Old 05-04-2023, 10:44 PM #1
tylrdvs277's Avatar
tylrdvs277 tylrdvs277 is offline
tylrdvs277 is on a distinguished road
tylrdvs277's Avatar
New CV Axles boots leaking
Hello all,
About 5000 miles or so I rebooted my driver side CV axle with the Toyota 5th gen reboot kit. Recently those boots have started to leak on the axle sides. I assume there’s still plenty of grease in them since I put them on recently. What do you recommend? Redo the job? Just tighten the clamps? Clean the grease and see if it keeps leaking?
2008 4Runner V8 4WD Limited (Dobinsons 2.5 inch lift, JBA UCAs, 265/65r18 KO2s)
tylrdvs277 is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 11:24 PM #2
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
The kit come with the proper amount of grease to pack in the boots. Maybe overfilled and squeezing out making sharp turns.. yeah try tightening the clamps if you can without damaging the boot. Hopefully it's not overfilled It could tear the boot.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 05-05-2023, 12:13 AM #3
tylrdvs277's Avatar
tylrdvs277's Avatar
I am lifted too. Maybe that plus some full-lock turns cause some leaking?
Old 05-05-2023, 01:20 AM #4
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Yes, that's definitely a possibility. That lift would increase the axle angle unless you have a different drop. If not get one it's just a couple sleeves and bolts and will relieve the extra stress on them. Has the possible excess grease stopped squeezing out yet? You say leaking, I'm imagining squeeze out from over packing. If it's done squeezing out tighten the clamps up good. You should be good to go. Nothing is torn so you should be fine
Old 05-05-2023, 09:49 AM #5
tylrdvs277's Avatar
tylrdvs277's Avatar
I’ll wipe off what’s squeezed out and see
axle , boots , grease , leaking , recently
CV Axle boots for EXT travel CV axles Kwikvette 3rd gen T4Rs 0 08-28-2021 08:41 PM
Replace Axles with OEM Boots or Extended Boots Rock_Rat 3rd gen T4Rs 79 11-10-2020 06:44 PM
4th Gen OEM Axles, torn inner boots. Emperor_Po For Sale: T4R Items 0 04-02-2018 10:15 PM
Front Axles - CV Boots tdsmither 4th Gen T4Rs 6 12-12-2014 12:11 AM
CV Axles/Boots Azwelder Classic T4Rs 9 08-23-2012 08:08 AM
