Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 07-13-2016, 10:10 PM #106
Karl540 Karl540 is offline
Karl540 is on a distinguished road
Hello,
Ok i have all those issues except my lights stay on all the time now and i have a total loss of top end power, i mean a total loss of power. When i hammer down the gas it wont drop down and take off. It is a 2006 sport V8. I hope someone can help me with this. Dealership says its going to cost me $1800 just for parts, says there is some kind of service bulletin for this problem.
Karl540 is offline   Reply With QuoteReply With Quote
Old 07-30-2016, 08:30 PM #107
hooker520 hooker520 is offline
hooker520 is on a distinguished road
VSC TRAC and TRAC OFF, No CEL
I finally took my 2001 4Runner to the dealer to help diagnose the "VSC TRAC" and "TRAC OFF" indicating lights for $95. The dealer said it was giving a C1207 code - the Park/Neutral indication was not being received but they were not sure why. On the schematics, the Park indication that goes to the instrument cluster and also goes to the VSC module. The VSC module triggers the "VSC TRAC" and the "TRAC OFF" indications. I informed the shop that the "P" for Park indication bulb was not working and was probably burned out for a couple of months. I also informed them that this is about the same time period that these indicating lamps became active. So I had the "P" lamp replaced on the instrument cluster for another $50 (labor). The code C1207 was gone and the "VSC TRAC" and "TRAC OFF" indicating lights went out. I can not believe a burned out bulb in the instrument cluster for "P" (Park) caused the "VSC TRAC" and "TRAC OFF" to be disabled. I guess that is why they are called idiot lights because you have be a genius to figure out the problem.
hooker520 is offline   Reply With QuoteReply With Quote
Old 11-21-2016, 11:03 PM #108
xtremegirl4life xtremegirl4life is offline
xtremegirl4life is on a distinguished road
VSC Lights on after replacing dashboard lights
My daughter has a 2002 4Runner SR5. I swapped out the halogen lights in the dashboard/instrument panel for led lights. Since then the VSC OFF and VSC TRAC lights turn on after the vehicle starts moving and stays on. I checked the gas cap, just in case, but this is not the issue. When taking apart the panels to get to the instrument panel, I did disconnect the plug that goes to the VSC button on the lower left next to the lights dimmer. Not sure if this has something to do with it or not. From all of the forums I have read, I think my problem is that this now needs to be reset and is truly not a mechanical issue that is causing this. I found a DIY option for 4th generation 4Runners with the 4th and 13th pins to perform zero calibration and was curious if anyone knows if this would also work for 3rd generation 4Runners. Also open to any other suggestions as to how to possibly clear this without having to pay to take it to the dealership or mechanic.
xtremegirl4life is offline   Reply With QuoteReply With Quote
Old 11-28-2016, 09:50 AM #109
Soundwave628 Soundwave628 is offline
Soundwave628 is on a distinguished road
New owner here. I just purchased a 2001 Limited with 104k that had these lights as well as a noise right behind the steering wheel. Ended up being the ABS master cylinder booster? And an abs wheel speed sensor. It's all good now! Was more expensive than I thought it would be but so far I'm only into the truck for $5500 including tax,title and buffing the paint back to life. Hoping to learn some stuff from this site. I'm already eyeing a new radiator lol
Soundwave628 is offline   Reply With QuoteReply With Quote
Old 11-29-2016, 04:53 AM #110
CHenry CHenry is offline
CHenry is on a distinguished road
Light on after dead batt
I had my battery go all the way dead .Had the batt changed and now my 2lights are on . Been on 4 months now. It went off for a few days but, came back on . I'm gonna try getting another gas cap and, trying to reset the computer. Wish me luck !
CHenry is offline   Reply With QuoteReply With Quote
Old 12-21-2016, 01:42 PM #111
jrobs1983 jrobs1983 is offline
jrobs1983 is on a distinguished road
catalytic converter
So my mechanic looked at the codes for my 07 SR5, told me it was o2 sensor, but it had caused the cat converter to become clogged. I haven't noticed a loss in performance, but my gas mileage isn't as efficient as it should be either. So he suggests a new cat con along with the sensor to be replaced. Now I know mechanics salivate over replacing cat cons whether they are needed or not, sooo is this $1200 repair really necessary, or do I need a new mechanic?
jrobs1983 is offline   Reply With QuoteReply With Quote
Old 12-22-2016, 01:59 AM #112
4runner55 4runner55 is offline
4runner55 is on a distinguished road
Go to Auto Zone or another auto parts store, have them read the codes if they haven't been deleted and get a second opinion. I'd try to find a good Toyota independent shop. Good luck.
4runner55 is offline   Reply With QuoteReply With Quote
Old 12-25-2016, 09:30 PM #113
Talking UPDATE - VSC Lights on after replacing dashboard lights
When changing out for LED lights, I had also replaced the P, R, N, D, 2, L lights. When I changed the P light back to halogen, it fixed my problem!
