02-21-2017, 05:49 PM
#31
is there a torque spec for installing the new plugs?
pet every dog
02-21-2017, 06:27 PM
#32
v6 (1GR-FE)
Service manual shows:
13 ft.lb for the spark plugs
66 in.lb for the ignition coils
05-26-2017, 04:24 PM
#33
Originally Posted by ZebRuaj
The "H" is for the longer plugs, which you need. The IK series are regular Iridium plugs, the SK series are Iridium plugs rated for long life.
Personally, I just stick to the Denso K20HRU11 copper plugs. The V6 is a tank and doesn't need anything special. My OEM plugs made it 140k before I changed it out when I bought the truck. I was also able to source all 6 for about a $1/ea. Yes they're only rated for 30k, but can easily go further, and getting under the hood periodically allows me to visually inspect the motor. They're also super easy to swap out, so win/win.
Try putting back new OEM copper plugs to see if it makes a difference
For what it's worth on an older thread, my gas mileage came back up to where it was pre-plug change after about 5 or 6 tanks of gas.
2005 V6 Limited 148k
07-09-2017, 09:39 PM
#34
I remember some plugs need the 'anti seize compound. I already got the Denzos. Just need to know if I need to go back and get that. thanks
___________________
2007 SE V6 Titanium
07-12-2017, 09:04 AM
#35
___________________
2007 SE V6 Titanium
Read the box? I believe NGK's say not to because of the compound they use. I still add a dab of anti-seize on all plugs I replace. Just torque them in correctly because they are "wet" now instead of "dry".
I also add a dab of silicone - dielectric grease inside boot.
07 T4R Sport Edition V6 4x4
07-12-2017, 12:48 PM
#36
Thanks, not much on the box, but 'Made in Indonesia'. I thought it was NGK saying not. will pick up some now.
07-28-2017, 12:50 AM
#37
Real Name: Neil
Real Name: Neil
Ngk 7877
Ok, had to revisit this post cuz some of the guys on one of the Facebook groups had me scared thinking I put in the wrong plugs last week, even though I had the same NGK 7787's I'd put in 70K miles ago with no issues whatsoever! I've been going through multiple sites the past hour & finally decided I should check NGK directly. So yes, 7877's are fine direct OEM replacements. Whoo...that was exhausting!
'04 4RUNNER Titanium Metallic 4.0 LTD 4WD. Toytec Ultimate lift | LR UCA | ProComp 7105 wheels 17x8 | Cooper STT Pro tires 285/70/17 | RCI Full AL skids | RCI steel diff skid | Ricochet AL LCA skids | BAMF sliders | Demello Offroad 3 Hoop Bumper | Spec-D headlight housing, XD Philips 4300k halogen, TRS BiXenon ACME Super HIDS
07-28-2017, 10:05 AM
#38
Originally Posted by nghiS4
So yes, 7787's are fine direct OEM replacements. Whoo...that was exhausting!
I went with Denso's .. but yeah, it pays to do your own research. Don't trust everything you see on FB. I rank research, forum knowledge, then FB knowledge.
05-23-2018, 09:57 PM
#39
Passenger side was easy, driver's side--how do the clips come off the coils?? Is is like the like the connector for the front lights??
2007 SE V6 Titanium.
05-29-2018, 10:39 PM
#40
I think they're exactly the same, if I recall correctly. Need to move a couple of hoses and a bracket to make it easier.
05-29-2018, 10:45 PM
#41
On the passenger side, I never unhooked the coils, driver's side, definitely needed that. First time on my truck, the NGKs where under there.
______________________
2007 SE V6 Titanium
06-03-2018, 11:45 AM
#42
Here I went with Autolite Iridium XP5325. My reasoning is quality gap is surely narrowing; price point, Advanced Auto had 20% off online/store pick-up coupon; 0.6mm center electrode, some research revealed 4mm can wear faster, while performance of larger 5 or 6mm center electrode is not much different; platinum sidewire, seems others except NGK didn't have platinum sidewire. No check engine light yet, but time will tell if my savings pays off.
The old plugs were NGK R LFR6C, 4 gaps were .043 to .045, one gap was slightly larger and one slightly smaller, but they all looked normal at a glance. Probably didn't need changing except for the too narrow, glad I caught that. 2005 V6 with 295k.
An aside, before I knew better, I put Bosch Iridium's in my 2005 Camry 4cyl, 10k on them and no problems yet.
06-13-2018, 10:34 AM
#43
Replaced Spark Plug
Just replaced my spark plugs on 2007 V6. Passenger side was easier than driver side, but still not too bad. I did remove the top bolt and loosen the bottom bolt on the bracket cover the drive side so I could rotate it out of the way.
Make sure you have at least a 12 in extension but I even attached another extension on that to make it longer, and used electrical tape around the spark plug socket so it wouldn't slip off.
The ones I took out weren't bad, but looks like the previous owner didn't gap them. I gapped mine to the owner's manual specification of 0.43mm.
06-04-2023, 04:11 AM
#44
Originally Posted by IK13
Looking at the Toyota maintenance schedule online I noticed that for this engine Toyota requires that the spark plugs are changed at 60K (bought it certified preowned at 34K, so I don't know if it was done at 30K).
Required by the terms of the Emission Control Warranty.
Well I'm at 65K, didn't change'em at 60K. Dealer serviced (oil changes at ~5K intervals). Didn't know and the dealer didn't bother to tell me (offered other nonsense though).
The car runs fine and I can't detect any signs that the spark plugs actually need change.
So, did I void my "Emission Control Warranty"?
The truck may run fine but the plugs are not gapped anymore at .043 at 60k.
I too was pushing 60k with some NGK 7787, but will swap out at 30k from here on out. The gap had eroded to .05+ on all of the old plugs.
The Coil on plugs and connectors are in great shape at 145k.
NGK 7787's are good, maybe not the best but solid in my book.
08-31-2023, 05:49 AM
#45
I am getting ready to replace my plugs and coils on my 4Runner. It has 200k on it
