that last plug on the driver's side, I did by feel. Bifocals didn't help at all.
________________ 2007 SE V6 4.0 titanium |
Service Life | Basic Knowledge | SPARK PLUG | Automotive Service Parts and Accessories | DENSO Global Website |
I almost went with Iridium plugs on my V6 but after reading other people’s comments/opinions/experiences I opted to just follow the service manual and get the standard copper Denso plugs.
The process was so straight forward and easy that to change every 30k really didn’t seem like a big deal to me. |
I ran NGK Laser Iridium plugs for 160K Km and they looked pretty good when I pulled them. I changed them anyway, and plan to go another 100K miles. Not sure why others are having issues. I know there's a lot of fakes out there so try buying from a reputable source like RockAuto. Under $10 each
I use a 18" 3/8 socket extension when changing them , removing the plugs on the driver's side firewall is a breeze with it. You can also use this same extension to lower your spare tire. Make sure the coil connectors catch and lock when you slide them back on. Gently tug on it and see if it comes loose. |
Being as I recently picked up a new 2019 TRD ORP, and that I'm also new to late model Toyotas, I have been spending time with the owners manual and maintenance guide.
The maintenance guide says the OEM Denso SK16HR11 gets its first replacement at 120,000 miles or 12 years, which ever comes first. As an aside, it looks like there might be some past history with propeller shafts coming loose - the maintenance guide says the bolts on it should be re-torqued every 15,000 miles/18 months... and every 5,000 miles/6 months if you tow, use a car-top carrier, haul heavy loads, drive on dirt roads, dusty roads, or roads that had salt applied to them. |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite) -
