Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 07-31-2009, 01:52 PM #16
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
Originally Posted by CJ3Flyr View Post
DAMMIT!
X2
It was a great post. We recently did a major software upgrade and many posts got clipped. I don't know if Mike's around anymore but I'll try to rebuild this over the next day or two...
I just PM'd him, and I loved the old system cause you could see when their last time online was, but this new one doesn't. I really hope he's still around, or that this is recoverable.
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 07-31-2009, 02:51 PM #17
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
Originally Posted by simple View Post
X2
I used my 'Super Moderator' powers to look at his info. I was able to see an email. I emailed him and I saw he was last on late 08
Mike did email me back. He's looking for pics etc from his old computer. Hopefully he'll be able to put something back on the first part of this thread.
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 08-07-2009, 08:02 PM #18
corsair944 corsair944 is offline
corsair944 is an unknown quantity at this point
Does anyone have the torque specs for the tranny pan?
2004 V6 4spd
corsair944 is offline   Reply With QuoteReply With Quote
Old 08-07-2009, 10:38 PM #19
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
2004 V6 4spd
20lb-f for the drain plug, 65in lb-f for the pan bolts from the 2003 FSM for the A340 (both the 2wd and 4wd versions).
Old 08-08-2009, 03:23 PM #20
Thanks Chris,
Do u fly a CJ3?
I drive a Be40 & CL601
Old 09-21-2009, 01:10 PM #21
alp alp is offline
alp is on a distinguished road
alp alp is offline
I wonder if the Mike's DIY writeup has been recovered?
alp is offline   Reply With QuoteReply With Quote
Old 09-22-2009, 09:03 AM #22
alp alp is offline
alp alp is offline
Originally Posted by JB. View Post
Doubtful anyone will believe I have any character flaws , but I do have one: I am a
However, this flaw comes in handy from time to time.
In the next post is Mike's excellent writeup, re-created as faithfully as possible.
Thanks JB! You are the Man!
Old 10-11-2009, 10:10 AM #23
johnnyd2723's Avatar
johnnyd2723 johnnyd2723 is offline
johnnyd2723 is on a distinguished road
Nice write up. I'm signing off and headed outside for my tranny service.
Thanks again.
John
97 Limited
10 SR5
05 F150 Lariat
69 Chevelle
johnnyd2723 is offline   Reply With QuoteReply With Quote
Old 10-13-2009, 09:49 AM #24
fishin fishin is offline
fishin is on a distinguished road
2wd
Does this apply to an 05 2wd drive also?
fishin is offline   Reply With QuoteReply With Quote
Old 10-13-2009, 11:17 AM #25
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
Yes but you need to read the Sticky at the top Maint section for transmission servicing. The fill and level check procedure is a bit different for the '05 but the rest applies.
Old 03-18-2010, 10:05 AM #26
sparkoneus sparkoneus is offline
sparkoneus is on a distinguished road
Comments
Since I had found Mike's write up on the tranny service, I thought I would share my experience with that service, which I performed over the weekend. First of all, his write up is basically very accurate and I executed his steps almost exactly (except for the beer part). But I ran into a couple of issues, only one of which was a bit difficult. I will say right off that I am very handy. I've done plenty of auto work over the years and lots of home improvement as well.
1) I put a big plastic tarp underneath the car to catch any fluid that came out and missed the drain pan for some reason. Trust me, there was some.
2) Dropping the tranny pan - This turned out to be rather difficult. Granted, my 4runner is a 2000 and it is now 10 years old (60K miles), but that gasket sealer between the pan and the tranny case wansn't easy to get thru. After removing all of the bolts, I had to resort to using a putty knife (I know, not the best thing) and a hammer. It took me a while to get all the way around 2 edges of the pan (drivers side & rear). I couldn't really get to either the front edge or the passenger side edge due to obstructions (frame, etc). So then I just kept working and bending the knife until I got it free. This took some patience. Do not use a screw driver for this or you might bend the pan at the gasket line. I looked over the case to be sure there was not marring/scarring, and it was fine.
3) The bolt holding the upper section of the dipstick tube is 12mm and angled down slightly. It took me forever to figure this out since you can't see the bolt, you just have to feel for it. It doesn't matter how much light you have, the view is completely obstructed. This irritated me, so hopefully having this information will prevent you from becoming irritated. I had to use a step stool to actually be able to reach in there and get that bolt off. Geez...
4) Once I had the pan off, I could not get it clear of the frame (WTF?). I saw in Mike's picture that he cleared it, but I have no idea how he did it. I had to move it all the way to the side (driver's side), remove the filter/screen, to allow enough clearance to then free the pan from the frame. Not too big of a deal, but noteworthy nonetheless. Maybe Mike's 2002 allows enough clearance for this without removing the screen, but not on my 2000.
5) Patience is required in grinding all of the gasket sealer off the pan and tranny case.
6) My strong advice would be to get the gasket lined up on the pan and push all of the screws into the gasket from below the pan while the pan is still off the truck. You will never get this done from underneath...don't ask me how I know this. I used a Beck Arnley filter/gasket kit which has a rubber gasket. It worked out very well since the rubber gasket holds those bolts very snugly and they won't fall out. I also did use Loctite 242 thread lock for the bolts according to Toyota. Probably doesn't matter much, I just did it to be safe. I have never known anyone to actually do this, including a very reputable local transmission shop.
