Old 08-11-2021, 12:52 PM #1
Fareastplaza Fareastplaza is offline
Fareastplaza is on a distinguished road
Replace X-REAS suspension without removing X-REAS
My 2010 4runner limited front suspension struts start leaking. It is part of X-REAS. I am trying to find out if I can replace it myself. But google shows every single article is talking about replacing it with the standard strut and remove/abandon the X-REAS.
I understand people don't like it or it is too expensive/difficult to replace it while keeping X-REAS. But why nobody even tried? Or I didn't search correctly?
If you guys have any DIY information, could you please share it here?
Thanks,
Fareastplaza is offline   Reply With QuoteReply With Quote
Old 08-11-2021, 01:47 PM #2
Frasher4Runner's Avatar
Frasher4Runner Frasher4Runner is offline
Frasher4Runner is on a distinguished road
I'm a little confused about your question. Are you wanting to replace the front struts with new XREAS struts or replace them with standard struts but not have to remove the XREAS system?
Frasher4Runner is offline   Reply With QuoteReply With Quote
Old 08-11-2021, 01:57 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Xreas is a gas over hydraulic system so if you replace a shock that has leaked it has probably leaked out the gas which would need to be recharged. My xreas system had no gas in it when I replaced it with Bilsteins and I didn't even know it. The shocks are very pricey too, so going to a standard shock arrangement is much more cost effective and you lose no performance in my opinion.
Old 08-11-2021, 03:49 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Keeping my X-REAS
Fixing XREAS suspension
Toyota 4-Runner X-REAS Shocks - Shockwarehouse.com
https://www.shockwarehouse.com/news/...structions.pdf
Remove and reinstall XREAS front shocks
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 08-15-2021, 10:56 AM #5
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
I replaced both of my leaky X-Reas struts on 2004 Sports without any issues. If your leak is minimal and has not being leaking long you can replace just struts since these disconnect at check valve and keeps the rest of system sealed while you disconnect and reconnect. GL
<<<< is offline   Reply With QuoteReply With Quote
Old 08-24-2021, 05:24 PM #6
I think x-reas struts can only be OEM. So I checked with Toyota dealer today. They quote me $500 for one only. It is so pricy, even like you said reconnect may work, but 2 for $1000 and that's just parts.
Old 08-25-2021, 03:26 PM #7
<<<<'s Avatar
<<<<'s Avatar
Don't use local dealer unless they match national online Toyota parts retailers.
$ 273 on partznet.com
48510-80500 - Shock Absorber - 2010-2020 Toyota 4Runner | Conicelli Toyota of Conshohock
It is your call whether replace 2 front ones for about $600 both or get whole new 4 corner aftermarket system which easily will put you over $2000. I kept my and saved both money and XREAS.
Old 08-26-2021, 12:21 PM #8
Thanks. But are these shocks for X-REAS? The image doesn't look X-REAS compatible as it does have an extra connect point to the oil pipe. Or it is just sample image?
Old 08-26-2021, 05:02 PM #9
<<<<'s Avatar
<<<<'s Avatar
Just image, non XREAS struts sell for $128 on that site.
Old 08-26-2021, 05:04 PM #10
<<<<'s Avatar
<<<<'s Avatar
Also call them with your vin number to be 100% sure about correct part #
Old 08-27-2021, 04:34 PM #11
Also, to replace x-reas strut, do you need to lift the entire truck since they are cross-linked? Or you can lift one wheel at a time?
Old 08-28-2021, 01:18 PM #12
<<<<'s Avatar
<<<<'s Avatar
Just lift a corner you are working on. Only disconnect at check valves to prevent fluid loss.
Old 09-14-2021, 01:56 PM #13
Thanks for everyone's reply. My 4runner is 11 years old and 167k km on it already. Also in here, winter salt road also brings lots of rust on the bottom. I am now rethinking: Should I pay a premium price for X-REAS or simply switch to a normal strut system.
I guess the basic 4runner SR5 modules come without KDSS nor X-REAS (correct me if I am wrong). They are just normal suspension/struts. Who drove them still feels good enough on the highway and the inner city?
Old 09-14-2021, 02:55 PM #14
Humble Leader's Avatar
this is tough to answer because people have different driving styles and types of road traveled as well as different preferences
personally I think when XREAS is working it is great. the truck does feel great cornering, body roll is greatly reduced and it feels really good. off-road capabilities are not compromised. you will likely notice a difference in driving with standard suspension. more body roll and probably more nose dive when braking. maybe you're fine with this, maybe you're not. do you drive more spirited or are you a cruiser?
many opt for a bilstein set up when scrapping XREAS, some say it has a similar feel. I think if you do off-roading and don't want XREAS look at bilstein 5100
I have a limited with XREAS. I replaced all 4 corners earlier this year due to a misting absorber in the rear at 155k miles (I figured the rest were going to be on their way out eventually). I considered bilstein but they were all out everywhere and I didn't want to wait. go test drive an sr5 and see if you can feel the difference between a new sr5 and new limited with XREAS. if you replace XREAS you will basically have a brand new suspension
Old 01-28-2022, 09:24 AM #15
Deniseh Deniseh is offline
Deniseh is on a distinguished road
Replace leaking rear shock absorber without removing xreas suspension
I have a 2019 with 44,459 miles and was told shock in rear is leaking. I took pictures but everything I find people say get rid of it. I don’t want to, I love how my car drives. I only do street driving, and my husband wants to do the work themselves but can not find any pictures or videos showing how to replace shock only. Dealer would only Goto $2300 to replace front left and rear right! And extended Warranity won’t cover. I drove a srd before buying as a test drive, I could tell difference right away. Everyone says go with bielstein and fj cruiser stuff. I’m afraid it will not be the same. Spent to much money buying this car to have it not drive like it has been . I’m very frustrated and need help.
Deniseh is offline   Reply With QuoteReply With Quote
expensive/difficult , people , replace , suspension , x-reas
FSM Reference Files for Removing X-REAS Bluesky 07 4th Gen T4Rs 0 12-19-2018 10:55 AM
Removing X-REAS from a Limited RiDE 5th gen T4Rs 11 12-28-2016 04:19 PM
Any local shops in Phoenix area who can replace X-REAS for a decent price btruong25 4th Gen T4Rs 3 09-09-2015 11:39 AM
X-REAS Suspension ? Raiderdad General Discussions 12 09-07-2008 05:38 PM
X-Reas and Air Suspension Hawk 4th Gen T4Rs 12 01-12-2004 01:39 PM
