Old 08-31-2008, 09:58 AM #1
greasefingers's Avatar
greasefingers greasefingers is offline
greasefingers is on a distinguished road
Spark Plug Time
I changed the ole plugs today. It went smooth and took about 45 to 60 minutes. It is scary removing plugs that have been in an engine so long (106,000 miles) Denzo SK20R11.
Some tips:
Remove the coil pack connector before removing the coil pack mounting bolt. This way you wiggle the connector off with some force. Depress the tab and use a large screwdriver to wiggle/wedge the connector off. The bolt size is 10 mm. I used a 5/8 inch deep well socket to remove the spark plugs. It is a spark plug socket so it has the rubber bootie inside it to retrieve the plug. The plugs are buried in the block, so a couple of socket extensions are needed.
The head is aluminum so in this case I would use a torque wrench! The torque is 13 ft-lbs or 156 in-lbs.
I had to remove the air filter and filter housing to get to the last two plugs.
I also took opportunity to spray the MAF (mass air flow) sensor with contact cleaner.
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
greasefingers is offline   Reply With QuoteReply With Quote
Old 08-31-2008, 11:09 AM #2
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
Re: Spark Plug Time
Some tips:
Did you use antiseize? I have read many times in this forum that it is a good idea.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 08-31-2008, 11:47 AM #3
Spark Plug Time for the V8
Yea I used a very small amount on each plug. It will completely burn away at those temperatures over 100,000 miles and since the threads are not the sealing device. But it makes it easier to install.
Old 09-04-2008, 06:38 PM #4
Blitzkrieg Blitzkrieg is offline
Real Name: Bob/Buckwheat
Blitzkrieg is on a distinguished road
I went ahead and replaced the wires while I was in there doing the plugs on mine.
Freeked out when I got home from the Toyota dealer having not really paid attention when the parts guy bagged the wires. Got home and realized they only gave me three wires not six.
LOL - a quick call to the dealer set me straight that the coil packs are shared and only one side of the motor has wires.
Bought the wires right after buying the truck without really looking too much so I didn't feel too bad.
"I speak three languages and liberal ain't one of them."
Blitzkrieg is offline   Reply With QuoteReply With Quote
Old 09-13-2008, 09:45 PM #5
2K3Runner 2K3Runner is offline
2K3Runner is an unknown quantity at this point
I use antisieze on all plugs that I change. I also use dielectric grease inside the coil boot and the connectors.
Pretty simple job to do, always best to do yourself so you know how to. When i show people how to do stuff like this, they're amazed on how simple it can be.
2003 Sport Edition Runner
V8, 4X4, K&N CAI and more....
Best Muscle Building System
http://034runner.nononsense.hop.clickbank.net/?tid=13579
2K3Runner is offline   Reply With QuoteReply With Quote
Spark plug blew out RonMAIDEN Problems & Warranty Issues 6 09-07-2012 03:50 PM
Spark plug hole stripped/coil melted MADMARTICUS 3rd gen T4Rs 13 10-02-2011 06:39 PM
Record time replacing spark plugs 2005 V6 4WD 4Runner SR5 tcpoob Maintenance/Detailing 5 03-16-2010 02:23 AM
Can you guys look at this spark plug? wsudu Maintenance/Detailing 8 02-15-2006 07:37 PM
Understanding Spark Plugs Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-20-2002 04:29 PM
