Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 02-06-2008, 07:16 PM #1
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
Front turn signal lens body replacement
I went to replace a burned out turn signal bulb. I noticed the housing was all fogged up and had a small pool of water inside it. I had something similar to this before due to the bulb connector not sealed in the housing but this time I noticed the lens was cracked right at the front edge, probably by a stone, looking at the chip. Finally got the replacement (U$34.91 at Partznet vs C$61.10 at the local stealer.) Luckily the fog light housing is OK because it would have cost U$294.21 to replace.
So here is the write-up on the install. I did this removal before and I think I found the details here somewhere but here is my version.
Removed the bulbs & wiring. Removed 3 bolts (10mm heads.) Released the 2 tabs on the radiator side of the fog light to free up the entire unit. The fog light and turn signal bodies are connected with a tab. Details of the locations will follow in the install pics.
Here is the new lens & body assembly (part # 81511-35401.)
Front turn signal lens body replacement-t4rfrpstrlens01-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 02-06-2008, 07:18 PM #2
Kmvreter's Avatar
Kmvreter's Avatar
Top view with the 2 housings side by side. Notice the tab connector between them.
Front turn signal lens body replacement-t4rfrpstrlens02-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-06-2008, 07:22 PM #3
Kmvreter's Avatar
Kmvreter's Avatar
Close up pic of the tab after sliding them together.
To disassemble these you have to pry the tab open with a screwdriver at the blue arrow to slide them apart. Be careful because you can easily crack the tab off the turn signal housing at the red arrow (I cracked it on the old one but I didn't care because the housing was junk anyway.)
Front turn signal lens body replacement-t4rfrpstrlens03-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-06-2008, 07:24 PM #4
Kmvreter's Avatar
Kmvreter's Avatar
Front shot of the 2 connected.
Front turn signal lens body replacement-t4rfrpstrlens04-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-06-2008, 07:26 PM #5
Kmvreter's Avatar
Kmvreter's Avatar
Side shot of the fog light housing. The blue arrows point to the tabs that interlock in the bumper holes and green arrow is the screw hole (see later pic.)
Front turn signal lens body replacement-t4rfrpstrlens05-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-06-2008, 07:29 PM #6
Kmvreter's Avatar
Kmvreter's Avatar
Rear shot. Again, green arrows point to the screw holes.
(Not related to this replacement, but I thought I would point out the fog light aim adjustment screw at the red arrow.)
Front turn signal lens body replacement-t4rfrpstrlens06-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-06-2008, 07:33 PM #7
Kmvreter's Avatar
Kmvreter's Avatar
The bumper cavity showing the interlocking tab hole locations (blue arrows) and the screw hole locations (green arrows.) Just slide the combined unit back into the hole and push in on the fog light edge to click the tabs back into place. Then install the 3 screws. Be careful not to overtighten these because they are just cutting threads into the plastic housing and strip very easy (I found out the hard way the last time I did this.)
Front turn signal lens body replacement-t4rfrpstrlens07-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-06-2008, 07:35 PM #8
Kmvreter's Avatar
Kmvreter's Avatar
Finally, here is my blatant post-whore shot of the finished replacement.
Front turn signal lens body replacement-t4rfrpstrlens08-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-07-2008, 12:33 AM #9
97hb's Avatar
97hb 97hb is offline
97hb is on a distinguished road
97hb's Avatar
Mine is also cracked, probably from some rocks on the highway. Looks good dude, will be replacing mine soon.
2017 Ram 3500 4X4 - The hauler.
2003 SR5 4X4 4Runner - 412K+ Off-road Toy.
1997 Civic SFWD 674hp 530tq - Because racecar.
97hb is offline   Reply With QuoteReply With Quote
Old 02-07-2008, 02:24 PM #10
ptung07's Avatar
ptung07 ptung07 is offline
ptung07 is on a distinguished road
ptung07's Avatar
Thanks for the write up! Unfortunately, my fog light is housing is the one that is fogged up and was shocked to see how expensive that replacement part is! I'll try to see if I can try it out and check the hosing for cracks. But thanks for letting us know how to do this!
ptung07 is offline   Reply With QuoteReply With Quote
Old 02-07-2008, 08:27 PM #11
Kmvreter's Avatar
Kmvreter's Avatar
Thanks guys. Glad to help.
Originally posted by ptung07
... Unfortunately, my fog light is housing is the one that is fogged up and was shocked to see how expensive that replacement part is!
Sorry to hear it's your fog lens. It's a steep price. Maybe you can pick one up or locate one through a bone yard.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-04-2017, 10:29 PM #12
Sheriff Sheriff is offline
Sheriff is on a distinguished road
Inexpensive alternative
I found them with 5 star reviews on Amazon for about $20 bucks. Also purchased new headlights from the same company for about $50 bucks OEM quality, exact drop in fit and just plain beautiful. Transformed my old but good looking 4 Runner.
Sheriff is offline   Reply With QuoteReply With Quote
Old 03-12-2017, 04:10 PM #13
cdoyle's Avatar
cdoyle cdoyle is offline
cdoyle is on a distinguished road
cdoyle's Avatar
Nevermind, Finally got them out.
just took some finagling to finally get them out.
Dumb way to have those in there
Check out my 2004 4Runner Audio upgrade.
cdoyle is offline   Reply With QuoteReply With Quote
Old 11-21-2020, 01:24 PM #14
jackal999 jackal999 is offline
jackal999 is on a distinguished road
Passenger housing won’t come out
How do you release the 2 tabs on the side of the fog light not connected to the turn signal? Because I’m having trouble figuring out how to get the passenger side out. There seems to be very little wiggle room to push them in.
jackal999 is offline   Reply With QuoteReply With Quote
Old 07-25-2022, 10:24 AM #15
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Come across any aftermarket assy for the turn signal?. Mine are beat too. Wish to replace them and perhaps spice things up
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Front turn signal bulb replacement Foxhaven 4th Gen T4Rs 17 04-03-2018 04:01 PM
Turn Signal apache 3rd gen T4Rs 15 10-24-2017 04:12 PM
front shock replacement farmer0_1 3rd gen T4Rs 25 02-23-2015 05:03 PM
Faulty Turn Signal Socket Bunyan Maintenance/Detailing 1 03-30-2010 11:40 AM
turn signal bublb replacement kmath3 Maintenance/Detailing 3 02-08-2004 12:25 AM
