Old 04-24-2004, 07:18 PM #1
msanta's Avatar
msanta msanta is offline
msanta is an unknown quantity at this point
msanta's Avatar
Changing Brake Pads on an 03' 4Runner
I would like to change my brake pads, particularly the front brakes, I just checked them and they need to be replaced soon. They look kind of complicated, not like my old 92' Camry. Have anyone replaced their brake pads or know where can I find information about doing so? : Do you really have to re-surface your rotors
every time you do your brakes?
A woman's mind is cleaner than a man's. She changes it more often.
-- Oliver Herford
03' 4Runner
Titanium Gray
SR5 All Time 4WD V8
Factory Sunroof
Double Deck Cargo Area/Cargo net
DRL 5 Speed Auto Trans
Jaos Center Protector R
Jaos Progreate Off Road Lights
Dueler REVOS
SilverStars
Volant CAI
WeatherTech Bug Deflector
WeatherTech Floor Liners/Wind Deflectors
msanta is offline   Reply With QuoteReply With Quote
Old 04-25-2004, 02:46 PM #2
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
How many miles do you have on them? It seems like front pads on an '03 shouldn't have worn out so soon! Might want to have the dealer check, see if you have a problem under warranty.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Old 04-25-2004, 04:08 PM #3
msanta's Avatar
msanta's Avatar
I have almost 20,000 miles. I got my 4Runner at the end of October 2002. I was wondering if it is because is a V8, the brakes would wear faster than the V6 due to the fact that it's a little heavier. I do get into a lot of stop and go traffic after work. It's the first time that I hear my brakes squeak a little, and they basically don't do it all the time.
-- Oliver Herford
03' 4Runner
Titanium Gray
SR5 All Time 4WD V8
Factory Sunroof
Dueler REVOS
SilverStars
Volant CAI
Old 04-25-2004, 08:49 PM #4
SteveM's Avatar
SteveM SteveM is offline
SteveM is an unknown quantity at this point
SteveM's Avatar
You should probably inspect the rear brake linings too. If they show little or no wear I would consider having a pro look at the braking system. It could be that something is preventing the rear brakes from actuating properly.
Can't help ya on the lining replacement as I haven't done mine yet (less than 10K miles). If it's like most other Toyotas, it should be pretty straightforward.
Rotors don't absolutely have to be turned at every pad replacement. If the rotors are scored or glazed, then they probably should be turned. If the brake pedal is pulsating now, or after the pad change, then the rotors will need to be turned.
On one of my old cars (a 1995 T-bird) I used to have the rotors turned at every other pad change.
Good luck!
=Steve=
2003 V-8 SR5 4x2 4Runner
2003 BMW 330i 6sp
1965 Mustang (in Bondo and pieces)
1998 Jayco Eagle10UD tent trailer
Surefire Aviator
I'm SteveM and I approve this post.
SteveM is offline   Reply With QuoteReply With Quote
Old 04-26-2004, 10:40 AM #5
msanta's Avatar
msanta's Avatar
The rear pads are fine, they show signs of wear, the front brakes were not completely worn out but the sensor was beginning to produce that annoying squeak. It also made sounds at certain speeds, not all the time. What's the normal wear in terms of mileage for the front pads? The rotors look fine too, they are no glazed. I saw some pictures of a 4Runner's installation and it looked easier, they only took out the pins and the pas came off right away. The only thing I was trying to figure out was how to push the caliper cylinders.
-- Oliver Herford
03' 4Runner
Titanium Gray
SR5 All Time 4WD V8
Factory Sunroof
Dueler REVOS
SilverStars
Volant CAI
Old 05-09-2004, 03:27 AM #6
EDGE EDGE is offline
EDGE is an unknown quantity at this point
With 15k on my truck my pads look new, you must be a heavy braker the front brakes have the same setup as 2nd and 3rd Gen 4Runners, cake to replace do a search on yotatech
EDGE is offline   Reply With QuoteReply With Quote
Old 05-09-2004, 03:48 AM #7
aj884runner aj884runner is offline
aj884runner is on a distinguished road
Easy to push pistons back. Crack the bleeder screw loose. Use a screw driver and wedge it in between the pad and rotor. You may have to use a hammer to get it initially started. Pry the pad back a little and let go. Push the screw driver in some more and repeat until pistons are back. Then use something to hold the pistons on the first side then do the other. After the new pads are in bleed the brakes a little bit and you are done. I reccommended bleeding the brakes to give it a little flushing. If there are any particles in the fluid it won`t screw up the ABS although this is highly unlikely to happen.
aj884runner is offline   Reply With QuoteReply With Quote
How long do your brake pads last? testrider Maintenance/Detailing 11 11-10-2009 02:41 AM
2004 4runner Brake Caliper ?? mac777daddy Maintenance/Detailing 7 02-26-2008 05:03 AM
03 4Runner Very Short Brake Life? pgibbons Problems & Warranty Issues 11 12-16-2005 09:57 PM
Dragging brakes can be hazardous on slippery roads Thai Maintenance/Detailing 0 02-06-2004 01:09 AM
Unsightly Brake Dust (and what you can do about it) Thai Maintenance/Detailing 0 01-16-2003 01:15 PM
