Old 02-29-2024, 09:50 PM #1
Lawman Lawman is offline
Real Name: Billy Hearnsberger
Lawman is on a distinguished road
Maintenance question
Been years since I was here but taking new interest in my 2017 4 Runner. Got the oil changed yesterday and service advisor gave me list of needed maintenance items totalling $4400.00. It only has 93,000 miles so I feel like it's nearly new. Had my first in 2003 and put 164,000 miles on it with it never getting anything but oil changed. Traded it when I got the 2017 and it drives as good as the day I bought it.. I HATE the new technology on my 2022 F150 so much that I want to make this 4 Runner last forever. I will not do all the maintenance that was recommended (struts accounted for $3400.00 of that) but since I want to get 300,000 miles on this one I know I should probably plan to do quie a bit of preventative maintenance. My question is other than oil changes and air filter changes what are the most important items?
Lawman is offline   Reply With QuoteReply With Quote
Old 03-01-2024, 10:20 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
If I bought a 4Runner with 93K miles and had no record of past maintenance I would change out ALL the fluids myself: front/rear diffs, T-case, power steer, trans, brakes, coolant. The dealer would probably significantly overcharge you for this and probably not do a good job. Some I would do as successive drain/fills (Trans, power steer, coolant).
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 03-11-2024, 06:38 PM #3
BLKNBLU BLKNBLU is offline
BLKNBLU is on a distinguished road
I find it almost impossible that you need struts!!!
Look up a YouTube channel called "The Car Care Nut" and find an episode he has about Toyota struts and shocks and go from there. Good luck.
BLKNBLU is offline   Reply With QuoteReply With Quote
Old 05-06-2024, 11:19 PM #4
spartacus's Avatar
spartacus's Avatar
The dealers have to make money some how. Every time I am there they recommend something but I humbly decline.
Old 05-06-2024, 11:38 PM #5
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
I’d suggest checking your brakes and tires regularly. Proper rotation and alignment can make them last longer and work better.
Remember to change important fluids like transmission, differential, and power steering.
Also, periodic coolant flushes and checks of hoses, radiator, and water pump can help avoid any overheating issues and expensive fixes.
Inspect the condition of drive belts, including the serpentine belt, and replace them if they look worn or cracked. A busted belt can mess with things like the alternator or air conditioning.
And check your battery and its terminals regularly.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-07-2024, 08:44 AM #6
vermontmike vermontmike is offline
Real Name: Mike (duh)
vermontmike is on a distinguished road
they make plenty of money with their over-inflated, addendum added paper in the window.
2022 Super White Off Road Premium KDSS
vermontmike is offline   Reply With QuoteReply With Quote
Old 05-07-2024, 07:17 PM #7
3ToyGuy 3ToyGuy is offline
Real Name: Patrick
3ToyGuy is on a distinguished road
Real Name: Patrick
Something else: Check the plugs on a regular basis. They can tell you important information about how well the fuel/air mixture is being maintained, and if there's any problems with it.
They also wear down over time, and NEED replacement. ONLY use the recommended replacement plugs, not some expensive, iridium/platinum plug. Don't use anything made for European vehicles. They don't get along with the Japanese systems in our 4Runners.
They can also tell you that the coils and/or plug wires are encountering any problems, which is critical information for you.
Keep an eye on the brake fluid. The darker it gets, the more water it's absorbed, and the less well it will work. It should be replaced at most every 4-5 years, or when it's much darker than can be seen through. Be careful not to let the master cylinder suck air in during the bleeding process. Keep it full to the FULL line, as you bleed it down.
Check any and all the plastic parts in the engine compartment. Over time, they get brittle, and can disintegrate at a touch. Especially things like the hot water control valve.
Keep an eye on the high-current connectors. The alternator, starter, battery, and so forth. Keep the ground points clean and free of corrosion and contamination.
OK, OK, shutting up now...
Pat☺
3ToyGuy is offline   Reply With QuoteReply With Quote
items , maintenance , miles , oil , question
Question about 4WD monthly maintenance on an ORP dandingo13 5th gen T4Rs 7 12-21-2023 06:55 PM
Maintenance question calcrc 5th gen T4Rs 2 04-14-2019 12:11 PM
New 00 T4R LTD - priority maintenance question(s) DK327 3rd gen T4Rs 9 02-24-2016 01:30 PM
94 T4R Maintenance Question 92128 4Runner Classic T4Rs 9 08-04-2011 10:17 AM
Maintenance question KX316 Maintenance/Detailing 11 10-12-2004 07:06 PM
