Old 07-06-2008, 07:05 AM #1
kimboy kimboy is offline
kimboy is on a distinguished road
Bleeding Brakes
I have a question. I used a pressureized system to bleed my brakes yesterday. Well, while bleeding the left rear, I had let too much fluid out and it got to the point where only air was coming out. I topped off the brake fluid reservoir and reblead the left rear until the brake fluid ran clear. Do you think there's any trapped air in the lines? Master Cylinder?
I bleed the left rear once again to make sure I got any visible air out and think its good. Much thanks if you can chime in.
kimboy is offline   Reply With QuoteReply With Quote
Old 07-06-2008, 12:36 PM #2
jharris2 jharris2 is offline
Super Moderator
jharris2 is on a distinguished road
Super Moderator
It would probably be a good idea to bleed the entire system again. It's very possible that there is still air in there because the reservoir ran dry.
2003 SR5 V6 4WD Titanium with cladding
jharris2 is offline   Reply With QuoteReply With Quote
Old 07-06-2008, 01:18 PM #3
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 07-06-2008, 05:47 PM #4
What's interesting is that the resivoir didn't run dry. There's still fluid around the min level. I was going back to check how the pressure was, when I heard the gurgling coming from the bleeder tube. I freaked out thinking all the fluid must have left the container but that didn't happen.
I'm thinking each line is independently hooked into the master cylinder and that refilling/re bleeding would push fresh fluid back out the valve being bled.
If this is true, there is no real order in which you should bleed your brakes.
Anyone else have experience with 4th gen brake systems?
WTF!!! Bleeding brakes!!! Impossible her-truck 4th Gen T4Rs 15 10-23-2018 03:04 PM
Tip for bleeding brakes (4th & 5th gen) Jed Maintenance/Detailing 9 04-08-2017 05:37 PM
Bleeding my brakes oa8888 Maintenance/Detailing 5 12-21-2009 08:15 PM
Bleeding brakes sciff5 4th Gen T4Rs 1 03-14-2009 06:46 PM
Disc vs. Drum Brakes Thai 3rd gen T4Rs 0 03-09-2006 01:33 AM
