Old 06-08-2020, 01:07 PM #16
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by royal T4R View Post
Great stuff.
I wanted minimal downtime and after reading a few posts about issues with Whiteline bushings I decided to get a bolt in SuperPro LCAs. They were $610 shipped but came preassembled. I’m sure this way is much cheaper.
I’m sure many that come after us will find this thread useful with the install.
Great work!
Thanks, I hear the SuperPros are super high quality. Working on the daily driver can be stressful, which is one of the reasons I decided to to this now. Working from home, I don't need to drive anywhere and could get food for a week if needed while the 4runner is down. Of course, this isn't viable for everyone.
It is going to cost less than high quality LCAs, but I paid with my time. Not including the cams, since I would need those regardless, I think I'm in about $220 and 12 hours for both. Not too far in raw cost from a pair of 1a auto or Moog LCAs haha. Mine are hopefully the worst case scenario coming from PA mostly, so the time could certainly be cut shorter for those in warmer areas or using a spray rust reformer instead of POR15
Originally Posted by JONBOY345 View Post
Awesome!
Saved it on the WayBack Machine for posterity: https://web.archive.org/web/20200608...-pictures.html
And thanks for using Imgur. I wish everyone used Imgur or similar. Photobucket has destroyed enthusiast forums with their greed.
Thats a great idea, thanks! I do like imgur and always got annoyed with the watermark on photobucket uploads. Only problem is that some work locations block Imgur.
Originally Posted by JuniorPigeon View Post
Now this is a proper write-up!
Appreciate it man, thanks!
y=mx+b is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 01:34 PM #17
y=mx+b's Avatar
y=mx+b's Avatar
Originally Posted by gimlithepirate View Post
Wow, this is an amazing write up. Great job! If I had a write up like this for every task I tackle, my wife wouldn't mentally double the amount of time I tell her it is going to take xD.
My question for everyone though is cost. Looking at good bushing, ball joints, etc. this is about 325$ in parts, plus your time. The Superpro LCA's that also help with camber (indirectly) are only 610. Not sure I can justify that cost difference.
Does underline how suspect something like the 1A Auto LCAs are though. They cost almost the same for the whole LCA as the price of the good bushings.... which is not a good sign for longevity.
Thanks haha I tried to be as detailed as possible! After researching, I still didn't find much to help me going in, so I wanted there to be some sort of documentation for others to know everything upfront.
The cost and time is definitely something to consider. For ball joints and bushings, I'm in about $220, and around $350 with the OEM alignment cams. For time, I have about 12 hours into completing both sides. This includes taking 350 pictures, mine being suuuper crusty, and meticulous surface prep. I ended up with better parts than Rock Auto ones, and it kept me from being bored on the weekends, so the time was worth it for me. Of course, the time justification will be different for everyone. The cut out and bolt in option of the SuperPros is certainly attractive.
Old 06-08-2020, 05:40 PM #18
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Oh yeah, the entertainment value is infinite right now xD.
12 hours given the condition of yours is actually pretty great. Can't fault you, and I've been in the position where 350 is much better than 610. The super pros come with alignment bolts and cams I believe, which are actually supposed to be pretty good.
I've got to do mine next time I do lots of things to the front end of mine. Not urgent, but will need to be done. Your instructions are very timely, as this process is not as bad as I was afraid. I might do a bushing repair, but keep my old cam bolts as they are in good shape. Just the bushings need some love.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 08:48 PM #19
y=mx+b's Avatar
y=mx+b's Avatar
Yep, I've been coming up with a long list of projects for a quarentined summer. I'm planning to strip and paint frame, replace cv thats beyond cooked to reboot, fuel tank straps, Dobinson's, new tires. Pretty much stock now, so it feels like the time to dive into off-road mods.
The process is definitely not that bad, and I'm jealous of you're not seized cams!
The time flew by, since I was having some fun and it was broken up of 2 weekends. I almost feel like the crusty-er the bushing sleeve, the easier it comes out. This is what was left of the super crusty one thats at the beginning of the bushing removal step looked like after needle scaling all the loose stuff, it practically fell out with some gentile prying. Kind of scary to think that thats what was keeping part of the suspension together
Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures) Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures)
Old 06-09-2020, 04:17 PM #20
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Nice job.
