Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 11-23-2019, 07:54 AM #346
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 is just really nice Bluesky 07 is just really nice Bluesky 07 is just really nice Bluesky 07 is just really nice
MY GARAGE
Bluesky 07's Avatar
MY GARAGE
Thanks to @snowbizx for the great writeup. Wanted to post this in case itís helpful to anyone else. I bought a set of gaskets that all came together in one bag unlike the pic below. I was only doing the front diff and while the drain gasket is obviously the big copper-colored one, sorting out the fill gasket was tough even when trying to compare the one I removed. So I made this based on the p/n listings in the first post here & a pic I found online.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 11-28-2019, 11:54 AM #347
firebirdguy will become famous soon enough firebirdguy will become famous soon enough
Originally Posted by catrains View Post
You have to use Toyota transfer case fluid. this is a special fluid that has additives to protect from wear.. has electricals in the case. viscosity is not the problem .... mobil synthetic does not have any of these additives..
curious why you say "mobil synthetic does not have any of these additives" where did you get this info from?
mobil & all other brand gear oils that are rated GL-5 have the same anti wear additives as toyota fluid, maybe different levels of some & more of others, but all are acceptable. the toyota manual does NOT say you HAVE to use toyota fluid... just says to use a GL-5 rated oil of the correct weight.
there are literally 10's-100's of thousands of 4runner, tacoma, FJ etc etc toyota owners that use mobil synthetic & other brands of gear oil with no problems or issues at all.
Old 11-29-2019, 08:06 PM #348
catrains catrains is offline
catrains is on a distinguished road
I have the blackstone lab test on the toyota transfer case oil..
buy the cheap oil in the transfer case you get what you pay for ...
I will not use the mobil synthetic gear oil 75-90wt .. el cheapo and no additives to protect the T/Case .. blackstone lab test on the Mobil ..
using the wrong lubricant is your problem ..
catrains is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 12:16 PM #349
yeah, ive seen VOA's on the toyota fluid. can you explain what these magical additives are that other quality synthetics or conventional gear oils dont have? & why mobil gear oil has "no additives to protect the T/case?" thats pure non sense! mobil or amsoil etc are not "cheap" in any way & not one single user of mobil or other non toyota gear lubes have ever had any kind of problems protecting the t-case.
why are you telling us we "have" to use toyota fluid in the xfer case when toyota themselves say in the owners manual to simply use a gear oil that meets the right weight & rating? i have never seen anything about absolutely needing to use toyota branded gear lube lubes in any pre 2015 4runners or tacomas. there is some info that says for 2014/2015 & later toyota uses that special gear lube, but that does NOT apply to any earlier year 4runner, tacoma or FJ etc, & even the dealerships just use a common bulk 75/90 GL-5 lube on these years. if you are only referring to 5th gens then that may be the case, but there are countless 5th gen owners using mobil or other synthetic lube with zero issues.
& i have no problems using the "wrong lubricants"... so not sure what thats supposed to mean... my 2008 T-case works excellent & is smooth & quiet using valvoline 75/90 synthetic. but then again you think you can tell by looking at the plug threads that the toyota engineers were off by 4 ft lbs on their torque ratings! LOL!
Old 12-03-2019, 02:17 PM #350
Boulder BC Boulder BC is offline
Boulder BC is on a distinguished road
Filling through drain plug.
I have an 03 Limited V-8. The rear diff fill plug is rounded out pretty good and is also stuck pretty good as well.
I have seen a couple videos of folks filling the rear diff through the drain hole using pump and rubber stopper. Does anybody on this forum have experience doing this? Or better yet, any advice on getting the rounded, stuck ill plug off?
Thanks!
