Thread Tools Rating: Thread Rating: 16 votes, 4.94 average. Display Modes
Old 10-23-2017, 05:49 AM #316
DayDaysTech DayDaysTech is offline
DayDaysTech is on a distinguished road
Originally Posted by WOLVERINE View Post
Keeping in mind that mine is a 2004 Sport V8 4wd that I use as a daily driver, for the front and rear axles I use 75w90, Redline has both options, for limited slip with friction modifiers and one without additional friction modifiers - I believe you want to use the standard - Amazon sells by the quart and gallon, Redline 75W-90NS is the standard without additional friction modifiers. It is a bit pricey, but it is quality lube.
If you are towing frequently, may want to stick with the 80w-90 (Hypoid gear oil API GL-5) or whatever is recommended in the manual for hotter temp. zones, SAE 90 I believe. *See Manual*
price is no matter, this car is my moms and is a daily and she also doesnt tow
DayDaysTech is offline   Reply With QuoteReply With Quote
Old 10-26-2017, 02:05 PM #317
ivopivo ivopivo is offline
ivopivo is on a distinguished road
Check my post on page 15 of this thread, #214 I believe, you can use a hammer and chisel/drilling bit chisel as pictured to get it off....plenty of penetrating fluid helps.. make sure it is penetrating lube.
Took some work and a few rounds of banging on it after spraying PB blaster, but it’s out and new fill plug, drain plug and oil is in. thanks for the help.
ivopivo is offline   Reply With QuoteReply With Quote
Old 10-26-2017, 02:35 PM #318
WOLVERINE's Avatar
WOLVERINE WOLVERINE is offline
WOLVERINE is on a distinguished road
WOLVERINE's Avatar
Thumbs up
Glad you made it work, anytime.
New Daily Driver - 2006 4runner Limited Galactic Grey V8 4x4 -291K miles and counting - STOCK Driveline - New Audio Setup.
2007 Lexus GX470 - Stock, 56K miles - Sold
2004 Black Sport V8 4x4 - Made Limited- 141k miles Sold
2003 Grey Sport V8 4x4 - Sold - 1st 2UZ owned
WOLVERINE is offline   Reply With QuoteReply With Quote
Old 12-01-2017, 04:08 PM #319
brisamh's Avatar
brisamh brisamh is offline
brisamh is on a distinguished road
brisamh's Avatar
All gens?
Looks like your on a 4th gen? Will the instructions be identical for a 3rd?
brisamh is offline   Reply With QuoteReply With Quote
Old 12-13-2017, 12:52 PM #320
Folsom4Rnr's Avatar
Folsom4Rnr Folsom4Rnr is offline
Real Name: Brian
Folsom4Rnr will become famous soon enough
Folsom4Rnr's Avatar
Real Name: Brian
Just did the drain and fill (first time doing it myself). Great write up OP - made it super easy to do.
2006 Limited V8 in Titanium Metallic
Build and misc. adventure thread
Folsom4Rnr is offline   Reply With QuoteReply With Quote
Old 12-14-2017, 09:39 AM #321
Schamattack Schamattack is offline
Schamattack is on a distinguished road
Just followed this myself. One question though. I have 105K on my 07 and the fluids came out crystal clear. I assume the previous owner had done a change some point recently. Can fluids with 100k still look new?
2007 SR5 4x4.
Schamattack is offline   Reply With QuoteReply With Quote
Old 12-26-2017, 07:39 PM #322
tlynch tlynch is offline
tlynch is on a distinguished road
Front differential help
Sr. Have you ever had to remove had experience in removing the whole front differential?
My problem is that i have gone thru three differentials and was told to remove the front driveshaft from the front diff to the transfer case and convert my 98 4runner to rear wheel drive. I was wondering if this would work?
tlynch is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 10:44 AM #323
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
Possibly. Could be the rig wasn't abused.
Bought mine at 140k with no service history for the driveline. Front and TC came out still amber and light. Rear diff was pretty dark.
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 02-19-2018, 05:38 PM #324
TPz_Fuchs TPz_Fuchs is offline
Real Name: Gus
TPz_Fuchs is on a distinguished road
Real Name: Gus
Awesome thread. Answered so many questions. But I have failed to see anything (forgive me if there is, is may not have searched deep enough) about the logistics to support this drill. I changed my diff oil today, and a few things popped out at me and onto my garage floor, so I will post them here in the hope that it will help others. Is it probably garage 101 type stuff, but I have not done vehicle service for a long time in my garage/driveway and do not have the facilities of a professional garage and find like a great number of other folks, we find ourselves rolling around on the concrete floor or driveway and getting it done. And the little things help to make it that much easier.
1. Safety. Eye protection, Fire ext nearby. Any jacking or support equipment in good condition. Flashlight.
2. What to do with the old oil? Have several empty one-gallon jugs that you don't mind losing to put the old oil in. Have it ready before you begin to drain. Don't count on using the new bottles when empty. Drain the used oil off, using a large funnel, with each differential and transfer case, as you finish them. You don't want to juggle a full drain pan of that nasty stuff.
3. Rags, towels clean-up stuff. Yes, plenty this can be messy.
4. As I was not able to lift the truck up on stands or ramps, space was at a premium. I used quart bottles to pump the oil into the differentials. A gallon jug would not have fit.
5. Use a plastic tray or pan to put the oil bottles on during filling the differentials and another to put tools on. I had to vent the bottle as I filled the diffs and that da&n fill hose on the pump went everywhere, except where I wanted it to go, not to mention when changing out oil bottles. And when getting the oil overflow when full. A pan/tray would have contained the dripage.