That rust is nasty.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 08:22 AM #21
y=mx+b's Avatar
y=mx+b's Avatar
Originally Posted by BackOff View Post
Nice job.
That rust is nasty.
Thanks! She is a tad crusty, but thankfully no frame holes. Thanks for the help on my question post from earlier, hope you can get your Whitelines installed sometime soon!
Old 06-10-2020, 02:59 PM #22
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Nicely done sir! You should get Senior Member status for this write up. Getting all those pictures with description in there with the right format isn't easy.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 08:14 PM #23
y=mx+b's Avatar
y=mx+b's Avatar
Thanks, that means a lot! I have learned so much from this forum, so this is a way I can give back to the community. Writing this up was also a good way to keep me busy and out of trouble, so that's an added bonus! I'm glad the level detail seems appropriate, I was worried that it was going to be information overload.
Old 06-10-2020, 08:29 PM #24
Real Name: Brett
Real Name: Brett
That's exactly what it's all about!! Pay it forward brother! Never too much info on a task this difficult either. I have learned a ton about vehicles in general on this forum, let alone the 3 different gens that I own. I've been wrenching as a hobby and money saving endeavor for 30+ years and I'm still learning on here every day.
@momo.75 this thread should be a sticky in the maintenance section, and maybe a Senior Member tag for @y=mx+b lol. This is one well thought out and meticulously done thread.
Old 06-10-2020, 08:55 PM #25
Real Name: Brett
Real Name: Brett
I've still got my OEMs, I might try this project soon.
Old 06-10-2020, 09:10 PM #26
y=mx+b's Avatar
y=mx+b's Avatar
That's awesome, I love reading this forum and absorbing every bit of knowledge that I can! I got into the wrenching recently to save money too, and I am really enjoying it. While working on the LCAs, it clicked in my head that 90% of jobs are bolt off/bolt on, which opened another world of possible projects for me to work on. I figure I will try to get some similar documentation out for most of my projects, extra information out there can't hurt.
I would be honored to have a 4th gen maintenance sticky, I'm game for anything that can help others easily find the information they need!
If you do, I want to see the pictures, post them up here! I think mine were original at 210k, but I'm honestly not sure. I have dealer records up to 150k that don't show anything with LCAs or suspension in general. I think I still might be on the original shocks, I dunno haha. Hopefully I'll be changing them out with Dobinson's in the future.
Old 06-11-2020, 10:47 AM #27
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
It is stuck! I did move it to the maintenance section. I still have my stock LCA's as well so I will be utilizing this thread as well. Thanks for all the documentation!
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 11:53 AM #28
Real Name: Brett
Real Name: Brett
Thanks Mo!! Pretty cool stuff.
Old 06-11-2020, 01:11 PM #29
y=mx+b's Avatar
y=mx+b's Avatar
Thanks for the sticky! Hopefully it is helpful when it comes time for you LCA bushings! I'll change over all my in-page linking so it doesn't redirect to the 4th gen section and then back to maintenance again.
Is there a collected thread of 4th gen specific maintenance anywhere? I'm planning on doing some more writeups for some maintenance items, maybe collecting some writeups is something I could work on?
Old 06-11-2020, 02:56 PM #30
momo.75's Avatar
Registered User
Real Name: Morris
Registered User
momo.75's Avatar
Real Name: Morris
I will look into having a sub thread of tutorial threads. thanks!
ball , bolts , lca , plate , step
3rd Gen Lower Control Arms w/ Whiteline Bushings 3rdGen4WD For Sale: T4R Items 1 11-12-2019 11:28 PM
Lower control arm bushing Duke562 5th gen T4Rs 2 10-12-2016 10:48 PM
Whiteline W53377A lower control arm bushings masphx 3rd gen T4Rs 15 12-22-2015 01:38 PM
Help Replacing Lower Control Arm Bushing bishop4r 5th gen T4Rs 4 01-31-2015 10:46 AM
Lower Control Arm Bushing Replacement Using Whiteline Bushings - Need Some Help danthemanx07 3rd gen T4Rs 12 12-22-2013 11:39 PM
