Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-20-2014, 10:10 AM #46
4RUNNER_2004 4RUNNER_2004 is offline
4RUNNER_2004 is on a distinguished road
Just replaced Transmission fluid the second time. Both followed official procedure. Two times I filled in about the same amount I drained out . so if you don't do temperature check and just fill in the same amount as it come out, would be fine as long as car at ambient temperature.
For those cars don't have overflow plug, what they do is just fill in the same amount they drain out, so why not 4ruuner?
4RUNNER_2004 is offline   Reply With QuoteReply With Quote
Old 11-10-2014, 02:42 AM #47
tucktuck8's Avatar
tucktuck8 tucktuck8 is offline
tucktuck8 is on a distinguished road
tucktuck8's Avatar
Quick question - I have a v8 sealed. So If I drop the pan and then run a line from the tranny cooler and start the car until the flow is trickling and then replace the same amount plus 1/4 quart then do the check would this be considered a full flush?
Also should I put the pan back on before I drain through the tranny cooler or leave it off?
2006 White 4Runner Sport V8 |Penelope's Build Thread|
tucktuck8 is offline   Reply With QuoteReply With Quote
Old 04-30-2015, 11:21 AM #48
JM2Runners's Avatar
JM2Runners JM2Runners is offline
JM2Runners is on a distinguished road
JM2Runners's Avatar
Check sealed auto-trans 09 V8 Limited
Hi all,
Stellar posts. Thanks for the help.
Finished my flush (non-pan drop method) and all is well.
Do I have to jump the DLP etc. or can i just warm up the trans-fluid and check overflow?
thanks,
01' SR5
09' Limited V8
JM2Runners is offline   Reply With QuoteReply With Quote
Old 05-22-2016, 10:02 AM #49
Annoyed's Avatar
Annoyed Annoyed is offline
Annoyed is on a distinguished road
Annoyed's Avatar
I realize, this is an older thread..
I've got an 06 4Runner, V6 engine with the WS type transmission.
I cannot add fluid to this at home; the process apparently requires the engine be running and warmed up to fill properly, and the fill plug is too close to exhaust / catalytic converter to be comfortable trying to fill while lying on my back underneath it.
I've recently acquired a boat that I will be towing with this. Total load roughly 3800 Lbs, boat and trailer. Call it 4000 with a full fuel load and such for the boat.
Common sense tells me that a tranny cooler would be a good idea.
I ordered a B&M B&M 70264 SuperCooler Automatic Transmission Cooler (14K & change BTU), listed as being suitable for my vehicle. inlet and outlets are both 3/8".
The cooler lines going to the factory cooler in the radiator appear to be significantly larger than 3/8", possibly 1/2". In addition to the inability to add fluid at home to make up for the expanded system capacity & spillage while doing the job, I am concerned with the smaller diameter lines restricting coolant flow.
I consulted the local dealer, to try to verify the real line size on that factory radiator/cooler, and to have them flush/fill (exchange?) the system after the job to get proper fluid level.
The dealer recommended that I not even bother putting the cooler on at all, as it is not needed. His logic is (and it makes sense) that the factory specs for the vehicle specify 5000 Lbs towing capacity as manufactured, and since I'm 20% under that, I shouldn't worry about it, just have the fluid exchanged. (almost 100K miles on the T4R)
In addition, Toyota apparently never offered a factory cooler or option package which included one for this vehicle, which is another indicator that an aftermarket cooler is not needed.
Anyone else's thoughts on this? If I don't have to add a cooler, I'd rather not have to add any more plumbing connections to the system since each one is a potential point of failure, as well as the hoses.
Thanks!
Annoyed
2006 4Runner 4x4 V-6 SR5 Driftwood Pearl.
2000 Tacoma 4x4 V-6 SR5 Ext. Cab TRD Sunfire Red Pearl. (R.I.P)
Poor Little Truck. Met the crusher at 51K miles, a victim of the Toyota frame rust buyback program.
Annoyed is offline   Reply With QuoteReply With Quote
Old 05-23-2016, 04:37 PM #50
oesterj1195 oesterj1195 is offline
oesterj1195 is on a distinguished road
Thanks!
I wouldn't worry about it since it already has a tranny cooler and is rated for 5000 lbs. I think that is boat weight though right. I think it's less if it's a trailer or something like that. Might verify that. Definitely get your fluid changed before you start towing and then regularly if you keep towing with it.
2005 SR5 V6 4WD
oesterj1195 is offline   Reply With QuoteReply With Quote
Old 05-24-2016, 01:04 PM #51
KaseyMcc's Avatar
KaseyMcc KaseyMcc is offline
KaseyMcc is on a distinguished road
KaseyMcc's Avatar
Originally Posted by JM2Runners View Post
Hi all,
thanks,
Sorry to call on some of you posting from two years ago, but I was hoping for a bit of insight. I'm looking to do a fluid replacement through the cooler lines but so far it looks like people just use the cooler line to evacuate the old fluid then refill through the fill plug on the transmission. Is it possible to evacuate through one line and refill through the other? If I understand correctly the top hose on the trans cooler will allow me to catch the old fluid coming out of the transmission, so would the bottom hose allow me to refill? Anyone tried this or something similar?
2004 SR5 4WD V8 , Titanium Silver, sunroof, HCF delete, K&N drop-in, Interior 6000K LED swap, map light mod, Denso Iridium TT 4702 spark plugs, Hankook DynaPro ATM tires, SilverStar Ultra lows/highs/fogs.
