Old 08-27-2021, 12:22 PM #1
Fareastplaza Fareastplaza is offline
Fareastplaza is on a distinguished road
Can ATF WS used for power steering fluid?
Manual said Power Steering Fluid type is "Automatic Transmission Fluid DEXRON II or III".
I have few bottles of Toyota OEM ATF WS left. Can I use it for replacing/flashing my power steering fluid?
Fareastplaza is offline   Reply With QuoteReply With Quote
Old 08-27-2021, 12:27 PM #2
spartacus's Avatar
spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold
spartacus's Avatar
No. may leak past the seals at the rack and pinion.
Old 08-29-2021, 10:58 AM #3
<<<<'s Avatar
<<<< <<<< is offline
<<<< is a jewel in the rough <<<< is a jewel in the rough <<<< is a jewel in the rough
<<<<'s Avatar
Didn't you quote Toyota Manual for Dexron-lll? I don't see an issue. Is Toyota ATF Dexron-lll?
TRD 17x8.5 Wheels / Nitto RG 285/70/17 / Shrockworks Sliders / ASFIR Al Trans Skid / B&I CF Dash / TRD Stealth Shift / LED Floor Ambient Light / Prado Al Pedals / Ellis Precision Al Battery Holddown / Northstar AGM Battery/LED interior / ARB on-board Air / LC custom Engine Cover / CF GC Shelf / Fire Ext & MagLite
<<<< is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 08:38 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
The ATF used for 4th Gens (2004) and onward is WS fluid and is not the same as Dextron lll fluid (which wasn't used in earlier Toyota auto Transmissions), it is very clearly stated in your owner's manual and also on the power steering pump cap which fluid should be used for the power steering.
Don't try to over think it, just read and use what Toyota says to use!
Also worth stating DON'T use "power steering fluid" in Toyota power steering pumps because it also isn't Dextron lll !!!
2004 Limited V8
Old 09-17-2021, 12:32 PM #5
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
That should answer your question right there.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 03:22 AM #6
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 is an unknown quantity at this point
Jakeepoo3's Avatar
They are both hydraulic systems. Yes you can. I probably wouldn't mix different kinds though.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
atf , bottles , fluid , power , steering
Power steering fluid level low. Do I use ATF or power steering fluid? 4flyer 3rd gen T4Rs 63 02-24-2020 05:07 AM
Power steering fluid, or ATF? INDYMAC 5th gen T4Rs 32 02-13-2019 08:12 AM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
power steering fluid catrains 5th gen T4Rs 7 12-17-2016 05:09 PM
Which power steering fluid? Gryphon Classic T4Rs 2 12-04-2004 11:29 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