Boulder BC is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 05:39 PM #351
caper caper is offline
caper is on a distinguished road
weld a nut to it , easy
caper is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 07:20 PM #352
xyzzy xyzzy is offline
xyzzy is on a distinguished road
Info for 2019 4Runner with
  • updated P/Ns
  • MSRPs as of Dec 11 2019
  • links to parts.toyota.com for reference
Code:
item	 desc	part/num
Engine Oil Pan	Drain Plug	90341-12012
Engine Oil Pan	Drain Plug Gasket	90430-12031
Front Differential	Fill Plug Gasket	12157-10010
Front Differential	Drain Plug Gasket	90430-24003
Front Differential	Drain Plug	90341-24014
Front Differential	Fill Plug	90341-18032
Front Differential (old p/n 90930-03136)	Breather Plug	90930-03219
Rear Differential	Fill Plug Gasket	12157-10010
Rear Differential	Drain Plug Gasket	12157-10010
Rear Differential	Drain Plug	90341-18057
Rear Differential (old p/n 90341-18006)	Fill Plug	90341-A0002
Rear Differential (old p/n 90930-03031)	Breather Plug	90930-A3001
Transfer Case (old p/n 90341-18006)	Drain Plug	90341-A0002
Transfer Case (old p/n 90341-18006)	Fill Plug	90341-A0002
Transfer Case (old p/n 90930-03172)	Breather Plug	90930-A3005
Transfer Case	Fill Plug Gasket	90430-18008
Transfer Case	Drain Plug Gasket	90430-18008
Fluids:
2 (1.6) Qts LT 75w-90 GL-5 Gear Oil	Front Differential
3 (2.8) Qts LT 75w-90 GL-5 Gear Oil	Rear Differential
2 (1.1) Qts Toyota LF SAE 75w Gear Oil	Transfer Case
7 (6.6) Qts Toyota OEM ILSAC GF-5 SAE 0w-20 oil	Oil Pan
Code:
where used	unique p/n	count	MSRP	Reference Links
Oil Pan Drain Plug	90341-12012	1	$5.52	https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG-PLUG-SUB-ASSEMBLY/62986468/9034112012.html
Oil Pan Drain Gasket	90430-12031	1	$1.13	https://parts.toyota.com/p/Toyota_2019_4Runner/GASKET/62973975/9043012031.html
Fr Diff Fill, Rr Diff Drain/Fill Gasket	12157-10010	3	$1.64	https://parts.toyota.com/p/Toyota_2019_4Runner/GASKET-PLUG/62915390/1215710010.html
Fr Diff Drain Gasket	90430-24003	1	$2.16	https://parts.toyota.com/p/GASKET/62986560/9043024003.html
Fr Diff Drain Plug	90341-24014	1	$11.32	https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG/63351244/9034124014.html
Fr Diff Fill Plug	90341-18032	1	$7.41	https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG/62981763/9034118032.html
Fr Diff Breather Plug	90930-03219	1	$9.68	https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG---BREATHER-FOR-FRONT-DIFFERENTIAL/66841376/9093003219.html
Rr Diff Drain Plug	90341-18057	1	$12.24	https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG-PLUG-SUB-ASSEMBLY/62986471/9034118057.html
T-Case Drain/Fill, Rr Diff Fill Plug	90341-A0002	3	$6.61	https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG-FOR-REAR-AXLE-HOUSING-FILLER/63286991/90341A0002.html
Rr Diff Breather Plug	90930-A3001	1	$10.72	https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG---BREATHER-FOR-REAR-AXLE-HOUSING/63154719/90930A3001.html
T-Case Breather Plug	90930-A3005	1	$2.44	https://parts.toyota.com/p/PLUG---BREATHER/69385720/90930A3005.html
T-Case Drain/Fill Gasket	90430-18008	2	$1.90	https://parts.toyota.com/p/Toyota_2019_4Runner/GASKET-PLUG-RING-SEAL/62973978/9043018008.html
tab delimited, copy to excel for better viewing.
Hope that helps someone out.
Please update OP as necessary.
xyzzy is offline   Reply With QuoteReply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
