Sparkplug, pcv valve, diff fluid front and rear, transfer case fluid, transmission fluid drain and fill. Replace coolant, brake fluid. check the drive belt, grease the drive shaft. Air filters engine and cabin. Check brake pads. I am of the opinion that trans fluid should be replaced on toyota trans even if has over 100k miles others will disagree. Good luck.
