Thread Tools Rating: Thread Rating: 8 votes, 4.00 average. Display Modes
Old 05-23-2017, 11:03 PM #136
JRapid's Avatar
JRapid JRapid is offline
JRapid is on a distinguished road
JRapid's Avatar
I did mine a few days ago because I was having some pretty bad clucking. So far so good. I used green grease like someone else mentioned. Here's a short clip pumping out the old stuff.
06 Limited V8 4x4 Shadow Mica
JRapid is offline   Reply With QuoteReply With Quote
Old 06-11-2017, 09:47 AM #137
eternalsoil eternalsoil is offline
eternalsoil is on a distinguished road
Going to try and do this tonight on our 2007 SE. Want to make sure I get the right grease.
Is this correct? http://m.oreillyauto.com/h5/r/oap/si...0412&ppt=C0139
I haven't been under to look but the two on the shaft is the part you DON'T want to overdo, right?
Sent from my SM-N920T using Tapatalk
eternalsoil is offline   Reply With QuoteReply With Quote
Old 07-16-2017, 02:04 PM #138
jmarsh8923 jmarsh8923 is offline
jmarsh8923 is on a distinguished road
Can someone re-up the pictures so I can locate all 6 of these.
jmarsh8923 is offline   Reply With QuoteReply With Quote
Old 07-16-2017, 06:10 PM #139
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
Photobucket is no longer allowing public pic sharing.
Eric the Car Guy has a series of videos maintaining an 04 4runner.
This one is for the drive line. Go the the last 10 mins for lubing the fittings.
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 10-24-2017, 06:24 AM #140
Flash Runner's Avatar
Flash Runner Flash Runner is offline
Real Name: Blake
Flash Runner is on a distinguished road
Real Name: Blake
I've had this "Clunk" issue since I first got it - and pardon my lack of automotive know how, I'm here and trying to improve - and honestly chalked it up to a rust issue. I accidentally came across this thread while reading another build thread - The time I've wasted in the middle of the night instead of studying HA!
Anyway down to this thread business - I'm going to attempt this later today after class/work and I'll post my results. My quick comments and questions from reading these 9 pages though:
People are arguing about pump count but one thing I noticed is that people are using different sized grease guns.... If this is relevant idk how it wasn't addressed before, and means pump count can be thrown out the window on this thread.
Also, I'm going to go with trying just a little the first go around - especially in the front - and see if that solves the problem. If not I guess I've got no choice then to just pump until I see the old stuff come out. I'm also planning on using just the one grease - Pink Mobil 1 stuff mentioned.
If anyone see's any errors in my statement, please correct me! As I'm here looking for advice. Thanks to everyone who has already contributed and will contribute after this.
edit: @ZebRuaj I saw this was in the maintenance section and was wondering how long it'd take for someone to notice this post - Hence I figured I'd @ somebody and you just had the most recent activity on it. Do you have any input for me? Thanks in advance!
22 SR5 Prem 4X4- Magnetic Gray
07 V8 Limited 4X4 - Natural White (SOLD)--> "Moby Dick" Build Thread
Flash Runner is offline   Reply With QuoteReply With Quote
Old 10-25-2017, 11:21 AM #141
ZebRuaj's Avatar
ZebRuaj's Avatar
I use Mobil 1 grease in my grease gun too. My applications were as follows:
Spider gears: 1st time ever - pumped until saw grease come out, pump a few more to get rid of any old grease, and then wipe it up so it doesn't sling everywhere while driving. Since then, I grease every few months, if not, every oil change. Pump til I see red start to squeeze out, call it good.
Slip yoke: Majority of the posts say to pump until you see it move, but don't over do it too as the grease has no where to go. If you extend the shaft too far, you're SOL. I've never seen mine move by pumping in grease. I just do a handful of pumps. If nothing moves, do one or two more, call it good. Redo every oil change or so.
Technically, you're suppose to use 2 different greases.
Molybdenum disulfide based chassis grease to the slip yokes and lithium grease for the spiders. I read somewhere its ok to use lithium where Moly is required, but not supposed to use Moly where lithium is needed .. so I just use lithium based grease on all of it (like a lot of other owners, shops probably too). No problems to report.
Good luck with your maintenance. Hope it helps with your driveline clunk.
Old 11-17-2017, 01:03 AM #142
wanderingandrew wanderingandrew is offline
wanderingandrew is on a distinguished road
Has anyone had luck in fully wiping off the excess after adding grease? My u-joints always throw some excess and the car smells like burnt grease no matter how much I clean.
I've even taken to wrapping aluminum foil around the exhaust and taking a drive to purge the majority of excess off, but that's only about a 90% solution.
2007 4Runner SR5 V8 7 Seats, Shrockworks front bumper, Warn VR10000 winch
wanderingandrew is offline   Reply With QuoteReply With Quote
Old 12-31-2017, 05:28 AM #143
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
You can use a small/thin screwdriver with a thin towel wrapped around the tip of it and clean it out. Time consuming but it works.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 04-28-2018, 04:41 PM #144
Jasonredwood's Avatar
Jasonredwood Jasonredwood is offline
Jasonredwood is on a distinguished road
I had grease come out of both slip joints after expanding.
Does that mean the seals are shot or something.
Clunk is gone now though. Seems much tighter.
Jason
1985 fj60
2006 4runner v8 4x4 sport
http://www.jasonredwoodart.com
Jasonredwood is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 09:35 PM #145
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
Thanks for all the info in this thread, did mine this evening and helped a lot!
awhitney1 is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 04:20 PM #146
RoyBell RoyBell is offline
RoyBell will become famous soon enough
Does anyone have updated pictures? I had the clunk so I greased the Front/Rear U joint as well as the front slip yoke. The slip yoke took a lot of grease before I saw any movement. The U joints took about 6 pumps before I saw the old stuff start to come out. Then another couple till I saw the new stuff. All noises are gone now.
Where are the other 3, on the front shaft? I didn't even look for more.
Just the Toyotas
'86 FJ60
'07 4R V8
RoyBell is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 06:29 PM #147
who done it who done it is offline
who done it is on a distinguished road
I know this is an old thread, but I finally got rid of the clunk so it might work for others.
Installed new rear control arms.
Upper control arms were left the same as stock.
Lower control arms were lengthened exactly 1/4'' from stock.
Clunk is completely gone, I used to get it really bad when hard braking or U-Turns on the fly. Truck does it just a bit, but its close to non-existent now. I know buying adjustable lowers is a stretch, but thats what helped me. Also truck is lifted 2.5'' in the rear on OME springs.
06 Curry Runner
who done it is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 02:40 PM #148
MrBunnyRunner's Avatar
MrBunnyRunner MrBunnyRunner is offline
MrBunnyRunner is on a distinguished road
Sorry if I missed it somewhere... Does anyone know the size of the zerks on the u-joint (it came out w/ a 7mm socket)? I have a damaged one (silly rocks in mud).
White 2007 T4R SR5 - Black VTec Raptors - Blacked out grill/ tail/ handles/ windows/ etc - Bilstein 5100 - Kenwood DMX7704S - Kicker CSC Speakers - 4300k HID kit (from XenonDepot)! - And still going...
MrBunnyRunner is offline   Reply With QuoteReply With Quote
ARB Front Bumper Request List Good Times Off-Roading 223 09-22-2006 05:28 PM
