05-10-2010, 04:28 PM
EFI Relay
Ok, So I am an idiot....I pulled the EFI relay fused to reset the tranmission like forum members have suggested, and I forgot to undo the battery first and turn off the car (I was listening to the radio) and blew the relay.....I feel really, really, really dumb. So my question is, how does one go about changing the EFI?
05-10-2010, 08:12 PM
Moderator
Real Name: The Chosen One
Moderator
Are you talking about a relay or a fuse, they're 2 different things.
The EFI what?
'89 4Runner SR5 - stock
05-10-2010, 08:59 PM
Sorry, the relay. The fuse is fine. I think I shorted the relay when I pulled the fuse with the car on.
Super Moderator
Super Moderator
What year? The pic below is a 4th gen...
This is a quote from another thread but it may help; "2) Remove the fuse cover by pushing in on the plastic latch. My finger is on the latch in the photo. The lid will release than it will lift right off.
3) Using the tool which "lives" in the fuse block remove the two fuses for 3 minutes or so. Then replace the fuses and cover. Turn the key to on, wait 5-10seconds and then engage the starter. That's it! The other thing is make sure the tires are serviced 32-35psi.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
05-10-2010, 10:37 PM
I tried resetting the fuses, but haven't checked the tires yet. Ill try that in the morning before going to the stealership. Thanks for the advise!!
edit The Tires are were they are supposed to be...Other than the fuses, are there any other resets or did I destroy the relay circut?!?
05-10-2010, 11:09 PM
The EFI what?
Sorry I somehow overlooked this question. I think EFI is as in Electronic Fuel Injection? I'm sure someone will correct me if I'm wrong.
05-11-2010, 10:16 PM
Moderator
Moderator
EFI is Elec Fuel Inj, but it's a big system.
You want to change the entire EFI system, or some part, or what.
05-12-2010, 09:35 PM
Moderator
Moderator
There's some important info missing here.
What year?
What engine?
05-12-2010, 10:10 PM
What year?
What engine?
2008 4.7L v8 2wd. Turns out the codes just had to be cleared. Not sure what happened but that fixed it.
05-13-2010, 09:14 AM
Moderator
Moderator
Then nothing was damaged, that's great
05-13-2010, 09:54 AM
Where did you see the instructions to pull the battery first? I pulled my EFI fuse once but didn't unplug the battery. Also I know Chris posted in another thread ( Getting Chittay Gas Mileage !!! HELP !!!) and only mentioned to have the car off to do this.
2007 4Runner Sport V6 4WD Shadow Mica, Tint, Extended differential breather, Carbon filter removed, Bilstein 5100s - 0 setting with Old Man Emu 884s, ToyTec Superflex coils and 5100s rear, Dobinsons UCAs, P265/70/17 Michelin Defender LTX M/S, Spidertrax, Xtreme Phillips 4300K HIDs, ICON Sway Bar Relocation Blocks
Former 1999 4Runner Highlander V6 4WD Black
05-13-2010, 08:52 PM
Actually my problem was the car was on, not that the battery was connected; however, the dealership was actually the first to suggest to pull the fuse. They said to turn off the car and undo the battery to be safe. All ended well, but I still wouldn't do it with the car on again.
12-29-2023, 10:23 AM
Good
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