Old 01-24-2017, 04:37 PM #114
c wilber c wilber is offline
c wilber is on a distinguished road
check engine VSC off
First time followed owner manual and took to Toyota for service, ended up paying about $100 for a gas cap. 2nd time 40,000 miles later went to auto parts store and purchased a gas cap for $14.00, disconnected battery to delete codes, problem solved.
c wilber is offline   Reply With QuoteReply With Quote
Old 02-11-2017, 05:44 PM #115
Kendybear Kendybear is offline
Kendybear is on a distinguished road
Question New
I am having a similar situation with my 2003 limited 4Runner except instead of the check engine light i have the Maintenance, and the ABS light on along with the VSC TRAC & TRAC OFF lights. I had filled my tires 2 weeks ago but today the tire pressure in one of my tires was about 7 pounds to low and the lights came on after i filled the tire to match the others. My friend said it could be the drastic change in weather this week with the tire but i'm not sure. I had my back rotors and all four brake pads changed over summer but the past week the brakes were squealing at certain points of pressure but has now stopped when the lights came on. I've had an appointment to take my truck in the have one of the door locks fixed next week but i'm not sure if i should take it tomorrow for a full inspection, my last inspection was 5 years ago. Im a 21 year old girl, i'm pretty good with how things work and have read my manual keeping up with maintenance myself but i'm kinda at a lose here.
Kendybear is offline   Reply With QuoteReply With Quote
Old 11-25-2017, 02:28 PM #116
russman1963 russman1963 is offline
russman1963 is on a distinguished road
I just had mine show CEL, VSC and VSC OFF with coder P0441, O0442 and P0446. All codes related to the Evap system.
Found the gas cap loose, tightened it, cleared the codes. No problem now. I'm glad I didn't waste time at the dealer.
Russ
2003 4Runner LTD V8
russman1963 is offline   Reply With QuoteReply With Quote
Old 12-05-2017, 10:06 PM #117
ran ran is offline
ran is on a distinguished road
ran ran is offline
It is starting to drop in the high 20's now, will probably lose it again.
___________________________________
2007 SE V6 Titanium
ran is offline   Reply With QuoteReply With Quote
Old 11-27-2018, 09:02 PM #118
TRDpro4R TRDpro4R is offline
TRDpro4R will become famous soon enough
Had this problem and resolved it.
Gas cap. I had already checked to make sure it was tightened but still had lights. On closer inspection, the rubber O ring had cracked. Replaced it with an OEM Toyota (~$20 on amazon) and all lights cleared.
Check your gas caps carefully.
Check engine light, VSC TRAC & TRAC OFF lights-img_5855-jpg  Check engine light, VSC TRAC & TRAC OFF lights-img_5857-jpg
2016 TRD Pro white, Bilstein 6112 and Eibach Pro-kit 1" rear springs w/ TRD shocks on rear, Camburg ball joint UCA’s, SSS front bumper with light bar, Gobi Stealth Rack No Rise, BFG KO2 275/70/17
TRDpro4R is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 10:52 AM #119
Tacotom Tacotom is offline
Tacotom is on a distinguished road
Originally Posted by KNOBmeister View Post
Mine's still on ......... almost a month and still both lights are still on
Gas Cap is tight ......
Mine is a 04 4Runner .......
Suggestions?
Joe
Hey I am having the same problem. I have an 04 sr5 2wd with all three lights on. I just had the rear diff regeared with lower ratio and when I got it back those lights were on. They weren’t on before that.
I’ve tried disconnecting the battery for 15 min and they went off for a while but came back on. I tried taking the battery wires loose and touching them together for 30min to clear the ecm but the same result...
Have you found any other answers? It’s hard for me to accept that I all the sudden need to replace some part that wasn’t an issue before.
Tacotom is offline   Reply With QuoteReply With Quote
Old 11-14-2023, 08:57 AM #120
Tin Ark Tin Ark is offline
Tin Ark is on a distinguished road
Had same problem with my 09. I checked the gas cap and retightened it and lights we were back to normal 👍
Tin Ark is offline   Reply With QuoteReply With Quote
One cause & fix for "VSC TRAC" & "VSC OFF" lights, Zero Point Calibration MicaBlue03 Problems & Warranty Issues 299 06-05-2023 01:23 PM
Check Engine + VSC OFF + VSC Traction lights all came on?! Bamboozler 3rd gen T4Rs 6 01-24-2017 04:40 PM
Check Engine Light Won't Stop Reappearing At High Speed!! kabhunt 3rd gen T4Rs 15 12-13-2010 01:34 PM
Intermittent Check engine light??? 4RunnerSC Classic T4Rs 5 01-12-2009 11:49 PM
Check Engine & VSC Lights Come on; now off Mtneer001 4th Gen T4Rs 5 11-12-2007 11:43 AM
