Old 08-26-2020, 10:09 PM #46
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
I just came across these 555 LBJs on ebay.
These are the ones i got from rockauto.
02-14 Toyota FJ Cruiser 4Runner Lexus GX470 Sankei 555 Lower Ball Joints Set | eBay
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 11:54 PM #47
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I have a question about the LCA removal/install that I havenÂ’t found an answer to on this forum or through a google search.
I also had to cut the front bushing sleeves on both sides (4 cuts) to remove my 16 year old frozen rusty LCAs. They both stuck out on the front and the rear. (No issues with either rear bushing.)
My new, aftermarket (Detroit Axle brand?) LCAs came with the two ball joints and four bushings installed.
I am reusing my OEM alignment adjusting bolts/cams(?).
The front adjusting bolts are smaller in diameter than the new bushing sleeves.
Question: Can I buy sleeves, to replace the sleeves that I cut, for the front bushings so the bolts that go through the bushings fit more snugly? Right now, I think the front bushings will move around when I am driving. When adjusting the LCAs, the nuts turn a little before the LCAs move.
I donÂ’t want to go get an alignment and have them say there is free play in the front bushings. Before I replaced the LCAs, an alignment couldnÂ’t be done because all the adjusters were frozen stuck with rust.
I bought some aftermarket adjusting bolts that are larger diameter than OEM, but I couldnÂ’t figure out how to adjust them. It was easy to adjust the OEM adjusters. I may re-install the aftermarket bolts in the front bushings and try to adjust them again. I think they fit snugly, but I donÂ’t remember how snugly.
Thanks in advance!
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 09:31 PM #48
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Thanks in advance!
Hey thanks for reaching out! Hopefully I can provide some insight that may lead you in the right direction. Sorry for the late response, since this thread is in a different section, its harder to monitor. Feel free to tag me directly if you need my attention quickly, should be able to copy this:
HTML Code:
[MENTION=429038]y=mx+b[/MENTION]
I had a similar issue where the Whiteline bushing sleeve IDs were slightly larger than the OEM alignment hardware, which had a little play that I was worried about. I made a thread on that and it can be seen here: Cam Bolts and Whiteline LCA Bushing Excessive Play Help. Here's a quote of the important stuff:
Originally Posted by y=mx+b View Post
Measurements:
I took measurements a bit after posting this, and the pictures can be found in post #14 linked here: https://www.toyota-4runner.org/3493028-post14.html
The OD of the rear cam bolt is a close to 13.5mm
The ID of the rear bushing sleeve is close to 14.5mm
The OD of the front cam bolt is a hair over 19mm
The ID of the front bushing sleeve is just about 20mm
Videos
rear bushing sleeve play: YouTube
front cam bolt and bushing sleeve play: YouTube
front bushing play: YouTube
front bushing play 2: YouTube
long story short, this amount of play is fine and just has a small gap so they're in constant contact all the time.
Is this similar to the issue you're having? Or is the play you have more than what I was experiencing? If you're able to take measurements with a caliper or something, that would be a great way to quantify the amount of play you're experiencing. Do you have pictures that you can upload of the old/reused Toyota hardware vs the new larger hardware?
I also saw you had a question mark by the Toyota hardware, is the hardware you have still good if you had to cut things out? This is a pic of all the necessary alignment hardware on the bottom row (+the whiteline bushings and tubes that you won't have to worry about) to confirm you have everything.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 02:05 AM #49
ads2539's Avatar
ads2539's Avatar
Thank you, I think you have the solution!
I think I just need two of the part in the photo below. My rear bushings are complete and good, and I have the bolts, the rear nuts and the rear cam adjusters for the front bushings. I am just missing the two front sleeve/cam combos. I didn’t realize they were one piece. I cut the sleeves, not realizing they were attached to the cams.
Do you have the part #? If not, I can probably find it online. I can’t read the part number in the photo. EDIT: I found the part number online: 48409-60020!
I will be so happy to finish this LCA installation!
Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures)-decfcae1-ac8f-4963-aab4-6543cb0c07e7-jpg
Old 10-24-2020, 02:44 AM #50
y=mx+b's Avatar
y=mx+b's Avatar
Looks like you got it all, thats great! Yeah theres like a million parts to the cams and they aren't the same front to back either haha. Was the play just as I had in the videos?
If you got pics and don't mind uploading, I'd love see! Its always satisfying to get a difficult project completed. Glad I could help, but seems like this one was all you!
Old 10-24-2020, 12:37 PM #51
ads2539's Avatar
ads2539's Avatar
I don’t have pics, but I can take some after my new sleeves arrive. It’s cold in Chicago now, and it might be a week before the parts arrive and I work on the LCAs again.
