Old 04-14-2011, 11:37 PM #16
renep74 renep74 is offline
renep74 is an unknown quantity at this point
skyline,
You are exactly correct. I went back and check the write-up it's for 1999 T4R. For 1GR-FE engine, only clean the TB.
renep74 is offline   Reply With QuoteReply With Quote
Old 10-02-2011, 01:22 PM #17
Brunes Brunes is offline
Brunes is on a distinguished road
Great Write up- The idle and response on my new-to-me 04 is much smoother now.
Dovetails well with a spark plug change, MAF cleaning, ECU reset, air filter change, and general cleaning of crud outta the engine bay. Gunna do my Tacoma soon...
Brunes is offline   Reply With QuoteReply With Quote
Old 10-02-2011, 02:35 PM #18
Dougtoms01's Avatar
Dougtoms01 Dougtoms01 is offline
Dougtoms01 is on a distinguished road
Dougtoms01's Avatar
What is the ECU reset? Is that the Check Engine Light? How do you reset it? Newbie here :-)
Dougtoms01 is offline   Reply With QuoteReply With Quote
Old 10-02-2011, 03:06 PM #19
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
disconnect - battery term. for a few minutes, then reconnect, that reset it so it can start relearning again.
chaz is offline   Reply With QuoteReply With Quote
Old 04-21-2013, 06:49 PM #20
codman232 codman232 is offline
Real Name: Cody
codman232 is on a distinguished road
Real Name: Cody
I did this 2 days ago along with cleaning the Mass Air Flow sensor, and if you are considering doing this I would highly recommend it. I have a 2007 4runner with 80k miles and it drives like a new car after cleaning the MAF and the Throttle Body. Acceleration is much better and it seems like the 4runner is shifting gears much smoother. I asked my wife to drive it just so I wasn't just over reacting to this but she also said it drives like a new car, hopefully it was because of the cleaning and not from the ECU reset. Thank you for the write up and again if anyone is thinking about doing the cleaning and you have high mileage, I would definitely consider doing this maintenance.
codman232 is offline   Reply With QuoteReply With Quote
Old 05-07-2013, 01:25 AM #21
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
am doing this soon!...good write up
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 05-11-2013, 02:46 PM #22
Duck'n's Avatar
Duck'n Duck'n is offline
Duck'n is on a distinguished road
Duck'n's Avatar
All was going well until one of my throttle-body bolts broke! Now I am wondering if my torque wrench (not an expensive one) is suspect. I had it set to 15 lbs. and it seemed like they were getting REAL tight so I am thinking I have a problem with the wrench. Other than that, my throttle-body was FILTHY and it looks ALOT better. The MAF looked very clean but I sprayed it with MAF cleaner anyway. Now I just have to wait for the bolts to come in. I am getting chummy with the local dealers parts department!
Duck'n is offline   Reply With QuoteReply With Quote
Old 05-11-2013, 03:07 PM #23
pls confirm that u can use the throttle body cleaner to also clean the MAF sensor
Old 05-12-2013, 09:27 AM #24
Duck'n's Avatar
Duck'n's Avatar
I bought both throttle-body cleaner and MAF cleaner. They are made by the same company. Only local store that carried both was O'Reily's. about $10-12 for both.
03 Limited 4x TOTALED on 12/27/2013 by a hit and run driver (never found)...RIP!
Old 05-14-2013, 09:19 PM #25
Duck'n's Avatar
Duck'n's Avatar
Bolts came in today so I buttoned her all back up. Runs great! I didn't drive it around too much as my wife wanted this dime in her suburban now but it does some more responsive and to shift better. On a side note, the job on my wife's Vortex was a lot easier. Her MAF was also a lot dirtier. Anyway, great write up and I am glad I did it. Considering Seafoaming it now but still reading up on it. I JUST installed iridiums so I want to make sure I do t mess them up!
