Old 07-27-2009, 06:20 PM #1
t4rBeast's Avatar
t4rBeast t4rBeast is offline
t4rBeast is on a distinguished road
t4rBeast's Avatar
Seafoam?
Has anybody seafoamed their t4r? I did it to my 3rd gen and it worked great! Smoother ride and overall better performance.
t4rBeast is offline   Reply With QuoteReply With Quote
Old 07-27-2009, 06:27 PM #2
nc211 nc211 is offline
nc211 is on a distinguished road
I haven't, but I did have the dealership do their injector/intake cleaning thing about 12k miles ago. I noticed a difference. I did do the seafoam trick through the brake booster line on my old LS400, and smoked out the neighborhood so bad, someone called the fire department as they thought my garage was on fire! It made a huge difference to the LS. But, honestly though, you're not getting all the benefit of the seafoaming if you don't also clean out the intake and specifically the butterfly opening in the throttle body. That, will produce some great results! Plus, a new set of plugs after the seafoam....and you're glass smooth and got all your power back! After I did all of that to the LS, I could honestly, barely keep it under the speed limit on the highway. I barely had to touch the gas peddle to maintain 80mph. And on those cool, damp mornings back in NC, that baby would freakin' fly off the onramp into traffic!
2005 SR5 V8 4x4. As of 7/09 it has 78k miles. As of 12/10 it has 88k miles. No mods, all stock, never a single problem.
2001 GS430 - Sold @ 60k miles 8/10 - absolutely the most boring "sport" sedan to drive, even with 300hp.
2007 CPO 4-door VW GTI fully loaded - absolute riot to drive, love it!
nc211 is offline   Reply With QuoteReply With Quote
Old 07-27-2009, 08:51 PM #3
el-guapin el-guapin is offline
el-guapin is an unknown quantity at this point
I Seafoamed my runner a week after I got it and what a difference it made. Highly recommended
98 4Runner SR5 3.4L Auto...SOLD!
el-guapin is offline   Reply With QuoteReply With Quote
Old 07-27-2009, 09:02 PM #4
RonMAIDEN's Avatar
RonMAIDEN RonMAIDEN is offline
Super Moderator
RonMAIDEN is on a distinguished road
Super Moderator
RonMAIDEN's Avatar
If you run a good quality fuel treatment periodically you should never need to do anything like Seafoam;it's more for an engine that has had questionable maintenance history or is a bit older or both.
I run a can of BG's 44k once a year and mine runs great at 150k miles.
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
RonMAIDEN is offline   Reply With QuoteReply With Quote
Old 07-28-2009, 12:05 AM #5
t4rBeast's Avatar
t4rBeast's Avatar
If anybody is wondering what seafoam is, its a wonderful elixir you feed through your brake booster line which will clear up carbon builder. It works great.
100% Pure Petroleum
Use in All Engines in All Seasons
2 Cycle, 4 Cycle, and Diesels
Treats 3 Critical Areas: Gas Tank, Fuel Systems, and Crankcase
* Cleans fuel injectors
* Cleans carburetor jets
* Cleans carbon
* Stabilizes fuels
* Upper cylinder lube
* Removes moisture in fuel
* De-icer
* Frees sticky lifters
* Frees sticky rings
* Removes moisture in oil
* Cleans P.C.V. systems
* Cleans catalytic converter odors
* Oxygen sensor safe
Old 07-28-2009, 07:35 PM #6
004Gunner's Avatar
004Gunner 004Gunner is offline
Registered User
004Gunner is on a distinguished road
Registered User
004Gunner's Avatar
I'll have to try that. I had a transmission flush with BG synthetic fluid and the stuff is still bright red 65k miles later
004Gunner is offline   Reply With QuoteReply With Quote
Old 08-14-2009, 10:30 AM #7
trokedawg trokedawg is offline
trokedawg is an unknown quantity at this point
Seafoamed my 2001 with 140,xxx last week. Used about 1/2 can through the PCV hose, 1/4 in the crankcase and 1/4 in the tank.