Without the sleeves, there is a lot more than 1mm of play (3mm?) between the bolts and the bushings. When I turn the cams, the LCAs don’t even move until the slack is used up. If I got an alignment done with the LCAs the way they are now, the alignment shop might say they can’t do it because of all the slack.
When the new sleeves arrive and I install them, everything should be back to factory specs.
Old 10-24-2020, 07:48 PM #52
y=mx+b's Avatar
y=mx+b's Avatar
Gotcha, makes since it was missing that entire piece. Hopefully everything goes smoothly once you get the parts in!
Old 11-29-2020, 06:08 PM #53
Honda pc Honda pc is offline
Honda pc is on a distinguished road
Thanks in advance!
let us know how that detroit LCA and bushings, ball joints last...It seems like easy way at low cost...but they don;t get good reviews and just plain are said to not last long at all..
I used white line bushings for LCA...and toyota oem for UCA bushings. so far its good ride and no problems...but its been less then 10k miles so far.
Anybody have consensus on how long these whiteline LCA bushings last or who's got the most miles on so far and results???? pro/cons
Honda pc is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 06:45 PM #54
ads2539's Avatar
ads2539's Avatar
I have a brother who is a mechanic. He said, “Only buy OEM. The Chinese crap only lasts a year or two.”
My parts are all still pretty new, so I can’t say (yet) how long they will last. Now with COVID, I’m only driving ~100 miles per month.
Old 11-29-2020, 08:13 PM #55
y=mx+b's Avatar
y=mx+b's Avatar
I haven't seen much follow up on the whitelines, which is one of the reasons I created this thread. They felt like decent quality, and I liked that the bushing IDs had some little channels to capture the grease inside them. I have about 4k miles on mine, which isn't a whole lot. I'm going to try and disassemble them this summer to give an update and inspection on how everything stood up over the year and hopefully 10kish miles. I'm also not driving a whole lot with the whole COVID situation, so mileage is not going up very fast.
Old 12-31-2020, 12:26 PM #56
MandAtaco's Avatar
MandAtaco MandAtaco is offline
MandAtaco is on a distinguished road
MandAtaco's Avatar
Just came across the thread while trying to find some info on the white line inner bushings. Getting ready to go through my wifes 04 4Runner with 210K miles on it!
Anyway, just wanted to say great write up! Thanks!
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
MandAtaco is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 11:27 PM #57
y=mx+b's Avatar
y=mx+b's Avatar
Thanks dude, I appreciate that! Let me know if you have any questions about the replacement before diving in or if you want to know more about anything. I unfortunately haven't been driving enough lately to put a bunch of miles on for a proper review, but everything has been satisfactory in the 4-5kish they've been on!
Old 07-11-2021, 07:01 PM #58
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
She’s a beaut Clark!!
Great post!
I’m chasing a squeak and just did left and right inner and outer tie rods. Doing the LBJs next. I have a pair of 555s I’m going to slap in soon.
Thanks again!!! Great work!
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 07-11-2021, 11:14 PM #59
y=mx+b's Avatar
y=mx+b's Avatar
Great post!
Thanks man! Hope its helpful and you're able to track down that squeak!
Old 10-26-2021, 01:07 PM #60
Cook County Cook County is offline
Cook County is on a distinguished road
Control arm refurb
Originally Posted by royal T4R View Post
Great stuff.
I wanted minimal downtime and after reading a few posts about issues with Whiteline bushings I decided to get a bolt in SuperPro LCAs. They were $610 shipped but came preassembled. I’m sure this way is much cheaper.
I’m sure many that come after us will find this thread useful with the install.
Great work!
How have the super pro lca’s held up? Price wise they are in the ball park with oem online.
Cook County is offline   Reply With QuoteReply With Quote
ball , bolts , lca , plate , step
3rd Gen Lower Control Arms w/ Whiteline Bushings 3rdGen4WD For Sale: T4R Items 1 11-12-2019 11:28 PM
Lower control arm bushing Duke562 5th gen T4Rs 2 10-12-2016 10:48 PM
Whiteline W53377A lower control arm bushings masphx 3rd gen T4Rs 15 12-22-2015 01:38 PM
Help Replacing Lower Control Arm Bushing bishop4r 5th gen T4Rs 4 01-31-2015 10:46 AM
Lower Control Arm Bushing Replacement Using Whiteline Bushings - Need Some Help danthemanx07 3rd gen T4Rs 12 12-22-2013 11:39 PM
