Real Name: Ron
Real Name: Ron
If I bought a 4Runner with 93K miles and had no record of past maintenance I would change out ALL the fluids myself: front/rear diffs, T-case, power steer, trans, brakes, coolant. The dealer would probably significantly overcharge you for this and probably not do a good job. Some I would do as successive drain/fills (Trans, power steer, coolant).
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