KaseyMcc is offline   Reply With QuoteReply With Quote
Old 06-03-2016, 06:07 PM #52
I have read a little bit on this and it doesn't seem to have enough suction to replace at the rate that you are dumping it out from the return line. It actually doesn't take that much time to pump it in each time. Kind of a pain. Just make sure you have the right line. I mixed them up and dumped quite a bit on my garage floor...doh! I also dropped the pan and replaced the filter inside, which might have been overkill, but my rig had 180k and I don't know if transmission fluid had ever been changed.
Also read up on getting your fluid level right. You do not want to screw up that one. Best of luck.
2005 SR5 V6 4WD
Old 06-26-2016, 02:07 PM #53
RichHawk RichHawk is offline
RichHawk is on a distinguished road
Talking Transmissions
I'm am very new to this site and am overwhelmed by the wealth of knowledge here. How do I determine if my transmission is "sealed" or "non-sealed? Also, can anyone recommend the very best Toyota 4Runner manual?
RichHawk is offline   Reply With QuoteReply With Quote
Old 06-26-2016, 07:01 PM #54
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
Basically, if you can't find a ATF dip stick, you have the "sealed" unit.
Search the service manual thread for the link. That's how I found the manual for my 07.
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 07-24-2016, 10:02 AM #55
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
with no dip stick to fill on these you will need to have 2 people . one in the cockpit the other at the tranny cooler line disconnected. using a marked container 1 qt amount mark run engine until @the 1 qt mark. shutdown engine . go under vehicle add 1 qt. repeat procedure until fluid looks good .
6-7qts should do it for a fluid exchange.
with no load on the tranny in park this is not going to cause any issues to the components. much easier with the dip stick used as the fill tube !
I have done this procedure and many others with the dip stick .
after it looks good then you will have to go and do the tranny temp fill procedure more time . then the gaskets to replace.
catrains is offline   Reply With QuoteReply With Quote
Old 08-02-2016, 02:17 PM #56
bunz559 bunz559 is offline
bunz559 is on a distinguished road
I had no idea there were sealed transmissions and that doing a tranny fluid flush was so tedious. Not that it's hard, but definitely much more steps to it than my previous Hondas and my current Subaru!
I am new and just picked up my 2003 V8 2 weeks ago. It has 181k on it and has an extensive record from 1 dealership its entire life. The last transmission fluid flush was done at 146K according to Carfax so I may be good for awhile. But started doing research to prepare for possible next DIY instead of taking it to the dealership.
bunz559 is offline   Reply With QuoteReply With Quote
Old 08-03-2016, 09:55 AM #57
since the dealership did a flush you should not worry about it . I would check the fluid condition/level though..
when a tranny has been cleaned up pan drop internal cleaning new screen and then a flush on a high mile vehicle there is most times less debris generated then a new tranny.
using a temp measuring device I have a couple measuring the pan .
in warm weather these are accurate . if it is low @110 deg F . shutdown engine let it cool down add 4 oz of fluid then repeat level procedure .
Old 11-10-2016, 08:47 AM #58
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
nice write up, just discovered my tranny is leaking from the cooler lines, will replace the cooler lines and drain and refill the tranny
T4R Transmission Fluid Servicing (sealed & non-sealed)-leaking-gear-oil-jpg
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 04-30-2017, 01:19 AM #59
jahmes143 jahmes143 is offline
jahmes143 is on a distinguished road
Hey all, about to change the tranny fluid on my sealed '04 V8. I'm going to do the "flush" method where you pull the hose off the tranny cooler.
My question is this...
Do you NEED to add fluid to the fill hole in the tranny, or, alternatively, can you add the fluid to the rubber hose you pulled from the tranny cooler? This would allow you to pump in the new fluid while standing up, rather than laying down under the vehicle.
'04 V8 Sport 4wd, Daystar Lift, 265/70R17
jahmes143 is offline   Reply With QuoteReply With Quote
Old 04-30-2017, 02:20 AM #60
Woz1976-MT's Avatar
Woz1976-MT Woz1976-MT is offline
Real Name: Steve
Woz1976-MT is on a distinguished road
Woz1976-MT's Avatar
Real Name: Steve
Yes, you can add fluid through the line that returns to the transmission. You will need some kind of pump. There are electric drill-powered pumps and an easy mod to a 1 gallon chemical sprayer.
Here is the very informative threat at Tacoma World (same transmission as our 4Runners):
https://www.tacomaworld.com/threads/...mission.68462/
Peruse through it until you find the links to the electric pump and sprayer methods.
Here's a YouTube video on how to make your own pressurized fluid pump from the chemical sprayer:
https://www.youtube.com/watch?v=VbNhswhnvuA
Just make sure you are measuring the fluid removed very accurately, and the consensus has been to add 1/2 to 1 quart extra in the end to make sure you don't have to try to put more in when you're doing the fluid level check.
- Steve
2016 Trail Edition | Classic Silver | KDSS | Entune with Nav | Factory Remote Start | TRD Pro Matte Black Wheels | Cooper Discoverer A/Tw LT265/70/17 Tires
Woz1976-MT is offline   Reply With QuoteReply With Quote
DIY: Non-Sealed Transmission Service for 4th Gen T4R's and Prior Mike the Wino Maintenance/Detailing 59 06-02-2021 11:35 AM
Changing WS transmission fluid in 2005 T4R Flyer 4th Gen T4Rs 39 12-29-2015 10:46 AM
Flushing Automatic Transmission Fluid gravitron Maintenance/Detailing 10 03-02-2011 10:52 PM
When to shift an automatic transmission manually Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 6 11-25-2003 01:18 AM
The Basics: Automatic Transmission Servicing Thai Maintenance/Detailing 0 03-24-2003 03:28 PM
