Old 03-31-2020, 01:53 PM #46
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
Also broke small fitting in the back
Old thread but also broke the little plastic fitting in the back of the air box.
Did a very weak repair with crazy glue to keep in place and reinforced later with epoxy.
How important is that fitting/hose?
Any suggestions for a more reliable repair?
Thanks
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 05:23 PM #47
Bowdenknxvll Bowdenknxvll is offline
Bowdenknxvll is on a distinguished road
Originally Posted by CJ3Flyr View Post
-Using the 10mm ratchet again loosen the clamps (A.) and remove the airbox mounting bolts (B.).
-Next undo the harnesses labeled C.
-Next undo the breather hose (D).
-Next detach the harness standoffs (E).
-Next remove the airfilter and detach it's 'lid' from the inlet hose.
-Next look at the back of the airbox and remove this rubber tubing (E). A quick twist and a pull should be fine. There's no clamp on it.
This is just an orientation photo showing the box loose but not completely removed.
And one after the box is completely removed.
Thanks so much for posting! Bought an 06 last summer with 230k. I drive a lot and needed something with 4wd. Cleaned my throttle body today and it was nasty. Took me 30 minutes to clean it off. Very easy to do thanks to your post.
Bowdenknxvll is offline   Reply With QuoteReply With Quote
Old 03-04-2024, 03:59 PM #48
andes andes is offline
andes is on a distinguished road
Thanks for your post. I followed what you did but replaced the throttle gasket as well part #22271-0P010 ($12). My 2007 is at 156k and probably never had the TB cleaned in my records.
The new gasket was visibly wider than the old one, so maybe some wear, maybe just compression, but I did that. Can't say that it runs different but it shifts better in a cruise doing some pickups.
'07 4WD 4.0L Original Owner, BXBuilt Headlights, TRD Pro Grille, Fox 2.0 Performance Series, KMC Wheels.
145k miles and counting
andes is offline   Reply With QuoteReply With Quote
