Old 01-01-2025, 11:47 PM #1
sabom_matt's Avatar
sabom_matt sabom_matt is offline
sabom_matt is on a distinguished road
sabom_matt's Avatar
Air in system during PSF drain/fill
So I drained and filled the PSF on my 2018 for the first time (67k miles).
Should have been super easy by jacking up front end with tires barely off the ground, plugging the return intake, putting return drain line into a container, then moving steering wheel side to side with key in the on position.
What I did not expect was the staining on the plastic PSF reservoir making it look fuller than it was, causing me to drain too much and get air in the system. Drove around the block once as the issue became clear with whine and intermittent power steering loss; hope I didn’t damage the pump.
Drained again and added a 2nd 12oz container of Idemitsu making sure not to get any more air in. Improved the steering back to normal but still with some whine. I only had 2 containers. Ordered 3 more containers planning to drain/fill again until the whine is hopefully gone before driving it again.
Any advice? Did I damage the pump by driving around the block with air in the system? Next time I’ll know to go slower with the drainage to prevent air in the system.
Learned something today. Just hoping it wasn't learned the very hard way.
Happy new year.
sabom_matt is offline   Reply With QuoteReply With Quote
Old 01-02-2025, 09:30 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Probably no damage for the short drive time and fact that there was some fluid in the system.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 01-02-2025, 09:06 PM #3
sabom_matt's Avatar
sabom_matt's Avatar
Thanks for the reassurance. Drove around the bock 2 more times after work today, reservoir only dropped a few millimeters each time. Just filled back to the appropriate level each time, with no further drop and no whine after the 2nd time.
Glad I didn't make this mistake with my brake fluid drain lol
air , psf , steering , system , whine
To Drain & Fill or Not to Bmnorm2 5th gen T4Rs 26 12-24-2022 04:42 PM
Should i drain and fill? nathanroyse 3rd gen T4Rs 29 08-22-2020 04:19 AM
Coolant drain and fill. Block drain plugs. lj4r 4th Gen T4Rs 2 11-24-2018 07:11 PM
ATF Drain and Fill, 5th Gen leje0306 Maintenance/Detailing 0 10-02-2013 08:13 AM
Doh! '03 V6 4x4 drain and fill quadzillabill 4th Gen T4Rs 5 05-11-2008 07:24 AM