Idle and startup immediatley improved. Drove for about 250 miles then had my oil changed. Was due for an oil change but the seafoam changed a relatively clear oil to a dark brown. Checked my dipstick a few times since the oil change and the new oil is completeley clear, looks appetizing almost.
Overall very happy, going to do this twice a year or so. Everything is much smoother and I have definatley regained some MPG's.
2001 SR5 4X4, 145,000
SS 1.2
2004 Taco sport seats
Budbuilt skid(soon)
31'' BFG AT
trokedawg is offline   Reply With QuoteReply With Quote
Old 08-14-2009, 10:37 AM #8
RonMAIDEN's Avatar
Super Moderator
Super Moderator
RonMAIDEN's Avatar
If your 4Runner is noticeably running better than it was in bad shape to begin with and needed a Seafoam treatment but after you've done it once you should just add a good fuel additive once or twice a year and never have to do it again since it's overkill as a regular maintenance routine not to mention a pain in the butt to do.
2010 Lexus RX350
Old 10-03-2009, 08:49 PM #9
Coy Coy is offline
Coy is on a distinguished road
Coy Coy is offline
does anyone have a picture of where they added seafoam? Unsure of where the brake booster line is.
Coy is offline   Reply With QuoteReply With Quote
Old 10-17-2009, 10:03 PM #10
KB084RUNNER KB084RUNNER is offline
KB084RUNNER is on a distinguished road
LOL...now that is funny
KB084RUNNER is offline   Reply With QuoteReply With Quote
Old 10-17-2009, 10:06 PM #11
I usually run techron or redline SI1 in all my vehicles every 20,000 miles. The redline seems to work the best and it contains no solvents. It is simply 100% detergent.
Old 10-20-2009, 11:12 AM #12
Ilovesnow's Avatar
Ilovesnow Ilovesnow is offline
Ilovesnow is an unknown quantity at this point
Ilovesnow's Avatar
I have not used seafoam in my 4runner, but I used seafoam with every oil change in my 1999 Isuzu Rodeo and it helped tremendously. The Rodeo had a design flaw with the piston rings - the holes weren't sized properly and oil would get clogged and burn on top of the piston rings. The seafoam would clean up all of the mess and I noticed an improvement immediately after an oil change. Usually what I would do is pour a half bottle in the crank case and let the engine idle for 5-10 minutes before draining the oil.
Maybe this is something that needs to be done with higher mileage vehicles, I am not sure. If you do use it, just be prepared for a mess! The seafoam dilutes the oil so when you remove the drain plug, it will splatter all over the place.
2008 Sport Edition, V6 4x4
265/65/17 REVO's
HCF Delete
M1 all around
Ilovesnow is offline   Reply With QuoteReply With Quote
Old 01-15-2010, 04:47 PM #13
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
hey guys i was reading all up on this seafoam thing, i've never done it on my t4r b4 and its at 260k miles right now, its a 1999 sr5. HOWEVER do you guys think i should do it now? or wait a bit? WHY? b/c i just changed my spark plugs and had an oil change about a month ago. so do you think i should wait until my next oil change and do it b4 the oil change or after the new oil change? also with the spark plugs, i know i dont want to replace new spark plugs after a month just b/c i did seafoam. but if i have to i dont mind spending the extra 20 bucks and labor to replace the plugs. but is it nessary? i want to get the best mileage as possible.
bak3rme is offline   Reply With QuoteReply With Quote
Old 01-15-2010, 07:25 PM #14
blcktpgsr's Avatar
blcktpgsr blcktpgsr is offline
Real Name: Ervin
blcktpgsr will become famous soon enough
blcktpgsr's Avatar
Real Name: Ervin
blcktpgsr is offline   Reply With QuoteReply With Quote
Old 01-16-2010, 05:08 AM #15
wallstreet wallstreet is offline
wallstreet is an unknown quantity at this point
i would like to do this on my 2003 v8 4runner. where to add seafoam? how do i get to the pcv valve/brake booster? the diagram is confusing a little...
wallstreet is offline   Reply With QuoteReply With Quote
