Old 05-29-2020, 12:55 AM #1
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
misfire when first starting??
Hey guys and gals, quick question, to see if anyone has ideas or solution. I have a high mileage 4runner that mostly runs great. But when the engine is cold, it misfires for about 10 seconds. It will throw a code for cylinder 2 misfire detected, or sometimes, multiple cylinder misfires. I thought I had a sticky fuel injector, but that has been swapped out and did not fix it. I have swapped ignition coils and the problem does not follow the coils. Does not smoke, burn oil or coolant.
I reset the ECU codes and can drive for as long as I want and the problem will not return. I was wheeling the other day in the mountains of Colorado and had NO issues.
Once the engine is warm it will restart and not misfire, only when cold and only for about 10 seconds.
The only thing I could think of is maybe a wiring problem to the #2 coil?
I though maybe someone on here could help, thanks.
Jpilot is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 11:27 AM #2
Theginger91 Theginger91 is offline
Real Name: Elston
Theginger91 is on a distinguished road
Real Name: Elston
maybe look into some things that adjust parameters due to being hot or cold, like air temp sensor..
Theginger91 is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 07:30 PM #3
pelantire pelantire is offline
pelantire is on a distinguished road
Have you looked into the cold start injector?
pelantire is offline   Reply With QuoteReply With Quote
cylinder , misfire , problem , seconds , swapped
P0301 misfire, replaced "everything", still a misfire, but no CEL...what next? Heyduke 3rd gen T4Rs 7 06-25-2018 10:50 AM
Toyota Misfire And White Smoke On Cold Starting sa2017 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-26-2017 06:19 PM
misfire....help me think thru this... Bt08231 3rd gen T4Rs 20 09-22-2015 01:52 PM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
Misfire the_dingman Classic T4Rs 3 01-12-2010 05:09 PM