6. I used a small plastic funnel and a short piece of ½" ID vinyl tubing to be able to transfer oil from the bottle into the rear diff. (This won't work on the front, gonna have to pump that one.) Make sure you don't overload the funnel and do this over a pan. A piece of tie-wire may help here. It is quicker than the bottle pump.Use the bottle pump to top up the final amount.
7. Spray brake cleaner or carb cleaner. To clean off tools, plugs and the area around the drain holes.
8. If you clean that area around the drain hole, you can see if is anything is leaking.
9. Old style cat litter open and on-hand to soak up spills, before it can get too deep into the concrete.
10. Buy enough oil plus some more. I now have to round up a qt of Redline to do the transfer case.
11. If you do stain the concrete this might help to clean up the stains.
A. Sawdust and solvent - wet saw dust with solvent and scrub stains with a push broom. Solvent will dissolve the oil and the sawdust will suck up the oil/solvent. DISPOSE CAREFULLY! IT IS FLAMMABLE!
B. Tide powder, broom and hose. Wet concrete, sprinkle with Tide powder and scrub with push broom.
2016 T4R SE Premium, 3" ToyTec Lift, SPC UPC, Baja Rack, Shrockworks Sliders, KO2's, Rigid SAE Fog Lights, Gobi Ladder, ArcLight Map & Hatch LED's, Blueridge Overland Attic, 2m Ham.
TPz_Fuchs is offline   Reply With QuoteReply With Quote
Old 03-08-2018, 09:24 PM #325
Fcbuff Fcbuff is offline
Fcbuff is on a distinguished road
T case
My thoughts on the transfer case specifically. I have a 2016 4Runner btw. For those that are anal retentive like me and the thought of the wrong fluid (75w-90) going into the t-case keeps you up at night. After much reading, I decided to put the OE 75w Toyota branded transfer gear oil. It takes Exactly 1liter. I replaced the diffs using the popular Mobil1 75w-90 1st. Therefore I was able to directly compare the fluids. The 75w Toyota fluid is much different. It is much “thinner” in viscosity and ran like water. The 2 different fluids are nothing alike. I feel that the Toyota fluid is the way to go! Nobody knows why the fluid is different,and for those of you who are like me, don’t agonize over it anymore and just use the right fluid. I am going to do it every 50k FYI.
I also used the kitchen can opener to open the can!
Torque 27ftlbs.
I also recommend the Motive power fill
https://www.motiveproducts.com/colle...-1-gallon-tank
Fcbuff is offline   Reply With QuoteReply With Quote
Old 03-08-2018, 09:39 PM #326
aika1 aika1 is offline
aika1 is on a distinguished road
Torque 27ftlbs.
The "75" part refers to the viscosity, so technically they're identical assuming you're checking them at room temp (not full operating temperature). How did you compare the two oils? It may be a "fig newton of your immigration" (a figment of your imagination).
2008 4Runner, V6 SR5 4x4: Front Setup: Icon 2.5 Ext. Travel coilovers, Camburg 1.25 uniball UCA; Rear Setup: 1.5 inch lift Eibach +15% stiffness, Icon 2.0 Remote Resi; ;FN FxPRO wheels 17x8, gloss gunmetal grey; BFGoodrich All-Terrain T/A KO2 LT265/70R17 Load Range C
Shrockworks rock sliders, Husky-liners throughout, TRD Exhaust, Optima Yellowtop D27f, Rigid Dually Pro Spots mounted on CBI ditch brackets, Dynamatted doors and rear cargo area, hardwired 8500 X50 Radar detector, Homelink addition, Alpine ILX-W650 head unit with parking brake bypass, Ultragauge II, Silverstar Ultra lo-beam, OPT7 Hi-beam, Mobil1 synthetic in engine, both diffs and transfer case, Thule T2 Bike rack and Fatcat6 ski racks...
aika1 is offline   Reply With QuoteReply With Quote
Old 03-09-2018, 05:17 PM #327
r32 r32 is offline
r32 is on a distinguished road
r32 r32 is offline
Just did this. Thanks for the great info!
Back fill and drain were a ***** to get off.
Front fill and drain came off easy.
If you have a long torque wrench and working off the ground, forget about being able to torque the fill plug in the front differential. There is not enough room to operate with a long wrench. Even on ramps there was not enough room. I had to buy a second torque wrench that was of the 14" length variety.
Used 75w/90 Mobile 1 in both.
The smell of diff oil is how I imagine rotting dead bodies must smell like. It is near the top of the most foul smell I've ever encountered.
r32 is offline   Reply With QuoteReply With Quote
Old 04-23-2018, 12:59 PM #328
4thGenFireAndRescu's Avatar
4thGenFireAndRescu 4thGenFireAndRescu is offline
4thGenFireAndRescu is on a distinguished road
Just changed my rear differential oil this weekend. It had 150,000 miles on it, it was black, smelled burnt, and there was metal on the drain plug. I filled it back up with AMSOIL 75W-90 using a hand pump made by AMSOIL. That pump makes your life so easy. Changing the rear differential oil has to be one of the easiest maintenance tasks you can do.
2009 Limited V6 4WD, Tints 15 Percent Front, 5 Percent Back. Full racing exhaust in the works.
4thGenFireAndRescu is offline   Reply With QuoteReply With Quote
Old 07-24-2018, 07:59 AM #329
Rapid_Amble Rapid_Amble is offline
Rapid_Amble has a spectacular aura about Rapid_Amble has a spectacular aura about Rapid_Amble has a spectacular aura about
Super helpful, thanks.
I've used Redline gear oil in differentials of rwd cars before. Will probably use their 75w85 GL-5 gear oil when the time comes.
Rapid_Amble is offline   Reply With QuoteReply With Quote
Old 07-24-2018, 01:32 PM #330
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
A Dead body smells worse.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
