Old 07-31-2010, 08:39 PM #31
shuly's Avatar
shuly shuly is offline
shuly is on a distinguished road
shuly's Avatar
Originally Posted by wbwatson79 View Post
Anybody have a hard time getting the calipers off of their truck? I had no luck linking a couple of 17mm wrenches together so I tried an impact wrench...no luck there either. What on earth do you have to do to free these things up?
I am trying to decide if I should go buy a cheapo 25" breaker bar from Harbor Freight and just go get a 48" piece of conduit to slide over the end of a ratchet/wrench. If the impact wrench wouldn't break them free I think I'll need more leverage than 25". These bolts are kicking my ass!
I used PB Blaster tapped them with a hammer and let it penetrate. Used the jack handle as a breaker bar. If they are really frozen, hit them with some PB blaster and let them sit overnight. Hit them again in the morning and then give it a shot. They will eventually come loose.
My Rig: 2007 Limited V8 (Nautical Blue) | Front Lift & Sliders: Downey Kit | Rear Lift: OME 896 (Heavy with Nitro Sport) |Skids : BudBuilt | Bullbar : Shrockworks| Winch : Warn 9.5XP Amsteel Line | Lights : PIAA 580s | Tires : 265/65 BFG TA/KOs on 18" Stock Wheels | Audio : VaisTech Video iPOD Kit for Factory Nav | Newest Addition - BajaRack | June T4ROTM (Thanks guys!)
shuly is offline   Reply With QuoteReply With Quote
Old 08-01-2010, 12:38 AM #32
riverwolf riverwolf is offline
riverwolf is on a distinguished road
Not trying to be a smarta$$, but are you sure you're trying to turn the bolts in the right direction? When working from the wrong end of a bolt, it's not unheard of to get the polarity reversed. There was even a thread explicitly asking which direction for the caliper bolts about this time last year. FWIW, the factory spec is only 91 ft-lbs and I had no trouble removing mine last year with an 18" breaker bar (only 12$ at your nearest Autozone), no penetrating lube required...didn't even think to turn the wheel on the first one to give myself better access. YMMV.
BTW, CCW will be towards the ground or front of the vehicle when you're facing the rotor assuming your tool handle is somewhere in the vicinity of the mudflap. Rotation is opposite the wheel lug nuts.
-Brent
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 08-01-2010, 03:48 PM #33
wbwatson79 wbwatson79 is offline
wbwatson79 is on a distinguished road
Believe me I checked several times to make sure I was going the right way. They really were just that tight. I finally got them loose after I went to Lowes and picked up a 5 foot long piece of 3/4" conduit to slide over the end of the ratchet. Best $2.67 I ever spent. I cleaned the bolts off because they were definately pretty rusty, also cleaned out the holes in the bracket so hopefully I won't have an issue next time.
2004 Limited V8 4WD
wbwatson79 is offline   Reply With QuoteReply With Quote
Old 08-02-2010, 08:01 AM #34
eliask08's Avatar
eliask08 eliask08 is offline
eliask08 is on a distinguished road
eliask08's Avatar
Shims
My new EBC pads came with an integrated shim, but do I still need to use the old ones? I am doing the sparks today, along with the brakes, and am not certain about this.
Elias
Silver 2005 Sport Edition - Mods will follow? Rite, lemme deal with this rust issue first. -DONE!
Lined Up: '06+ Headlight Assembly and Grill swap. - Headlight's done (sweet!), grille waiting. EBC Green pads and cross-drilled rotors installed. 3000k HID in fogs. Alpine INA-W900BT Nav unit installed with JBL bypass.
eliask08 is offline   Reply With QuoteReply With Quote
Old 08-02-2010, 09:54 AM #35
eliask08's Avatar
eliask08's Avatar
Sorry to be stealing your post, ducman, but I am doing my breaks today and have noticed that the calliper pins are a bit warped. PD Blaster and a mallet were able to get them out in 15 minutes, but should I be concerned? I have a new set form the dealer, but am worried that there might be another underlying issue here.
Old 08-02-2010, 12:07 PM #36
eliask08's Avatar
eliask08's Avatar
Originally Posted by eliask08 View Post
Should I be concerned?
Well, I have a seized piston on the inner, lower caliper, for both the right and left brakes. Sucks to do this today as all the shops are closed for the holiday. I am attempting the rear now, which should go smooth.
Elias
Old 08-02-2010, 03:53 PM #37
eliask08's Avatar
eliask08's Avatar
Rear=Finished. It was incredibly easy. Now, all I have to do is pickup two 13WH calipers from Napa, and reattempt the front!
Old 08-03-2010, 02:08 PM #38
liquidvw liquidvw is offline
liquidvw is an unknown quantity at this point
I used a breaker bar with a short piece of pipe on it for extra leverage. They were in there good.
