Old 04-10-2022, 11:07 PM #1
slonny slonny is offline
slonny is on a distinguished road
Rusted break lines - How far should I take it?
Front hard break lines on my 2010 4Runner have rusted pretty badly. No damage to the break lines, but rust is pretty significant.
It looks like the long upper line that connects to triangular connector (Toyota calls it Union Way) is in good shape except for break line screw. Everything that is below connector has a lot of rust. If I mess up long break line screw, it will become a bigger job than I want to do.
Left and right upper front lines (47316 & 47314) are still in good shape, but there is a lot of corrosion on the screws. I will most likely need to use Groove Joint Pliers to get the screws off.
I was thinking of:
1) Cleaning upper break lines nicely and coating with POR15, and changing only the lower hard break line that goes from the break hose to the caliper.
2) Taking a more risky approach and using groove joint pliers to get small upper hard break line screw off of triangular connector, and then changing the entire assembly (small upper and lower hard break lines, and break hose).
How far do you guys think I should take it as far as changing hoses and lines?
slonny is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 08:20 AM #2
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You have some ugly crud going on. First I would scrape/wire brush all the loose stuff off, then if you decide to replace any lines give the fittings a good soaking with liquid wrench or similar for a few days before starting to remove/replace. Or clean up the area good, sand down the lines and coat as you mention.
Be sure and use brake line wrenches when you work on them.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
rdruss is online now   Reply With QuoteReply With Quote
Old 05-09-2022, 06:28 PM #3
BeansUnlimited BeansUnlimited is offline
BeansUnlimited is on a distinguished road
I discovered the same thing with my new (to me) '99 SR5. I was just going to slowly accumulate all the lines I want to replace and do at least most of them all at once because I want to bleed my system as few times as possible. Your lines look like they could use a little bit of sand paper and that should remove most of the rust. After that some paint would make them look good as new.
BeansUnlimited is offline   Reply With QuoteReply With Quote
break , hard , line , lines , upper
Rusted and leaking Lines. parts #? BigMike18 4th Gen T4Rs 5 10-26-2021 09:13 PM
Extended break lines? oneshot808 5th gen T4Rs 14 05-21-2021 11:41 AM
99 4runner- what are these leaking rusted lines? hawkcharmer 3rd gen T4Rs 8 07-11-2015 02:02 AM
Mysterious rusted line by brake lines! Help! lemonlyme Classic T4Rs 2 01-02-2015 06:57 PM
99 sr5 break line rusted out. stainless steel brake lines? Philbush1127 3rd gen T4Rs 1 01-27-2013 10:05 PM
