Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 07-28-2018, 04:25 PM #331
IRONLUNG IRONLUNG is offline
IRONLUNG is on a distinguished road
4th gen specific---how is everybody accessing the front fill hex bolt?
IRONLUNG is offline   Reply With QuoteReply With Quote
Old 07-28-2018, 06:31 PM #332
<<<<'s Avatar
<<<< <<<< is offline
<<<< will become famous soon enough <<<< will become famous soon enough
MY GARAGE
<<<<'s Avatar
MY GARAGE
With skid plates removed there should be no issue accessing that bolt.
Who Dares Wins
2013 TRAIL KDSS / Forged TRD 17x8.5 Wheels / Nitto TG 285/70/17 / Shrockworks Sliders / ASFIR Aluminum Trans Skid / 5000K HID Low HL / 5000K 10000 Lumen LED High HL /3000K LED Fogs / TRD Billet Oil Cap / B&I Carbon Fiber Dash / TRD Black Shift Knob / LED Interior / XUJI Leather Steer Wheel / Aluminum Pedals / Aluminum Battery Holddown / Northstar AGM battery / TRD Carpet Mats / LED floor lights / ARB on-board Air
<<<< is offline   Reply With QuoteReply With Quote
Old 08-23-2018, 03:35 PM #333
Fareastplaza Fareastplaza is offline
Fareastplaza is on a distinguished road
I finally changed oil for 2 diffs and transfer case and thinking it's my turn to contribute something here.
Mine is 2010 4runner I believe it is 5Gen. I would like to say, Diffs and TC are exactly same as the picture showing on the first page of 4GEN if it is as described by OP. But, somehow dealer provided 6 gaskets there are 3 of them don't fit. What they give to me, based on receipt, same as the one listed here in first page. So, I had thought it is correct but they are not.
Dealer give to me 3 small, 2 middle, and 1 large (cooper). Due to the receipt, they are 12157-10010, 94030-18008 and 94030-24003.
When I doing the work, I noticed, other than the large cooper one for Front Diff drain, rest are same (or similar) middle size of gasket. None of 3 small can be put in.
I ends up reuse 3 of them for fill as I cannot drive out to purchase anything without my ride is ready. I am little worried if there is problem for reusing them. They call crash washer, and I am actually saw it is crashed when I wrench them in indeed. Should I get correct washer and redo the job?
Fareastplaza is offline   Reply With QuoteReply With Quote
Old 08-23-2018, 04:28 PM #334
Also, about using torque wrench, I know everyone suggest to use it as newbie sometimes just don't know what they are dealing with.
My last night experience was totally opposite.
I changed real diff first. After all old oil drained out, I put the plug back, set my be loved torque wrench to 36 which some one mentioned here. I turned and turned and waiting for the 'click' sound. The 'click' music didn't come out of it before I actually crashed "too much" the crash washer. I then realized I might tight it way too much. I headlight it and look at it, I saw crash washer was squeezed too much and one side had already extended to broken. It is not leaking yet. But I am worried.
So, last night, for all other plug, I forgot torque wrench, only used common sense. torque tight enough I think should be ok.
My friends later told me, I am using a large torque wrench which only accurate on higher setting even it has lower setting in the mark. Also since I set high value on it entire time (mainly used for change tires) when you just set it back to low setting, the spring inside doesn't addjust in time. That might be the reason why I didn't hear 'click'.
After all, I highly suggest to use your common sense, do not rely on some fancy tool. My torque wrench is very expensive so I trust it wrongly :-(
Old 08-23-2018, 06:33 PM #335
<<<<'s Avatar
MY GARAGE
<<<<'s Avatar
MY GARAGE
Torque wrench tip: Set torque about half of what is called for fastener (in your case of 36, set 18). If it fails to "click" you will know and less likely to overtighten or damage your treads. If it does click then set it up to spec (36) and finish the job.
Who Dares Wins
Old 10-04-2019, 07:57 PM #336
bspurs bspurs is offline
bspurs is on a distinguished road
Super simple and helpful post - thank you! I just did rear diff, TC, and front diff, in that order. It was easy and took about 2 hours in total.
Only a couple of thoughts to add about my experience:
  • Sprayed every bolt with PB Blaster the day before, and had no problems getting them loose with a breaker bar today.
  • The rear diff fill bolt was reverse threaded - counterclockwise tightened it. Strange.
  • The front diff drain bolt was tough to get out, as it is so low and I could not get a good angle with my breaker bar, and could not break it free with a standard length socket wrench. Finally got it to break free at an awkward angle.
  • Rear diff fluid had been replaced a few years earlier with the previous owner. It and the TC fluid were pretty clean. But the front diff fluid was literally like grease at the very bottom. The rest came out dirty and fluid, but the first little bit at the bottom dear the drain plug was THICK. Glad I got it changed.
Current: 2007 4Runner Sport 4x4 V6 - 120,000 miles - stock for now...
Former: 1998 4Runner Limited 4x4 - 118,000 miles - TRD Tundra/5100 front, OME 906/5100 rear - Plastidipped exterior emblems - Black painted interior woodgrain
bspurs is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 08:53 AM #337
<<<<'s Avatar
MY GARAGE
<<<<'s Avatar
MY GARAGE
2007 Rear Diff fill bolt should not be reverse threaded. If it is I suspect some one stripped it and repaired with left handed Helicoil or retreaded to the opposite side. Take that bolt out and look closely at your treads. This is not normal.
Who Dares Wins
Old 10-07-2019, 09:06 AM #338
SHagood's Avatar
SHagood SHagood is offline
SHagood has a spectacular aura about SHagood has a spectacular aura about
MY GARAGE
SHagood's Avatar
MY GARAGE
Just changed my front/rear diff and the transfer case yesterday with @papabeach walking me through step-step.
Thoughts:
Very easy maintenance, but have a ton of shop paper towels and cardboard to mitigate oil stains on the driveway. Overall, good learning experience but a messy job. Didn't find any metal shavings in any of the drain plugs, but the gunk that was caked up was disgusting. Bought 7 quarts of Mobil 1 75w 90 off Advanced Auto Parts for about $10/quart with free 3-day shipping.
2008 Urban Runner
MY BUILD THREAD
SHagood is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 10:07 AM #339
<<<<'s Avatar
MY GARAGE
<<<<'s Avatar
MY GARAGE
The gunk on magnet is metal.
Who Dares Wins
Old 10-10-2019, 10:20 PM #340
Itsme71190 Itsme71190 is offline
Itsme71190 is on a distinguished road
Attempted this yesterday on my front diff. My drain is seized. Drawing board
Itsme71190 is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 11:34 AM #341
<<<<'s Avatar
MY GARAGE
<<<<'s Avatar
MY GARAGE
PB blaster spray and wait 2 days. Easy to remove after that unless someone stripped 10 MM hex inside that plug. GL
Who Dares Wins
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
