleaner/Conditioner?
Hi Peeps,
Can someone recommend a leather cleaner that actually penetrates/cleans this Toyota leather?
The ones I've tried just seem to slide off as if the material is Scotch-guarded or something.
TIA,
G
apache67 is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 11:40 AM #2
spartacus's Avatar
spartacus's Avatar
Originally Posted by apache67 View Post
Hi Peeps,
TIA,
G
So take this with a grain of salt I had sunscreen stains on the rear door leather inserts and I tried every thing on the market to clean it and then took it to a detailer to get the stains off. They basically said that all car leather in modern cars has a clear protective coat sealant and so to remove the hardened stain they will have to remove the door insert clean it dye it and reseal it which would cost about $150 so I passed. There advice clean the stain immidiately. If you let it sit it will be much harder to come out. I've been using meguires leather cleaner coditioner and once it dries the stain is still there. There might be a solution out there that I have yet to find.
Old 03-05-2020, 11:51 AM #3
Thumbs up
Gotcha, thanks for the info.
Old 03-08-2020, 10:10 PM #4
StaccySpeck StaccySpeck is offline
StaccySpeck is on a distinguished road
I am using ArmorAll Leather Care Gel, Its clear and soaks in. Looks great.
StaccySpeck is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 11:05 PM #5
Jdog's Avatar
Jdog Jdog is offline
Real Name: Josh
Jdog is on a distinguished road
Jdog's Avatar
Real Name: Josh
I have had pretty good luck with chemical guys leather cleaner and leather conditioner. The conditioner smells like fresh leather for a week or so and does not leave a greasy or shiny leather. my .02
2014 4runner trail-
Bilstein 5100/OME 3" lift-
Stealth customs stealth 6 wrapped in 285/70/r17 duratrac-
Cali Raised ditch lights-
RSG sliders
Jdog is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 10:53 PM #6
ran ran is offline
ran is on a distinguished road
ran ran is offline
I have used Lexol Leather conditioner on all the leather in the house. Boots and any shoes for the yard/garden.
_________
2007 SE V6 titanium
ran is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 10:17 PM #7
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Leatherique 2 part kit. Park in sun, apply step 1, or in shade with seat heaters on etc. Helps keep leather supple and prevents tearing also. After soaking in for a few hours apply the 2nd part.
Can also use neatsfoot oil but easy to overdo that.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 10:23 AM #8
jbtvt's Avatar
jbtvt's Avatar
Originally Posted by ronaldsh View Post
Currently, the best leather kit I have found on the market which isn't stupidly expensive is Dodo Juice Supernatural leather cleaner and sealant.
Of course, if you're leather is semi-aniline, its a different story but conditioners should NOT be used on modern leather. Read this for more info.
At $20/bottle according to Google, that stuff is even pricier than Leatherique. Link doesn't work, but modern leather definitely does need conditioning. Even coated non-aniline leathers will dry out and crack. Leather is tanned by one of several processes but all have been around for a long time. Chrome tanning since 1850, vegetable tanning for thousands of years, in one form or another. The only difference is the polyurethane coating, but that wears off eventually, and even if it doesn't the leather underneath it will get stiff and start to crack over time. Coating also does nothing to protect the stitched areas or keep them supple, which is where a lot of leather will split first.
Old 04-04-2020, 12:55 PM #9
Timc03 Timc03 is offline
Timc03 is on a distinguished road
I would recommend Adams Polishes leather cleaner and leather conditioner. I have been using their products since before i could start driving. and I will never go back to anything less than their products. It is local and i go hang up at the warehouse all the time. I help out there when I can. I promise you you will be beyond satisfied. They have a 110% satisfaction guarantee. If you are not happy with your purchase, they will refund you, AND 10%. They just released a leather ceramic coating that is pretty sweet. Here is everything you would need to clean, and condition. If you have any questions or need some more help feel free to PM me. I use every single one of their products and can help with anything you need!
Adam's Polishes Leather & Interior Cleaner | Interior Cleaning Product
Adam's Polishes Leather & Interior Conditioner | Car Interior Dressing
Adam's Cockpit Interior Cleaning Brush | Interior Cleaning | Leather Cleaner - Adam's Polishes
Adam's Polishes Edgeless Utility Microfiber Towel | Auto Detailing
Timc03 is offline   Reply With QuoteReply With Quote
Old 04-21-2020, 12:26 PM #10
power818 power818 is offline
power818 is on a distinguished road
I recommend Meguiar's Gold Class Leather Cleaner and the Leather Conditioner. I do detailing work on the side, and I have never had a seat that they didn't penetrate. If a seat is very dirty; however, I will clean it with a 1/5 dilution of SuperClean Degreaser before conditioning it. I do have a bias towards this conditioner though. It is what I used on my baseball gloves growing up, so the smell brings back memories of baseball season.
2019 Midnight Black SR5 4Runner - Black TRD Sema Wheels, Predator Tube Steps, Bilstein 5100 Shocks front and rear, 1.5" Daystar Rear Spacer with 2.5" of front lift, 285/70/17 BF Goodrich KO2's, Blackout Emblem Kit, Black Vinyl Wrapped Roof Rack, Black Chrome TRD Exhaust Tip, Lock'er Down Console Safe.
power818 is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 10:45 PM #11
Magnetnerd Magnetnerd is offline
Magnetnerd is on a distinguished road
Yup, this is true for most vehicles starting in the late 2000s to early 2010s. Leather conditioner actually won't do anything for the protected leather.
Sent from my Pixel 3 XL using Tapatalk
Magnetnerd is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 02:10 AM #12
truc.karl truc.karl is offline
truc.karl is on a distinguished road
Lexol and Leatherique are my go-to products.
truc.karl is offline   Reply With QuoteReply With Quote
Old 07-18-2020, 08:50 AM #13
bautistasamuel bautistasamuel is offline
bautistasamuel is on a distinguished road
Currently I am using Leather honey leather conditioner. I think it is good for leather seats because I used it 5 months earlier and still it is okay. It penetrates the leather's pores deeply. It it is non-solvent, non-toxic, non-sticky, odorless, and does not contain silicone. I think you can try it without any hesitation.
bautistasamuel is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 12:08 AM #14
I would recommend Adams Polishes Leather kit. You might need a stiff bristle brush to scrub the stain but this stuff is my go to(Adams sells the stiff bristle brush as well). I am a detailer and I use this stuff on every car. I cleaned a black seat that didn't look like it was dirty, but when I ended up wiping the headrest in a customers car, there was like blue dye that came off. Highly recommend
leather , material , scotch-guarded , slide , tia
Brake cleaner to cleaner IAC and TB? duffbeer911 3rd gen T4Rs 10 10-19-2015 06:00 PM
1Z einszett Klima-Cleaner - A/C Odor + Bacteria Cleaner? KAILUAZ Maintenance/Detailing 2 10-09-2011 03:32 PM
1Z einszett Klima-Cleaner - A/C Odor + Bacteria Cleaner? KAILUAZ 3rd gen T4Rs 6 09-17-2011 09:05 PM
FS (CT): Lexol leather cleaner + conditioner Apexi For Sale: Non-T4R Items 0 08-28-2011 09:37 PM
Lexol leather cleaner Thai Maintenance/Detailing 1 03-31-2003 02:50 PM
