Old 07-19-2007, 02:51 PM #1
Lee614 Lee614 is offline
Lee614 is an unknown quantity at this point
pics of 60k on NGK & Denso plugs (FYI)
Since no one has posted pics of plugs with 60k on them I figured you can see how they held up.
they look warn but ok. Denso looks less worn.
I think they do 3 & 3 so if you show up with a blown engine @ 50k and the stealership sees the 3 & 3 plugs they will know they are original and void your warranty. just my theory.
2003 4Runner V6 4x4 Sport w/ Nav & Cladding
2004 Corolla CE
Lee614 is offline   Reply With QuoteReply With Quote
Old 07-20-2007, 02:01 AM #2
Jacobzky's Avatar
Jacobzky Jacobzky is offline
Jacobzky is on a distinguished road
Jacobzky's Avatar
did u replaced them with the same brand plugs and 3 of each? How about a write up on how to change them plugs? for us newbies.
Jacobzky is offline   Reply With QuoteReply With Quote
Old 07-20-2007, 02:06 AM #3
Jacobzky's Avatar
Jacobzky's Avatar
nvm found them here at
http://www.toyota-4runner.org/showth...k&pagenumber=1
Old 07-20-2007, 06:57 AM #4
I got 6 Denso.
It can be a uncomfortable squeeze for larger hands on the driver side.
The pain (on the driver side) is disconnecting the wires from the individual coil packs.
be sure to get a 10" extension for your wrench plus you might use your 2" extension on the end of that one.
One helpful note is inside the spark plug socket is the rubber boot... to cut some rubber off... so it is shorter. This will keep the socket from disconnecting from the extension.
2004 Corolla CE
Old 07-30-2007, 10:00 PM #5
97hb's Avatar
97hb 97hb is offline
97hb is on a distinguished road
97hb's Avatar
Dang, those look good. Mine at 60k were worn down hard. See if I can get some pics of them. It was weird that half of them were denso and the other NGK. I put all NGK in for the replacements.
97hb is offline   Reply With QuoteReply With Quote
Old 08-03-2007, 08:25 AM #6
NCSCOTT's Avatar
NCSCOTT NCSCOTT is offline
NCSCOTT is on a distinguished road
NCSCOTT's Avatar
Here is a link I started over 2 years ago about the 3 Plugs on one side and 3 on the other.
http://www.toyota-4runner.org/showth...ight=ngk+denso
Do a search for "NGK Denso" and you will come up with 3 pages of threads.
04 4x2 Black SR5 V-6, Bilstein 5100s @ .85 w/ Moog 81088 springs 2.75" lift front, FJ Rear Springs, 265/70s, Scion T1807 HU w/ AUX input cable. 151K miles. 07/08/14 Traded-in.
08 4x4 Salsa Red SE V-6 Daystar 2.5/1.5", 265/70 Revo 2s, SpiderTrax. Traded-in on 09/14/11 W/55k miles for 08 Sequoia 5.7L
NCSCOTT is offline   Reply With QuoteReply With Quote
Antenna Plugs - pics? drbiii Engines / Suspension / Wheels / Tires / Audio / Accessories 4 10-28-2009 12:46 PM
3 NGK & 3 Denso Plugs from Factory??? NCSCOTT 4th Gen T4Rs 23 08-01-2009 01:59 AM
Replaced Spark Plugs W/ Pics!!! the_josh Maintenance/Detailing 34 02-27-2006 12:28 PM
denso or ngk iridium? eric_c806 Maintenance/Detailing 4 07-29-2005 07:55 AM
Denso Iridium Plugs seconds2none Maintenance/Detailing 0 07-25-2005 06:36 PM