Elias
I used Wagner thermo quite pads. They had the shim built in. I did not re use the factory shim.
Elias
I thought I had a sized piston as well. Turns out that I just wasn't turning hard enough. I put a pair of vise grips on my c clamp and my piston went in.
liquidvw is offline   Reply With QuoteReply With Quote
Old 08-25-2010, 04:26 PM #39
kdiddy kdiddy is offline
kdiddy is on a distinguished road
Which break is which
SO, I just did a break job and I have a few questions about which pad is which.
I think I matched the pads as they were in my car, but I noticed the new pads had an L on them and the Caliper had an R....and that doesn't seem kosher.
So here is a picture of the old pads, and how I think they were in my car...and how they are now in my car. IF they are wrong I haven't driven it so I can definitely switch them up before I break them in. Help is much appreciated
My 4th Gen Front Brakes walkthrough-break-pads-jpg
kdiddy is offline   Reply With QuoteReply With Quote
Old 08-26-2010, 01:30 PM #40
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
The reason for marking some pads left/right has to do with the metal wear indicators on the pads. If installed on the pads, these wear indicators are designed to start making a squealing noise when the metal tab hits the rotor surface, indicating it is time to replace the pads. In most cases, these wear indicator tabs are supposed to be installed so they would make contact and be 'pulled' by the rotor when the vehicle is moving forward, not being 'pushed' by the rotor. In most cases, this means the outer and inner pads should have the wear indicators installed so they are at the bottom of the pad when mounted in the caliper if the calipers are mounted in front (toward front of vehicle) of the rotors, and if the calipers are mounted behind the rotors (toward rear of vehicle, then the pads would be mounted with the tabs on the top end of the pads.
Since the calipers on the 4Runner are mounted after the hub (behind the rotors), the wear indicators should be on the top of all pads, inner and outer.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Old 09-06-2010, 05:25 PM #41
pmdata pmdata is offline
pmdata is an unknown quantity at this point
Ok, so I got the RF wheel off the ground, truck on a stand and the wheel off in preparation for the new pads and rotors that should be in later in the week. A couple of questions:
I got the hawk ceramic pads; will the come with new pins and cotter pins? Or do I have to get the part numbers and head to the dealership?
Is there anything holding on the rotors besides the lugs and then friction? Nothing else to unbolt?
If I remember right, the 17mm caliper bolts are on the engine side of the hub. How did you get in there with the breaker bar?
I'm sure there are more questions to come.
TIA.
2007 SR5 4Runner V6 4X4 - Nautical Blue
pmdata is offline   Reply With QuoteReply With Quote
Old 09-11-2010, 10:54 AM #42
Part numbers for the pins, clips and M springs for future reference.
My 4th Gen Front Brakes walkthrough-imageuploadedbytapatalk-jpg
Old 09-26-2010, 03:23 PM #43
Medvedko Medvedko is offline
Medvedko is on a distinguished road
Thank you for the sweet walk through on the brakes!
I wanted to hit the dealer this weekend but had little time so went to Napa today and got everything I needed including the pads. I always buy OEM but have heard great things about NAPA and the guys near me are great to deal with unlike my Toyota dealer.
Anyway, I have an 06 V8 SE and got the rotors and pads for like $260 + tax and they have a $50 dollar mail-in rebate until the end of September if you by over $250 in rotors, pads, calipers and other selected brake parts. The Pads are basically free if you go this route. I got the Adaptive 1 pads so we'll see after hearing good things about them. BTW, they do sell the pins and anti rattle clips as well at NAPA.
I have 48k on the clock, hopefully the calipers are cool when I do this job next week.....
Great group of people on this forum!!
Medvedko is offline   Reply With QuoteReply With Quote
Old 09-28-2010, 10:14 AM #44
TBoliv TBoliv is offline
TBoliv is on a distinguished road
TIA.
I was able to get an 18" breaker bar in there to get the caliper bolts off. Course mine weren't stuck on super tight, so I didn't need a ton of room to crank on them. If you needed extra space, turn the wheel.
TBoliv is offline   Reply With QuoteReply With Quote
Old 10-10-2010, 04:57 PM #45
Ok. Front rotors and pads done today. First side: 1.5 hrs. Second side: 20 min.
Two questions:
1) I may have put the pad with the metal tab on the wrong side on one of the wheels. Big issue?
2) I got new pins, M springs, cotter pins and shims from the dealer. I didn't notice before install, but four of the shims are flat, and four are slotted. Well, one side got four flat shims and one side got four slotted. Is this a big issue?
Other than that, no problems. Road test and bedding later tonight.
brakes , pads , rotors
