Old 06-04-2008, 03:21 PM #1
POPSRNR POPSRNR is offline
POPSRNR is an unknown quantity at this point
Question Disabling ignition and fuel pump
In order to conduct a compression test on my '06 V8 4Runner I need to disable the ignition and fuel pump. How is that best accomplished in this vehicle? TIA!
Larry
POPSRNR is offline   Reply With QuoteReply With Quote
Old 06-07-2008, 11:12 AM #2
96dcmss 96dcmss is offline
96dcmss is an unknown quantity at this point
should be a relay, or EFI fuse to disable fuel. Just unplug and remove the coils. You have to take the plugs out anyway.
2005 4Runner SR5 2WD, bone stock, hers
1996 Impala SS lightly modded, mine of course
1990 volvo 240, gets me where I'm going for little to no $$
http://memimage.cardomain.net/member...80_80_full.jpg
96dcmss is offline   Reply With QuoteReply With Quote
Old 06-07-2008, 11:25 AM #3
Thanks for the reply!
After posting, I remembered I had the shop manual in PDF format and in case anyone else has the same question, this is what the manual says:
10. INSPECT COMPRESSION
(a) Remove the V−bank cover sub−assy.
(b) Remove the air cleaner hose assy.
(c) Disconnect the throttle control motor connector.
(d) Remove the 8 ignition coils.
(e) Remove the 8 spark plugs.
(f) Disconnect the 8 injector connectors.
Removal of the EFI fuses, there are several, would probably accomplish the same thing.
No fuel pressure - 1989 4Runner 4x4 HKforte Problems & Warranty Issues 2 05-03-2011 01:27 PM
Understanding Octane Thai Maintenance/Detailing 17 05-21-2007 03:43 PM
Toyota TurboDiesels in USA Offroader 4th Gen T4Rs 16 10-19-2005 11:00 PM