Old 06-30-2013, 02:38 PM #26
jmm3807 jmm3807 is offline
jmm3807 is on a distinguished road
So I did this and reset ecu. The problem I'm having is when I bought the truck when I cranked it I don't remember it starting up the rpms this high. Basically at start it goes up to 2k then slowly brings it down to about 1k-1200. It never really sits back below 1k until I put it in gear. Before this it would sit around 600-800. I don't really know if this is normal. My TB was filthy though and I did an ecu reset no cels or anything just seems like high idle.
jmm3807 is offline   Reply With QuoteReply With Quote
Old 07-01-2013, 12:50 AM #27
jpless's Avatar
jpless jpless is offline
jpless is on a distinguished road
jpless's Avatar
Normal. Just did mine recently. Also installed a URD maf cal and same thing. Each time you reset the ecu, at least by disconnecting the battery, it'll jump. Take it down the street and it'll go back to normal.
My Build Thread
2006 Grey Mica Limited 4wd, JBL, RCI Skids, FJ TT suspension, aFe stage 2 CAI + URD MAF cal, Sprint Booster, Cobra 75 CB, 17" MB Gunner6 wheels + 265/70 Cooper Discoverer AT3s, Poly Bushings, Rear Diff Breather Mod, Morimoto XB 4500k HID Lows, LEDs in and out, Husky Liners, Load Warrior.
jpless is offline   Reply With QuoteReply With Quote
Old 04-21-2014, 11:26 AM #28
ASUMTNEER ASUMTNEER is offline
ASUMTNEER has a spectacular aura about ASUMTNEER has a spectacular aura about
Going to bring this thread back from the dead! Thanks to OP for this post. I have been meaning to do this for a long time. I had a day to myself, so what better to do than some vehicle maintenance!!! I followed the directions of the OP, but I decided to disconnect the coolant hoses so I could get the TB out of the engine bay and scrub it real good with a toothbrush. I was surprised, probably shouldn't have been, with the "gunk" on the back of the throttle body. Here are before and after pics. Total time of the diy was maybe 40minutes. Piece of cake. The car really does drive much better now. We'll see if I increase the fuel mileage or not.
ASUMTNEER is offline   Reply With QuoteReply With Quote
Old 05-19-2014, 11:12 PM #29
ellroy2 ellroy2 is offline
ellroy2 is on a distinguished road
I also just did a bad thing and broke one of the throttle body mount bolts. My wrench was set to 15lbs and it seemed like the bolt just kept spinning until it broke. I put a dap of anti-seize on so maybe that had something to do with it?
Anyways, I am in a bad spot because I don't have another car and am actually in Baja Mexico, about 2 hours south of San Diego. I have no idea how I am going to get a replacement bolt. Do you think I could safely drive the truck with only 3 of the 4 throttle body bolts in place? The other 3 bolts were spinning too and I didn't want to over tighten them and break them too. But is seems secure.
ellroy2 is offline   Reply With QuoteReply With Quote
Old 01-28-2016, 04:45 PM #30
rkw23 rkw23 is offline
rkw23 is an unknown quantity at this point
Continued high idle after TB cleaning
Did a lot of searching with no viable answers for my high idle after TB cleaning.
2008 4runner V6 116K mile:
- cleaned my MAF and dirty TB for the first time since I had a low idle after a battery replacement
- after several weeks of driving (and battery & EFI fuse disconnect/re-connect) still having high idle (1200-1300 in park and ~900 in drive). Also idles a lot higher when first starting it up cold (~1800rpm, think it used to be ~1400)
- did recheck all hoses, etc.. for any vacuum leaks
- checked the inside bore of the TB and don't see anything that is jamming/binding the butterfly to cause a high idle.
I didn't replace the rubber TB gasket but it doesn't look bad.
I cleaned the TB with the CRC fluid on a towel and wiped the inside of the TB really hard, wonder now if I might have taken some (alum) material off the inside of the TB to cause a wider open against the butterfly??
Any suggestions before I go for a new (refurbed) TB for about $100.
Thanks
rkw23 is offline   Reply With QuoteReply With Quote
