Old 07-20-2021, 06:11 PM #1
Fareastplaza Fareastplaza is offline
Fareastplaza is on a distinguished road
Is there an full inspection guide for 4Runner?
Guys, I have 2010 4runner limited. Thanks to all my friends here I stop hopping by dealers since 2015 and did all required maintenance myself. My T4R is so far running well.
Now I'm planning my first road trip since the pandemic. I will put about 5000km on my T4R for this trip. I am wondering if there is a full inspection checklist or tech guide that can walk me through everything so I can be on the road confidently.
Fareastplaza is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 08:09 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is just really nice Bossman is just really nice Bossman is just really nice Bossman is just really nice Bossman is just really nice
Bossman's Avatar
You can check on the Toyota Canada website for the Maintenance Schedule.
Maintenance Schedule - Toyota Canada
Simply by the age of your vehicle, you could be looking at the following:
At 114 months:
Oil & Filter Service - Replace engine oil & filter.
Remove & inspect air filter element.
Lubricate locks, latches & hinges.
Inspect lights, horn & wipers for proper function.
Inspect coolant, brake & washer fluid levels.
Inspect tires & adjust pressure as required, including spare.
At 120 months:
Replace Super Long Life Coolant; Tighten Propeller Shaft Bolts; Lubricate Propeller Shaft; Brake Service;, Replace Cabin Air Filter; Replace engine oil & filter.
Remove & inspect engine air filter element.
Lubricate locks, latches, & hinges.
Confirm lights, horn & wipers function properly.
Check coolant, brake, transmission & washer fluid levels.
Perform battery service and comprehensive electrical charging system evaluation.
Inspect valve clearance (audibly).
Inspect drive belts for damage, adjust tension if required.
Check steering gear box, linkage and shock absorbers for looseness, damage or leakage.
Inspect ball joints and dust covers, driveshaft and steering rack boots, chassis nuts & bolts for looseness or damage.
Remove wheel and brake drum, check pad/shoe thickness. Examine brake calipers, wheel cylinders and brake lines.
Inspect fuel and exhaust systems for leaks or damage.
Examine tires for damage and wear, check & adjust pressure (rotate if required, additional charge).
Summer: Michelin Premier LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 08-03-2021, 01:46 AM #3
Sparky9000 Sparky9000 is offline
Sparky9000 is on a distinguished road
In the past I have used the certified pre-owned inspection checklist for pre-trip prep
Sparky9000 is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 01:14 PM #4
I always wonder about these " Tighten Propeller Shaft Bolts". Checked many times, I didn't see any possible why these bolts got loose. ��
Old 10-11-2021, 03:18 AM #5
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 is an unknown quantity at this point
Jakeepoo3's Avatar
The guide is to visually look and inspect everything and act accordingly.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
full , inspection , road , t4r , trip
3rd Gen 4Runner Buyer's Guide 4-Ripcord 3rd gen T4Rs 887 Yesterday 02:33 PM
08 4Runner 2WD prepurchase inspection cherishzm 4th Gen T4Rs 11 08-05-2017 08:45 AM
Full Replacement Guide for SR5 V8 with JBL (Just BLows) gshadow325 4th Gen T4Rs 24 11-21-2015 01:30 AM
Any full inspection for my warranty-expiring car? lyrebird Problems & Warranty Issues 4 03-19-2012 03:40 PM
4Runner buyers guide Turbo224 General Discussions 6 01-13-2011 12:50 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
