Old 11-07-2022, 09:57 AM #1
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Differential fluid weed sprayer pump
I had one of those Slippery Pete manual pumps that screws to a bottle but I got tired of having to clean and store it.
https://a.co/d/0H2Ct3j
I saw a post on FB and copied it, not my idea, just my execution
I bought a Flo-Master 1-Gallon Lawn and Garden Tank Sprayer, $10 https://a.co/d/gBGULns
Picked up some 3/8" ID Shark bite PEX (1/2" OD) at Lowes, $3
Picked up a 1/2" inline brass ball valve at Lowes, $10
Had some spare 3/8" PVC hose lying around
I drilled out the outlet of the weed sprayer to 1/2" and cut a section of the PEX and shoved it in, it was a tight fit
I used a small section of the 3/8 PVC as a junction between the PEX and the ball valve.
The delivery tube is the end of the Slippery Pete bc it has a nice fitting the stays in the diff, so it was repurposed.
You can pre-charge like a sprayer and open the valve or you can manually pump it like a regular jug-top pump.
I'll be using it this week and will revise my design/execution if necessary.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 11-10-2022, 09:45 AM #2
krole krole is offline
krole is on a distinguished road
Nice work. I just changed my diff fluids, wish I would've made one of these first. I like the nozzle that stays in the hole, wonder if something similar can be found without buying the Slippery Pete.
krole is offline   Reply With QuoteReply With Quote
Old 11-10-2022, 05:09 PM #3
I already had the Slippery Pete, but yeah
You could probably accomplish the same with a magnet affixed to the hose about an 1" back from the end
Old 11-12-2022, 11:26 AM #4
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
I use one of these. It is slow but once in 60K miles gets the job done:
<<<< is offline   Reply With QuoteReply With Quote
Old 11-12-2022, 08:33 PM #5
Drained and filled both diffs with Lucas 85W 140 today using the new sprayer. It was basically a dream come true. Easy peasy.
Sent from my Pixel 4 XL using Tapatalk
1/2 , pex , pump , sprayer , valve
Differential fluid transfer pump? Grug556 5th gen T4Rs 15 11-03-2022 12:56 PM
Whine coming from power steering pump + bubbles in the fluid NOT after fluid change Pyral 3rd gen T4Rs 14 03-19-2022 06:43 PM
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
brake fluid or differential fluid? RiverRat37 3rd gen T4Rs 11 09-27-2011 09:00 AM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
