Old 03-02-2012, 09:32 AM #31
BigRogers's Avatar
BigRogers BigRogers is offline
Real Name: Brian
BigRogers is on a distinguished road
BigRogers's Avatar
Real Name: Brian
So my CEL, TRAC & VSC lights are all on. Since I have already done all this last year, i was thinking it may just be a clogged line, which is one of the reasons the lights can be on according to the FSM. The truck has 184k miles on it and i have been wanting to give the seafoam a whirl anyhow. Do you think it is wise to do while the CEL and other lights are on? May be just running a good fuel system cleaner instead?
Thoughts?
2001 2wd SR5 | Daily Driver
2002 4wd SR5 | Build Thread | Lifted | Armored | Dual Lockers | Geared
BigRogers is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 11:42 AM #32
Jeff4runner's Avatar
Jeff4runner Jeff4runner is offline
Real Name: Jeffrey
Jeff4runner is on a distinguished road
Real Name: Jeffrey
Thoughts?
The traction control system may be an unrelated issue in terms of seafoaming. However, it would be a good option to properly diagnose what is wrong with the electronics just to be absolutely sure. Im not entirely familiar with the 3rd gen system, but the TRAC/VSC is disabled on mine (4th gen). One question, do the CEL, and VSC/TRAC lights come on immediately after start-up, or once you physically start moving. It might be a simple issue such as a Zero Point Calibration, or a ridiculous $900 yaw rate sensor. Mine are on, but the CEL isn't on and only activates when the car rolls.
ASE Certified Automotive Technician
President: Storm Engineering, LLC
04' 4Runner 255 HP V6, Custom CA Intake, Spectre Filter, Custom Interior Light, General Grabbers 265/70/17, Catalytic converter deletes, Flowmaster High Flow Muffler, JBA Performance Headers, Jet Black Bull Bar, Rear Diff Breather Mod, 9006/9005 Silverstar Ultras in all * 160K Club *
Jeff4runner is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 12:13 PM #33
BigRogers's Avatar
Real Name: Brian
BigRogers's Avatar
Real Name: Brian
When the CEL is activated the VSC and TRAC lights all come on. Basically as a visual assistance to the CEL. I totally agree on having the vehicle looked over, but i also know that i have replaced all the big parts to the error code (P0442 - Evap system) and all that really left to replace is the tubing. So i thought a fuel system cleaner might be an inexpensive place to start the process, hence the seafoam as i have always wanted to give that stuff a shot
Old 03-03-2012, 01:17 PM #34
mytyeerinpie's Avatar
mytyeerinpie mytyeerinpie is offline
mytyeerinpie is an unknown quantity at this point
I didn't read the thread but I thought I would throw this in, I was told to NEVER use seafoam on a gas engine as it strips the oil off the valves, I was told to add a little ATF to your oil before you change your oil maybe 200 miles or so before, and it cleans the crap out of everything.
mytyeerinpie is offline   Reply With QuoteReply With Quote
Old 03-05-2012, 11:39 AM #35
Real Name: Jeffrey
Real Name: Jeffrey
If you're talking about the oil from the crankcase, it wont matter if it strips it. The valves get "fresh" oil every time the engine cycles on and pumps oil. Seafoam is safe enough where it wont hurt anything, much like ATF cleans gunk out of the engine. However, with newer vehicles (4th gen and over) its not a good idea due to the multitude of fluid types (type 3/4/WS Merc/Dex etc.) and the properties of the fluid are different than standard crankcase oil. Seafoam is a coagulant of sludge, so it will only fill your oil filter faster (hence do before changing oil), and can blend with the oil. You might be thinking of filling diesel fuel filters with ATF for start up cleaning, because its not a better alternative for putting in the crankcase.
Old 07-05-2012, 10:04 PM #36
swampy_swimmer swampy_swimmer is offline
swampy_swimmer is on a distinguished road
PCV hose or Throttle Body?
I decided to bring this thread back up for reason that I couldn't find answer to my question that might seem obvious to most of you: the best port to add it in with the SeaFoam recent invention (the spray can with hook and tube), is it still the PCV hose or now the TB?
Thanks.
swampy_swimmer is offline   Reply With QuoteReply With Quote
Old 07-15-2012, 01:27 AM #37
SJC's Avatar
SJC SJC is offline
SJC is on a distinguished road
SJC SJC is offline
SJC's Avatar
Thanks.
Yeah i still dont know what hole to put it in ...
3.4 Swap. Sas. Locked front/rear. 5:29's 35x1250 KM2's
SJC is offline   Reply With QuoteReply With Quote
Old 08-15-2012, 06:27 AM #38
zonianbrat's Avatar
zonianbrat zonianbrat is offline
zonianbrat is on a distinguished road
zonianbrat's Avatar
bump.
zonianbrat is offline   Reply With QuoteReply With Quote
Old 12-07-2014, 10:13 PM #39
Toyota_Thom Toyota_Thom is offline
Toyota_Thom is on a distinguished road
2009 Toyota 4runner V6 4.0L 4WD SR5
Obviously about to do the seafoam treatment ....
Help! Am I going crazy, blind or just ignorant of where to look? I have been searching and searching online for a bleeping photo of my brake booster and hose because I can't find it in my engine compartment! I have seen all the nice photos of the black brake boosters and the easy to get to hose sitting nicely behind all the other master cylinders in multiple years in multiple Toyota vehicles. But not my 2009 4runner. One place I saw a photo of a black squared off booster module that sits on the side of the master cylinder I believe but again, no brake booster. The master cylinder and brake fluid reservoir sits right against the firewall! Does my 4runner even have a brake booster and hose? Where is it?
If not, can someone point out exactly where the pvc line is then? I'm a visual learner, and reading something gets me part way there. Seeing it done or detailed photos with decriptions, and I can repeat it no problem. Thanks in advance for any real detailed and descriptive help.
Again, I have a 2009, 4Runner, V6, 4.0L 4WD SR5
Toyota_Thom is offline   Reply With QuoteReply With Quote
Old 12-05-2015, 07:02 PM #40
NoVA_T4R NoVA_T4R is offline
NoVA_T4R is on a distinguished road
Thanks.
If you have the spray Seafoam with the hook and tube, spraying in through the throttle body makes the most sense/convenience. On my 3rd gen, the tube that attaches to the front of the TB has a slight notch at the top that the spray tube fits perfectly into and allows a tighter seal once you attach the tube back onto the TB before spraying the Seafoam.
Plus spraying it in this way gives a higher assurance that the Seafoam is going in through all of the intake manifold passages and applying the Seafoam uniformly.
NoVA_T4R is offline   Reply With QuoteReply With Quote
Old 12-24-2020, 12:40 AM #41
the_glutton the_glutton is offline
the_glutton is on a distinguished road
Originally Posted by RonMAIDEN View Post
If you run a good quality fuel treatment periodically you should never need to do anything like Seafoam;it's more for an engine that has had questionable maintenance history or is a bit older or both.
I run a can of BG's 44k once a year and mine runs great at 150k miles.
Yo, I saw your post about "seafoam" and 44k. I'm a longtime lurker, but happy to be a part of your forums!
Can you tell me the difference between the two? I need to replace a few more o2 sensors, and some other sensors before my bad ***** is running at full tilt. I've got about a half a tank run through 44k, now. What benefits would I get from "seafoam" AFTER 44k?
I'd appreciate any answer, even if it was a **** off, so I'm not waiting for one.
Thanks in advance!
the_glutton is offline   Reply With QuoteReply With Quote