7) I know that the torque spec on the pan bolts is 65 ft-lbs or so (maybe 69), but I was not comfortable with that much torque. When I got to 40, I could see the gasket getting crushed in there, so I actually stopped shy of 40. I have checked it over the course of a few days for leaks and nothing so far. I am thinking that the spec is based on having the permatex style sealer rather than a gasket. Maybe I am wrong and should go to 65, but that just seemed like way to much for me.
8) I now know what Mike was referring to with filling the dipstick tube slowly. It's not that the funnel will fill up and slowly go down. While this is true, it's not really the issue. The issue is that the new fluid will seep out of the seam between the upper and lower sections of the dipstick tube. I discovered this when I found a small puddle of new fluid under the truck after filling. Since you have to break the seal between the upper and lower sections of the tube, fluid will leak from there during the fill process, unless you pour REALLY slowly. This would take forever, so just put a pan under there and fill as fast as the funnel will take it. You won't lose that much new fluid.
All in all, Mike's directions were dead on. This took me a lot longer than 2 hours though, but I took my time to make sure I didn't mess anything up since I am a perfectionist. Probably took me more like 3 1/2 hours total, including cleanup. Two other things...check the fluid over the course of a day or two. Mine appeared full for the first several miles, but after 10 miles, it dropped a bit. Lastly, I did this with only jacking up the front driver's side. I didn't even have the tire all the way off the ground to fit under there with a creeper, but I'm a thin guy. As always, I used a jack stand...don't do this with just a jack.
Hope this helps.
sparkoneus is offline   Reply With QuoteReply With Quote
Old 03-18-2010, 11:33 PM #27
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
1) I put a big plastic tarp underneath the car to catch any fluid that came out and missed the drain pan for some reason. Trust me, there was some. Awesome tip
2) Dropping the tranny pan - This turned out to be rather difficult. Granted, my 4runner is a 2000 and it is now 10 years old (60K miles), but that gasket sealer between the pan and the tranny case wansn't easy to get thru. After removing all of the bolts, I had to resort to using a putty knife (I know, not the best thing) and a hammer. It took me a while to get all the way around 2 edges of the pan (drivers side & rear). I couldn't really get to either the front edge or the passenger side edge due to obstructions (frame, etc). So then I just kept working and bending the knife until I got it free. This took some patience. Do not use a screw driver for this or you might bend the pan at the gasket line. I looked over the case to be sure there was not marring/scarring, and it was fine. Makes sense... Mikes write-up was based on a 1st year 4th gen (03). Maybe that explains some of the differences.
4) Once I had the pan off, I could not get it clear of the frame (WTF?). I saw in Mike's picture that he cleared it, but I have no idea how he did it. I had to move it all the way to the side (driver's side), remove the filter/screen, to allow enough clearance to then free the pan from the frame. Not too big of a deal, but noteworthy nonetheless. Maybe Mike's 2002 2003allows enough clearance for this without removing the screen, but not on my 2000.
7) I know that the torque spec on the pan bolts is 65 ft-lbs ????? or so (maybe 69), but I was not comfortable with that much torque. When I got to 40, I could see the gasket getting crushed in there, so I actually stopped shy of 40. I have checked it over the course of a few days for leaks and nothing so far. I am thinking that the spec is based on having the permatex style sealer rather than a gasket. Maybe I am wrong and should go to 65, but that just seemed like way to much for me.
Hope this helps.
Great info! Thanks for taking the time to type it out. Mike has an '03 which probably changes things a bit. the other thing is 65ft/lbs???? Maybe in/lbs???? 65 is WAY too much for pan bolts...
Very helpful, great write-up, thank-you
Old 03-22-2010, 10:00 AM #28
Hey there...I just double checked the specs on those pan bolts and you are correct...65 in-lbs, NOT ft-lbs. Very important distiction and thanks for that clarity. I would say that I probably have mine too tight though I know I was nowhere near 65 ft-lbs, but I only used a short 3/8 socket wrench with an extension, so I think I am probably ok. I checked it again over this past weekend and no leaks, so I'm not touching it. It's probably a good thing for me that the Beck Arnley kit came with a rubber gasket.
The other thing I noticed was Mike's picture of the dipstick tube from above the hood. The bolt on his is easily visible from above...not so on the 2000. Just another one of those slight differences.
Old 06-07-2010, 12:29 AM #29
kylebacc kylebacc is offline
kylebacc is on a distinguished road
Safe to assume this will be about the same for the 5-speed tranny?
Kyle
2006 GX470 Sport
kylebacc is offline   Reply With QuoteReply With Quote
Old 06-07-2010, 07:08 AM #30
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
Yes, very similar! Read this post/response. http://www.toyota-4runner.org/570946-post2.html It'll help with which line to pull. The rest of Mike's procedure will be virtually identical even though his is a V6/4sp.
DIY Mods: Post Write-ups HERE AlphaQup General Discussions 73 02-23-2016 11:52 AM
