Old 05-23-2021, 10:51 PM #1
little_titan little_titan is offline
little_titan is on a distinguished road
Full Synthetic Gear Oil change interval
This will be my 3rd time doing this service on my 2008 T4R SR5 4x4. Every time i do this service I’m showing minimal fluid wear on my front diff, transfer case, and especially rear diff. For those wondering I am using Valvoline full-synthetic 75w-90 because it is cost effective and replaced my fluid every 30k.
I have been using my car for 100% normal drives and 0% for towing or off roading.
I have researched on the forums and had little to no luck.
My goal is to not be cheap and at the same time not waste money on changing gear oil too early.
For fully synthetic gear oils, what service mileage interval have you guys been comfortable with...35k? 40k? 45k?
And what gear oil did you use?
I’m thinking about using walmart brand super tech full synthetic for my next service since its made by Warren Oil.
Please share your experience, thank you!
little_titan is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 12:23 PM #2
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Normal driving and no towing should allow you to keep diff fluids for 60K.
<<<< is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 05:47 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I was using Valvoline too but last time (2 months ago) I splurged and went with Amsoil, front/rear/Tcase. Had no issues with Valvoline but decided to upgrade. Rear dif and Tcase are always clean at drain, 30K, but front dif is usually dark at least. I'd say for your service, which is same as mine, we're good for 60K interval easily.
I have about 300 miles on 4R since change and MPG monitor has settled at 18.0-18.3 for past two weeks, never done that before, all last summer stayed at 17.3.
Only other reason I could see for change is wheel alignment, which I did myself and fine-tuned toe.
Old 06-01-2021, 09:42 AM #4
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
i say every 50k after the 100k mark.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 12:46 PM #5
Swipter Swipter is offline
Swipter will become famous soon enough Swipter will become famous soon enough
Stupid question but does this include leaving the original fluid in for that time, if you don't tow or off road?
Swipter is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 11:27 AM #6
<<<<'s Avatar
<<<<'s Avatar
Yes, original fluid is just plain 75W-85 gear oil with LS (Limited Slip) additive and perfectly okay for 60K.
Old 06-02-2021, 11:33 AM #7
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I bought my '17 SR5 with 20k miles on it.
Changed the diffs and T-case at 30k, just for my personal baseline.
Will do again at every 50k or after water crossings from now on.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 03-15-2022, 11:41 AM #8
RunnerFanTenn RunnerFanTenn is offline
RunnerFanTenn is on a distinguished road
replace differential at 75k and drain and fill transmission at 100k on daughters and wife's 4runners. Pavement only, typical driving, very little towing. Use mobil 1 synthetic, valvoline synthetic in trans. Both trucks now over 250k, zero issues.
RunnerFanTenn is offline   Reply With QuoteReply With Quote
gear , oil , service , synthetic , time
synthetic oil change interval v8 moloss 4th Gen T4Rs 10 12-27-2014 05:32 PM
Oil change interval after switch to synthetic? 46runner 4th Gen T4Rs 12 11-07-2014 06:14 PM
synthetic oil change interval bokmeipai Maintenance/Detailing 16 08-16-2011 12:47 PM
5th Gen Oil Change Interval 10K miles with Synthetic 0W-20 GMZ 5th gen T4Rs 15 10-15-2009 10:29 PM
Synthetic Gear Oil Change Interval? TeryT Maintenance/Detailing 9 12-30-2008 01:00 PM
