5th Gen Alternator Harness Removal
Got the alternator undone, including the infamous rear bracket. Can't figure out how to remove the harness. I've removed the two 10mm bolts, but can't get the cover off the terminal, nor can I figure out how to pull the plug. Also there is a harness going down the outside back of the alternator thats' attached to a bracket. I assume that needs to be removed too.
