Old 03-07-2010, 01:01 AM #1
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
Your results after brake/powersteering flush/bleed
first can u guys explain a flush/bleed? is that where u completely take out all the liquid and replace it with new ?
and i read a post how to change power steering and brake fluids...
should there be a difference after changing brake fluid? i can see a change in power steering but brake fluids?
'99 SR5 3.4L 2WD
SOLD
Build Thread
2003 Nissan 350z Track/Autocross
2014 4runner SR5
bak3rme is offline   Reply With QuoteReply With Quote
Old 03-07-2010, 09:55 AM #2
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
Originally Posted by bak3rme View Post
first can u guys explain a flush/bleed? is that where u completely take out all the liquid and replace it with new ? Yes. Without dis-assembly you can't do a 100% change but the goal is 95% or higher...
Power steering fluid: Fresh fluid will lubricate the pump and steering gear better than old fluid. Sometimes you'll notice a slightly smoother feel (when steering in a parking lot scenario) and reduced noise levels with fresh fluid.
Brake Fluid: Fresh brake fluid has no moisture and a boiling point of 400F or so. It's also free of all particulate. Over time brake fluid absorbs some moisture and the boiling point lowers. A couple of hard stops on old fluid can produce a spongy pedal where as it may take 3-4 consecutive hard stops to get sponginess with new fluid. Fluid with a higher moisture content also allows corrosion to set in. A by product of corrosion tends to be particulate which works as an abrasive in the brake system.
What you'll notice with fresh fluid is a slightly firmer pedal.
IMHO a brake system flush every 2-3 years, regardless of mileage, is great preventative maintenance. If you don't drive much and live in a very dry climate maybe every 4 years...
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 03-07-2010, 10:46 PM #3
ALLEGRO's Avatar
ALLEGRO ALLEGRO is offline
ALLEGRO is on a distinguished road
ALLEGRO's Avatar
I got to tell you, in 35 years of driving, all sorts of cars, I have never even heard of a flush for power steering.
I do the brake-fluid change with a baster a couple times a year, but even that is probably overkill.
2007 Driftwood Pearl Limited
ALLEGRO is offline   Reply With QuoteReply With Quote
Old 03-12-2010, 06:39 PM #4
jeober's Avatar
jeober jeober is offline
jeober is on a distinguished road
jeober's Avatar
The word flush or flushing is mis-used. It must come from the cooling system method when you hooked up a garden hose.
Replacing your power steering fluid is a good idea. The system has wearing parts and the fluid becomes contaminated.
Replacing the fluid only in the reservoir, whether yor're talking brakes or PS, while better than doing nothing, is an incomplete job. You should push the fluid through the brakes lines out the bleeder screws. It's most foolproof to do with two people and once you've done it with the wheels removed you'll know how to do it without removing the wheels.
Clarke
'05 4x2
jeober is offline   Reply With QuoteReply With Quote
Old 03-12-2010, 08:27 PM #5
Cougar8000's Avatar
Cougar8000 Cougar8000 is offline
Cougar8000 is on a distinguished road
Cougar8000's Avatar
In what sequence does brake fluid needs to be flushed?
From motorcycle world I can tell you that it makes HUGE difference when you put new brake fluid.
Any of you use Speed bleeders?
03 4Runner SR5 V8 4.7
Cougar8000 is offline   Reply With QuoteReply With Quote
Old 03-13-2010, 10:27 AM #6
004Gunner's Avatar
004Gunner 004Gunner is offline
Registered User
004Gunner is on a distinguished road
Registered User
004Gunner's Avatar
Flushing is when you push out all the old fluid by adding new fluid. Typically the system is kept at a constant fluid level during the exchange process so it can take significantly more fluid to complete a flush. Like Chris mentioned, 95% exchange is the goal. Cooling systems, transmissions, brakes, and power steering are all routinely serviced through this method.
A drain and fill is something that can be done with cooling systems, transmission fluid, and of course engine oil. Brake systems can not be drained and filled because you would introduce a lot of air into the system.
Bleeding is done with brakes and it is used to remove air from the brake system. In this case, it's not much different than a brake flush, except that your goal would be to stop bleeding once air is removed, instead of bleeding out all the old fluid.
004Gunner is offline   Reply With QuoteReply With Quote
Old 03-14-2010, 12:58 AM #7
Uneek's Avatar
Uneek Uneek is offline
Super Moderator
Uneek is on a distinguished road
Super Moderator
Uneek's Avatar
Siphon out all the old brake fluid in the master cyclinder reservior and then top-off with new brake fluid.
You want to bleed the from the furthest wheel from the master cyclinder first. So passenger rear, driver rear, passenger front and driver front wheel.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
Uneek is offline   Reply With QuoteReply With Quote
Old 03-14-2010, 04:03 PM #8
Cougar8000's Avatar
Cougar8000's Avatar
Cool, just wanted to make sure on the order.
