Old 04-06-2021, 11:00 AM #1
CrazySte CrazySte is offline
CrazySte is on a distinguished road
Unhappy TRANSMISSION: Changed Fluid to A750F, now takes forever to Engage Overdrive
Hello Everyone,
i own a 2015 4Runner TRD-Pro, and as probably many dealers told you too, they say the A750F Transmission is sealed and never need a Fluid Change.
Well... Speaking with a Toyota Specialist he said it's better to do a change regardless unless you're OK to have the Transmission fail around 130-150k miles, otherwise you should change it every 65-70k.
My TRD-Pro has 80k, So i went to the Dealership and scheduled a Fluid Change;
they needed to have the Toyota Specialist in house to change the Fluid on this Sealed Transmission.
The specialist he said he WOULD NOT FLUSH, he raccomanded just changing the Fluid and cleaning out the pan... And so he did.
They kept the Car 2 days, and returned...
ALL PERFECT
I even had to tow a small alluminum Trailer the next Week, nothing major, but i kept it driving it is S4 to avoid going into Overdrive.
Despite the fact the Trailer is Superlight, and that i had only a Motorcycle on it, i could tell the Car was taking longer to engage 4th, she would rev up to 4k in 3rd Gear for a While before engaging 4th gear but... NO BIGGY.
I checked for leaks the next day, and it was perfect.
Following day we went on an Off Road Trail...
All great, still no leaks.
Then i left for a trip with the Company Car, so my wife used the Car going around town for the whole month, and the Car ran PERFECT.
HERE WE START TALKING ABOUT THE POSSIBLE ISSUE
A Month went by and we get to Easter WeekEnd when we took a trip with our 4Runner to go up the Mountain, about an hour and a half drive from Home, and during the drive on the Interstate, i noticed that she was taking a long long time before engaging 5th Gear, even at the bare min incline at 70-75mph, she would downshift to 4th and rev up to 3000rpm and stay there for quite a while revving revving and would not get back into 5th, not even when we leveled off, we had to go downhill to get back into 5th... And for the Overdrive the situation was the same.
I didn't feel any SLIP, although at some point, i had to overtake someone so i pushed up the speed, she downshifted to 3rd, and as she Engaged 4th, i didn't feel the usual "push" it was more of a soft engage of 4th, there might have been a slight run away with RPM's increasing by a couple of hundreds, but maybe it was been noticing things that weren't happening because i was starting to really pay close attention and paranoia might have been settling in.
The next day, it was pretty chilly (about 35-37degrees) we took a short drive with our 4R and the only way the Car would engage 5th or Overdrive, was if i was above 3500rpm in 4th, which means 70-75mph and i had to be going downhill.
The next day we went Off Roading, i had to go even in Low Gear for quite a while, we have a TRD-Pro and we like to use it.. and she worked PERFECTLY:
never had issues of any kind, as we finished the Trail, we drove back to the Hotel and it was a good 1hr on Interstate, and it felt to be driving normally again, as if the Offroading effort made it feel better, i felt like 5th and Overdrive were engaging better.
The next day we Drove Home, again on the interstate for about an hour and half, with Cruise set at 70-75mph, this time with warmer weather around 70degrees, but i still noticed that she took quite a while before Engaging 5th, once engaged, she holds it pretty good, even going up a slight inclide, but once she Downshifts to 4th, she needs to be back in a slight Downhill before 5th and Overdrive kicks in.
Unfortunately, the nature of my Work makes it so my Wife is the one that Drives this 4Runner 90% of the times, and she only Drives around town, so essentially she never gets to engage 5th, but i am starting to wonder.
DO I HAVE A PROBLEM?
When you drive it around town, at Speeds 50mph and beliw, you really can't tell the difference, it feels just normal, even as you accellerate hard to merge in traffic, so really... The only difference i notice is at highway speeds above 65 and so
Anyone else that experienced these types of issues after a Fluid Change or is it me being paranoid?
Thanks for any infos
HAVE A GREAT DAY
ADDITION
after about a Month, i decided to take it back to the Dealership to have it checked... they kept it 2 hours and said they did an Update to the ECM and it has been working great since then, which is 5 months ago.
It feels super smooth, even on downshifts, it is like new... i wonder what the update actually entailed though
CrazySte is offline   Reply With QuoteReply With Quote
Old 04-11-2021, 11:50 AM #2
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Your most likely problems are either incorrect fluid level or the wrong fluid.
Or both.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 04-18-2021, 07:16 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I would have the dealership check the fluid level, it has to be done by the shop manual properly and with their scan tool (Techstream), i.e. at the proper operating temperature, sounds like it not at the proper level to me.
Just an FYI even driving around town it will still shift into 5th, unless you never get above 30 to 40 MPH and unless you're under moderate acceleration which can cause it to downshift.
2004 Limited V8
Old 09-27-2021, 10:49 AM #4
Talking
So... after about a Month, my Wife stated that the car still felt rough,, and since i was back home from a Work Trip, i decided to to take it back to the Dealership to have it checked...
I explained very well all the symptoms and how they had not disappeared after a while as they initially expected... they kept it 2 hours and called back saying it was ready.
The guy didn't know exact details, but said they did an Update to the ECM that needed to be "recalibrated" with the new fluid.
As soon as we drove out of the dealer It feelt super smooth, even on downshifts, it is like new... i wonder what the update actually entailed though
Anyway, at this point it has been 5 months that we drive it like that, we did trips and off roading and it is perfect, i would be curious though in what the actual Software Update did the correct the previous issue.
Anyway
Glad she's OK again
Old 09-27-2021, 11:22 AM #5
spartacus's Avatar
spartacus spartacus is online now
spartacus's Avatar
They probably recalibrated the shift points.
spartacus is online now   Reply With QuoteReply With Quote
4th , 5th , car , fluid , overdrive
Should I have my transmission fluid changed/flushed? JoshuaHufford 4th Gen T4Rs 34 08-18-2018 01:38 PM
Transmission Fluid changed. progress4m Maintenance/Detailing 5 09-12-2011 10:59 PM
What actually happens to transmission fluid to cause it to need to be changed? Metzbower Maintenance/Detailing 6 04-24-2011 02:42 PM
never changed transmission fluid s1moore1s 4th Gen T4Rs 4 08-14-2010 08:12 PM
Who has changed their transmission fluid? nc211 4th Gen T4Rs 13 08-18-2008 10:47 AM
