Toyo dealership for the fluid. They'll know if one or two gallons is correct.
I would drain and run a couple of times. Distilled water is so cheap and if you have nasty water I'd buy some. Study the Toyo antifreeze carefully. If it's not pre-mixed you'll need some distilled water for mixing. EDIT: Just read my own post The new Toyo fluid will be pre-mixed. The grocery store has it.
This may help: [i]COOLANT REPLACEMENT
1. DRAIN ENGINE COOLANT
CAUTION: To avoid the danger of being burned, do not remove
the radiator cap while the engine and radiator are
still hot. Thermal expansion will cause hot engine
coolant and steam to blow out from the radiator.
(a) Remove the radiator cap.
(b) Remove the service hole cover from the engine
under cover No. 1.
(c) Install a vinyl hose onto the drain on the radiator
side.
(d) Fix the vinyl hose with tape.
(e) Loosen the 3 drain plugs on the engine and radiator,
and drain the coolant.
(f) Drain the coolant from the reservoir tank.
(g) Tighten the 3 drain plugs.
Torque: 13 N*m (130 kgf*cm, 9 ft.*lbf) for the
engine
(h) Remove the vinyl hose from the radiator.
2. ADD ENGINE COOLANT
(a) Slowly fill the system with engine coolant.
Capacity:
12.3 liters (13.0 US qts, 10.8 lmp. qts)
HINT:
