Old 01-21-2022, 01:23 PM #1
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
NEW RADIATOR - Expansion/ relief cuts in core frame
Hey,
Just received my new radiator to swap into the rig. I noticed it has 2 "cuts" in the top and bottom aluminum frame. They don't look hacked in. They are equidistant from the sides, but each from the opposite side, so they are offset as you're looking at it from the front. And, they don't effect the fluid channels. It's a Denso I ordered from rock auto. I had read of people finding this before on parts ordered. A little searching found some info that they are not defects or damage, but relief cuts to allow for expansion and contraction with heating and cooling. Is this really a thing? It does make sense. My OEM doesn't have them as far as I can tell, and maybe it was the expansion and contraction that finally let to it's failure. It's got 264k on it, but I've been hunting a coolant leak and finally found it in the radiator when I pulled back the fan shroud, where it's been hiding for a while. Thx for any opinions.
**UPDATE** If you don't have dedicated radiator hose pliers, you might want to take out the old radiator with the lower hose attached, but disconnect at the thermostat housing (this is on a V6). Then transfer your hose to the new radiator so you can get the clamp on correctly. I tried to attach that stupid hose to the lower connection and I couldn't get the hose seated like I wanted, or get the clamp slid back on. I had to take it all back out and pull the lower hose off the thermostat. And those cuts aren't damage. They are totally fine
NEW RADIATOR - Expansion/ relief cuts in core frame-img_20220120_162241067~2-jpg
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 09:58 AM #2
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Save yourself trouble finding defect after install. Cap lower outlet and fill this radiator with distilled water on the bench. If that notch or any other area leaks - you know there is an issue before diving into the swap.
<<<< is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 01:10 PM #3
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
Originally Posted by bob3dsf View Post
Hey,
Just received my new radiator to swap into the rig. I noticed it has 2 "cuts" in the top and bottom aluminum frame.... A little searching found some info that they are not defects or damage, but relief cuts to allow for expansion and contraction with heating and cooling. Is this really a thing? It does make sense.
Sounds like they are accounting for the Thermal expansion coefficient of the material. Using Aluminum as an example I usually have to increase part size by 3-5% when casting to ensure that my final part is within tolerances when cooled. The previous unit may have accounted for the expansion in another way: Looser fit in the frame, expansion slots in the mounting at one or both ends, etc...
This is similar to accommodations needed for woodworking with solid woods. The reason bread board ends and sliding dovetails can't be glued full width when interfacing grain endgrain to long grain is that as the wood shrinks and grows with humidity and temp changes the trapped wide boards will tear the piece apart.
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 12:23 AM #4
bob3dsf's Avatar
Real Name: Bob
bob3dsf's Avatar
Real Name: Bob
Nice. I hadn't thought of that. You mean the where the lower radiator hose attaches?
Old 02-02-2022, 08:42 AM #5
<<<<'s Avatar
<<<<'s Avatar
Yep. Use some plastic bag and strong rubber band to cap that.
Old 02-15-2022, 01:32 AM #6
bob3dsf's Avatar
Real Name: Bob
bob3dsf's Avatar
Real Name: Bob
I did and confirmed no leaks. Thanks for the tip.
cuts , expansion , finally , ordered , radiator
Anyone know what's behind the OEM tape on frame near radiator? rageandlove 5th gen T4Rs 11 02-15-2022 11:51 AM
Need advice: Rotted radiator frame support DaveK22 4th Gen T4Rs 7 07-27-2021 10:41 AM
Los Angeles: 3rd gen front radiator body frame and hood latch s20004runner Free 2 01-10-2019 10:09 AM
A/C Expansion Valve Geolander Classic T4Rs 3 07-21-2011 06:09 PM
1995 4runner core support/radiator support bolted vs. welded into frame jlfindley74 Classic T4Rs 3 12-28-2010 05:59 PM
