Old 12-24-2021, 09:01 PM #1
YOKBB YOKBB is offline
YOKBB is on a distinguished road
Oil change on '06 V6 takes less oil than manual states (4qt)
I have a 2006 V6 with 255k miles, and when I change the oil and filter it only takes about 4 quarts of fresh oil to fill it back up. The owners manual states it should take 5.8 quarts of fresh oil. Does this sound like sludge buildup? Should I be worried? It sounds like it's running well, the valves are a little noisy but I think that's normal.
YOKBB is offline   Reply With QuoteReply With Quote
Old 12-24-2021, 10:27 PM #2
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
I have a low mileage 2003 V6. Got it with 26K miles on it from family member.
I change my engine oil/filter. Always 5 qt. to top of the dipstick mark. 5.8qts. will overfill.
No idea why less than 5 qts.
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 12-25-2021, 10:30 PM #3
KarrotJuice KarrotJuice is offline
KarrotJuice is on a distinguished road
Are you sure it's the original dipstick?
KarrotJuice is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 02:20 PM #4
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
You either have the wrong dipstick or your car isn't level when you check it.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 09:52 AM #5
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
My 2004 takes less than 5.8q (about 5.5q) but not near yours 4q. I think your dipstick is giving you false readings for which they are notorious or not original part. I would be concerned underfilling the crankcase by nearly 2q.
<<<< is offline   Reply With QuoteReply With Quote
Old 03-22-2022, 11:20 AM #6
5.5 Quarts is exactly what it takes, not 5.8
If you have the correct dipstick, the car is level, and you read the dipstick correctly, then I'd look into the possibility of a large buildup of sludge from insufficient oil changes.
And if your valve operation is already noisy, that could confirm improper oil change intervals in the past or having it run 2 quarts low in the present.
change , fresh , manual , oil , quarts
Manual Transmission Fluid Change kjcprb 3rd gen T4Rs 41 12-14-2022 04:58 PM
how change seats Manual for electric ochoa1801 4th Gen T4Rs 4 04-19-2013 01:18 PM
Manual transmission won't hold what my book states land308 Classic T4Rs 4 09-24-2012 05:43 PM
Owner's manual says 5k or 6 months for oil change... Ilovesnow 4th Gen T4Rs 8 01-09-2011 01:57 AM
1999 T4R Manual Transmission oil change Twoods927 3rd gen T4Rs 6 10-06-2009 12:20 PM
